PKT KATHREIN E2 HYPERION IMAGE
Тема в разделе "E2", создана пользователем aleks.62, 14 апр 2013.
  1. aleks.62
    aleks.62 Профи в Сат-ТВ
    8 янв 2008
    1.134
    641
    Источник - http://pkteam.pl/viewtopic.php?f=29&t=5359
    E2 OpenSource SH4 Duckbox Project GIT-4767 PKT SVN-2060 HYPERION Image
    Added by PKT:
    [ALL] migration to OpenPLI
    [ALL] add more than 100+ plugins to download
    [ALL] fixed aspect ratio selection in A/V setting.
    [ALL] fix network setup
    [ALL] transparency fix if any window opend while infobar is dimming
    [ALL] added recording setup to menu
    [ALL] PermanentClock : added progress bar & other small fixes
    [ALL] fix subservices reload
    [ALL] fix green key support in infobar
    [ALL] Basic HD skin removed - it is already as default
    [ALL] fix opkg
    [ALL] add djcrash Updater v1.2.5
    [ALL] update Backup Manager v1.7
    - add /media/Points for backup
    - add backup of timer
    [ALL] converters update
    [ALL] new approach to control of FrontPanel
    [ALL] fix SCART Output
    [ALL] add missing: subtitle setup & autolanguage setup to main menu
    [ALL] fix GS when subtitled was selected by Audio Menu
    [ALL] GraphMultiEPG -fixed compatibility to other skins ( without our fonts )
    [ALL] 1st boot wizard fix
    [ALL] Languages: 1st is English, 2nd - Polish, others is alphabetical order
    [ALL] fix Backup Aurorestore - now 100% working
    [ALL] FrontPanel Setup extended to Time&Name, Time&Number
    [ALL] video settings optimization
    [ALL] update skins for PIG support
    [ALL] fix some STB's for PIG support
    [UFS910] fix restart network interface
    [ALL] increase stability
    [...] and many many other changes not included in chagnelog.
    Dodane przez PKT:
    [Wszystkie] migracja do OpenPLI
    [Wszystkie] dodane ponad 100 pluginów do pobrania
    [Wszystkie] naprawione ustawianie formatu obrazu w menu ustawień A/V.
    [Wszystkie] naprawione ustawienia sieci
    [Wszystkie] naprawiona przeźroczystość okien przy wygaszaniu paska info
    [Wszystkie] dodane ustawienia nagrywania do menu
    [Wszystkie] PermanentClock : dodany pasek postępu i inne drobne poprawki
    [Wszystkie] naprawione przeładowanie serwisów
    [Wszystkie] naprawiona obsługa zielonego klawisza przy wywołaniu z paska info
    [Wszystkie] Basic HD skin usunięty - występuje teraz jako domyślny
    [Wszystkie] naprawa opkg
    [Wszystkie] dodany plugin djcrash Updater v1.2.5
    [Wszystkie] aktualizacja Backup Manager v1.7
    - dodane archiwum /media/Points
    - dodane archiwum timera
    [Wszystkie] aktualizacja konwerterów
    [Wszystkie] nowe rozwiązanie obsługi FrontPanela
    [Wszystkie] naprawa obsługi wyjścia SCART
    [Wszystkie] uzupełnione w menu: napisy i język automatyczny
    [Wszystkie] naprawiony GS gdy zostały wywołane przez menu Audio
    [Wszystkie] graficzne EPG - ustawiona kompatybilność ze skinami ( nie posiadającymi naszych fontów )
    [Wszystkie] naprawiona grafiak Wizard'a przy pierwszym uruchomieniu
    [Wszystkie] języki: pierwszy - angielski, drugi - polski, pozostałe w kolejności alfabetycznej
    [Wszystkie] naprawa Backup Aurorestore - 100% sprawny
    [Wszystkie] FrontPanel Setup rozszerzona obsługa o Czas i nazwę kanału, Czas i numer Kanału
    [Wszystkie] optymaizacja ustawień obrazu
    [Wszystkie] aktualizacja skinów o funkcje PIG (Obraz w grafice)
    [Wszystkie] naprawa działania PIG w niekórych dekoderach
    [UFS910] naprawiony restart kart sieciowych
    [Wszystkie] poprawa stabilności
    [...] i wiele więcej innych zmian nie opisanych tutaj.
    Special THX to TDT and all betatesters.
    Specjalne podziękowania za wkład dla TDT i betatesterów.
    FTP login: root, passwd: pkteam
    Regards
    Pozdrawiamy Polish Koders Team
    Ссылка на закачку
    UFS910 - http://www.sendspace.com/file/ztw6eq
    Выложены и для UFS912 и UFS922.
    ---------- Сообщение добавлено в 02:42 ---------- Предыдущее сообщение размещено в 02:17 ----------
    P.S. Запустил. На большее уже нет времени...
  2. alex1059
    alex1059 Профи в Сат-ТВ
    1 ноя 2006
    768
    109
    Запустился без проблем. все-равно транспондеры с DVB-S2 каналами через некоторое время просмотра начинают рассыпаться.
