PKT mod 7.0 Tideglo rev 0.7.0
valdemarich
Zmiany Tideglo
release 0.7.0
- fixed mute volume on channel change
- mute over SPDIF is now working
- added mp4 runtime detection
- added http mp4 streaming
- added m2ts file
- added stty
- added netstat
- added traceroute
- added grab for GUI screenshots (it does not work with live-tv screenshots)
- fixed many bugs on video drivers (don't remember all because most of drivers code were completly reviewed)
- applied better quality on video drivers (IMHO now on sd channels is really better than before)
- fixed many bugs on audio drivers (most of them on codec side)
- fixed (??) snr/agc value on tuners (especially in the sharp tuner)
- fixed bug on starting network at boot
- changed bootlogo with a new default
- reorganized general driver structures
- fixed subtitles *.srt and *.ssa when there is '.' char in the file name
- fixed time in the frontpanel (now should be always get the right value, with GMT offset, also at enigma2 boot)
- fixed a bug that causes DNS to be rewritten at reboot or at network restart when dhcp is activated on the router/net (if you have dhcp activated dns will be always given by dhcp server)
- fixed a bug that make dhcp always activated
- fixed record from standby
- fixed record from deep-standby
- fixed timer bug for record scheduled events
- fixed volume bug on web-interface
- fixed menu factory reset (thanks skaman)
- fixed panscan mode on almost all possible cases
- fixed audio volume on SCART wich was lower than HDMI
Zmiany PKT
+ rekonfiguracja domyślnych ustawień
+ ustawiono domyślny skin blackGlass-HD
+ dodane narzędzia do monitoringu temp. HDD
+ dodano Infocenter PKT (Menu->Informacja->Inf. o tunerze)
+ nowy mountmanager v0.7.2 (dynamicznie wykrywa urządzenia do zamontowania)
+ nowy emumanager v0.9.6
+ zastąpienie restartu tunera przez restart GUI po aktualizacji listy kanałow
+ poprawka dla montowania cifs
+ poprawka wizarda startowego
+ aktualizacja listy kanałów
+ aktualizacja media center
+ aktualizacja media player
+ aktualizacja fontów ->v6
+ aktualizacja spinera
+ aktualizacja plików systemowych
+ dodany plugin do zmiany spinera
+ bootloga do pobrania z pluginów
Pozdrawiamy
Polish Kathi Team
http://pkt.cal.pl/PKT/pub/PKT7.0/PKT_7.0_9000.tar.gz
http://pkt.cal.pl/PKT/pub/PKT7.0/PKT_7.0_910.tar.gz
http://pkt.cal.pl/PKT/pub/PKT7.0/PKT_7.0_900.tar.gz
http://pkt.cal.pl/PKT/pub/PKT7.0/PKT_7.0_91.tar.gz
nikolasi
Changes Tideglo
release 0.7.0
- Fixed mute volume on channel change
- Mute over SPDIF is now working
- Added runtime detection mp4
- Added HTTP streaming mp4
- Added m2ts file
- Added stty
- Added netstat
- Added traceroute
- Added grab for GUI screenshots (it does not work with live-tv screenshots)
- Fixed many bugs on video drivers (do not remember most of all because drivers were completly code reviewed)
- Applied better quality on video drivers (IMHO now on sd channels is really better than before)
- Fixed many bugs on audio drivers (most of them on codec side)
- Fixed (?) SNR / agc value on tuners (especially in the sharp tuner)
- Fixed bug on network starting at boot
- Bootlogo changed with a new default
- Reorganized the general driver structures
- Fixed subtitles *. srt, *. ssa, and when there is'. " char in the file name
- Fixed time in the frontpanel (now should be always get the right value, with GMT offset, also at Enigma2 boot)
- Fixed a bug that causes the DNS to be rewritten at reboot or at reboot network is activated when the dhcp on the router / net (if you have activated the dhcp dns will be always given by the dhcp server)
- Fixed a bug that make dhcp always activated
- Fixed record from standby
- Fixed record from deep-standby
- Bug fixed for timer record events scheduled
- Fixed volume bug on web-interface
- Fixed menu factory reset (thanks skaman)
- Fixed Panscan mode on almost all possible cases
- Fixed sound volume on SCART Which was lower than HDMI
PKT Changes
+ Reconfigure the default settings
+ Set the default skin blackGlass-HD
+ Added a tool for monitoring temperature of HDD
+ Added Infocenter Points (Menu-> info-> Inf a tuner)
+ New mountmanager v0.7.2 (dynamically detects the device to be fitted)
+ New emumanager v0.9.6
+ Replace the tuner restart restart the GUI after the upgrade list ŢдЗЙ
+ Patch for mounting cifs
+ Fix startup wizard
+ Updated list of channels
+ Updated media center
+ Updated media player
+ Update font -> v6
+ Updated Spiner
+ Update system files
+ Added plugin to change Spiner
+ Bootlog to download the plug-ins
http://uploadhyper.com/file/16121/PKT7.0900.tar.gz.html
http://uploadhyper.com/file/16120/PKT7.0910.tar.gz.html
http://uploadhyper.com/file/16124/PKT7.091.tar.gz.html
http://uploadhyper.com/file/16117/PKT7.09000.tar.gz.html
nikolasi
тормознутая она...что при старте что при переключении каналов.Базовая 7 шустрее работает и стабильнее
Добавлено через 2 часа 50 минут
А менюшку выбора каналов срисовали у меня-мой принцып:)Былабы польза...а вот полного скина пока не сделали:)
Lenina
Куратор "IPBox"
Уважаемые участники раздела IPbox, два дня назад меня попросили модерировать раздел. Предложение я принял. В связи с тем, что пока не имею достаточного опыта по управлению постами, прошу извинить, если какое-то время в ветке будут присутствовать два поста от разных участников с одинаковым содержанием или еще что-то подобное. Постепенно ветку почищу и оставлю одно из повторяющихся, которое поступило на форум первым по времени. Если что не так, пишите в личку.
N!CK
Как я понял каналы теперь лежат в папке /etc/enigma2/
greg
Может кто поправит громкость на кресте?
Кто может выложить этот софт на нормальный аплоад??? Скачать с того что есть невозможно.
kamig
Lenina
Куратор "IPBox"
yakimchuk
К сожалению нет возможности сравнить с оригиналом, а так разницы со временем загрузки с предыдущей версией я не заметил. К сожалению и та, и эта грузятся очень долго.
nikolasi
Когда увидим вашу, а если уже есть. то где можно взять?
Я не считаю что добавив просто свою блю-панель есть смысл выставлять свой релиз.Это может сделать каждый но толку с этого?Сиф рабртает над своей версией-полной.Когда будет собран полный софт получите для теста.Клавиши подправлю...вечером хотя сейчас работаю над другим.Будет сюрприз по крайней мере для форума ipbox.com.ua-все же это мой родной форум
Добавлено через 30 минут
думаю сегодня вечером кое-кто сможет потестиь:) новую Сиф
Sani0k
Что-то в этой версии у поляков глюк с ихними "фирменными" скинами,тормозит при переключении.на других вроде нормально:pardon:
Я заметил что РКТ все хуже и хуже , на 6.0 в зелень практически не выпадал. А на последних это ужас.
VadimIv
Дааа.. печально все это! Остаюсь на Iscan :(
Похоже с DGS сейчас подвижек больше (зашевелились корейцы)
P.S. Тьфу-тьфу-тьфу:)
