Lenina
Куратор "IPBox"
PKT 9.6.1 Tideglo rev 0.9.6
Changes compared to version 9.6 POINT:
- Added Media Center Menu
- Ejected from the menu VCR scart
- Reorganization of the Setup Menu
- POINT dopaswanie skins to change the menu
- Update Picon
- Added new plugin POINT Skin Setup (described in section Skins POINT)
- Added ability to disable the background image in the radio mode
- Added ability to disable top info bar in the Skinhead BlackGlass show off EMU in Skin Setup Info
- Cosmetic fixes in Skinhead BlackGlassHD
- Added call POINT Skin Setup by pressing the SWAP (the sub-web)
- Skin removed PKT_F1-Lite - now with Skin Setup can be obtained from the same Skin PKT_F1-HD
- Added support for the EmuCamInfo OSCAM (works with versions that generate ecm.info)
- Optymaplizacja code EmuCamInfo
- Other minor fixes and performance graphics
http://e2.pkteam.pl/index.php?dir=IMAGE IPBOX/Enigma2/9.6.1_usb/
- Update Picon