  3. Guzon
    Guzon Новичок
    24 сен 2008
    43
    1
    дайте сылку на закачку для ufs912
  4. alex1059
    1 ноя 2006
    768
    109
    Сецчас на форум пкт нельзя зайти, видимо сервак пергружен. попробуй через некоторое время здесь найти http://pkteam.pl/viewtopic.php?f=29&t=5359
  5. aleks.62
    8 янв 2008
    1.134
    641
  6. Guzon
    Guzon Новичок
    24 сен 2008
    43
    1
  7. mihailp
    mihailp Пользователь
    5 ноя 2006
    209
    15
    А если попробовать драйвера от Небулы?
  8. aleks.62
    8 янв 2008
    1.134
    641
    Через сколько примерно.
    Выставил 1080p, включил HD Кино. За полчаса один раз дернулось. Заметил только потому, что ждал... И похоже это было больше на сбой по шаре, чем на рассыпание.
    Вроде работает. Как повторить? На каких каналах обнаружили и через какое примерно время?
  9. alex1059
    1 ноя 2006
    768
    109
    Стоял на HD Кино примерно 20 минут.
  10. aleks.62
    8 янв 2008
    1.134
    641
    Пока без проблем. Как включил - не прикасался. Около двух часов уже.
    Если что вылезет - отпишусь...
  11. mihailp
    5 ноя 2006
    209
    15
    Имидж действительно шикарен!
    Рассыпания картинки нет. Смотрел ХД Футбол - 2 часа один раз дернулось и все. После этого поставил плагин очистки памяти с интервалом в 5мин - дальше просмотр без проблем.
    Отдельной похвалы заслуживает скин HD Glass16. Это просто бомба для UFS910! Периодически заглядывал к Октагонам и завидовал. А теперь он есть на Кате!
    Осталась лишь старая проблема имиджей от ПКТ - не засыпает подключенный по USB HDD ни по времени ни при дежурке.
  12. alex1059
    1 ноя 2006
    768
    109
    С этого момента поподробней плиз.
  13. BrunoM
    BrunoM Новичок
    19 янв 2011
    156
    2
    Добрый день 1
    Вроде все ОК на это имидже, только wicardd на BISS не хочет запускаться :(
    На другом ПКТ имидже все было ОК !
    В чем может быть проблема ?
    Спс
  14. mihailp
    5 ноя 2006
    209
    15
    В плагинах есть такой ClearMem.
    В установках выставляется периодичность очистки оперативки от мусора.
    Имидж собран на базе OpenPli. Видимо есть какие-то отличия. Сейчас попробую - отпишусь.
  15. BrunoM
    BrunoM Новичок
    19 янв 2011
    156
    2
    Имидж собран на базе OpenPli. Видимо есть какие-то отличия. Сейчас попробую - отпишусь.[/QUOTE]
    Спс !
    Не только бисс а и шарик не катит ! :(
    Главное на 10 грю NBA на бисс не идет !!!!bad!
  16. alex1059
    1 ноя 2006
    768
    109
    Надо у октагоновцев почитать про эмулятор vicard. У меня тоже этот эмуль на этом имидже не запустился.
  17. Rood
    Rood Пользователь
    8 янв 2007
    131
    19
    Блин это эпидемия какая-то с рассыпанием HD-каналов. Я блин разобрал тюнер, паяяю резисторы, а похоже, трабла в чем-то другом ...
  18. mihailp
    5 ноя 2006
    209
    15
    Эмуль на бисах работает. А триколоры у меня не открывает.
  19. alex1059
    1 ноя 2006
    768
    109
    Все, разобрался. Вот что пишут в ветке октагона: с wicardd пока сам не понял. На последних двух предрелизных версиях PKT он перестал работать... До этого все работало...
    Вот поставь пока этот эму менеджер с версии 2026 он работает с wicardd . Я написал по поводу бага обещали посмотреть...
    Надо заменить эму менеджер в плагинах. Прикрепил его ниже. Файл wicardd.conf положить в папку /var/etc/. Файл wicardd в ту же папку. права 755. С хитрым просмотром 3к не разбирался. По шаре он идет.
    • EMUmanager.rar
      Размер файла:
      30,2 КБ
      Просмотров:
      36
    • wicardd_1.13.rar
      Размер файла:
      538,1 КБ
      Просмотров:
      34
  20. roman5
    roman5 Любитель Сат-ТВ
    21 апр 2008
    976
    42
    А зачем все подряд менять- в ветке WICARD выложена сборка для 3-небулы, все влет..., по папкам разложите правильно.
    ---------- Сообщение добавлено в 20:56 ---------- Предыдущее сообщение размещено в 20:37 ----------
    Поправили запуск Wicardd... BP->Обновления->Firmware->Скачать -> SVN-2062( из ветки октагонов), сам не ставил имидж, поэтому так- что вижу, то и пишу.
Похожие темы
  1. allllex
    Ответов:
    41
    Просмотров:
    13.506
  2. levan
    Ответов:
    8
    Просмотров:
    6.191
  3. aleks.62
    Ответов:
    25
    Просмотров:
    9.775
  4. roman5
    Ответов:
    56
    Просмотров:
    19.381
  5. roman5
    Ответов:
    5
    Просмотров:
    3.650
Загрузка...
Поделиться этой страницей
