PKT mod 7.5 Tideglo rev 0.7.5
Lenina
Куратор "IPBox"
ivanko
PKT mod 7.5 Tideglo rev 0.7.5 USB and Flash for 9000,910 900,91HD
release 0.7.5
- added possibility to search channels by channel name's first letter, just press the remote button with the letter in the channel list
- fixed a bug on input box for remote controller keys
- added nc
- fixed some new memory leak bugs on drivers side
- updated enigma2 cvs 15/12/2009 (don't ask me all the change log, it's too big)
- added working subtitles remote button on live tv
- second recording should now be fine when starting while playback and another recording are active
- timeshift (or record + playback) should be more stable
- VCR scart connector now supports input signal, so you can connect other devices to the box and see automatically the TV signal when cuberevo is in standby or in deep-standby
- fixed WSS over 4:3 Scart connector, do not forget to set it in the A/V Configuration menu (let me know if it works good with TVs)
- updated to python 2.6
- added possibility to set Fan by menu (check CuberevoVFD in the plugin menu)
- added possibility to set brightness by menu (check CuberevoVFD in the plugin menu)
- added possibility to set clock in standby by menu (check CuberevoVFD in the plugin menu)
- added possibility to set led by menu (check CuberevoVFD in the plugin menu)
- added possibility to set scroll mode for channels name in the VFD by menu (check CuberevoVFD in the plugin menu)
- updated dreamTV-HD skin (IMHO now is a little bit cooler)
- fixed some VFD icons showing bugs, more need to be added
- fixed DVB subtitles where they were not allowed over some channels (like Universal Channel with Romanian subtitles, TotalTV and so on: report if now it works good)
- fixed a bug were enigma2 doesn't decode teletext pids on some channels (like Mega, Star, ANT1 in package Netmed: report if now it works good)
- udpated webinterface to last 23/12/2009 cvs
- fixed seeking from current position in avi
- fixed user audio delay in seeking
- enable seeking in mp4 files
Enjoy it! Tideglo
Ciao giopet===========WWW.MINICAT.TV
Lenina
Куратор "IPBox"
Поставил на 9000 на внешнюю флешку, почему-то у меня настройки сети слетают. А как у других?
P>S> А сегодня настроил, сеть сохранилась. Шрифты поменял для нормального отображения русского языка. Все бы ничего если бы не этот снег на HD каналах.
eugeny13
привет не открывает
ivanko
Прошу -подскажите- Какой адрес к фаворитам в этой ЭНИГМЕ. ===В 6.1 был -USR/LOKAL/SHARE/ENIGMA2====спасибо...
a2group
поставил на 910 флешь версию,при перезагрузке постоянно говорит что мало места на флешке и предлагает очистить( также неполучается шрифты изменить(
разобрался, нужно в настройках отключить Cleanup Wizard
VadimIv
Люди, не мучайтесь, ставьте Iscan-овский 809 на базе этого, почти все поправлено, а если нет Iscan с Nicolasi доведут до ума.
ipzam
flash версия
910 flash:
1) не получается изменить шрифты ( не дает переписать файлы в папке usr\share\fonts)? a2group у тебя получилось?
2) по кнопке i информация epg идет с отставанием в несколько часов, а по кнопке ОК все нормально? Часы, и пояс в норме.
3) Есть\будет ли Iscan-овский 809 для 910 flash?
dako
почему не видит ХДД на прошивке ПКТ мод Тиегло 0.7.5??? у кого нибудь получилось завести?
Lowik
Установил на флешку этот мод.
1. Сразу заменил шрифты (взял файл iscan-a enigma2-plugin-fonts-e2_1_sh4.ipk)
2. вэб-морда работает
3. внутренний HDD видит
4. по NFS все подключает
5. Не работает mytube-плагин - сразу зелень (проблема с одинаковыми портами http-сервера и плагина)
6. при пропадании интернета mgcamd133 восстановил соединение но на эране песок
7. иногда песок на HD-каналах, но лечится переключением с канала на канал. (смотрю только +++)
Lenina
Куратор "IPBox"
ivanko
Очки моделирование 7.5.1 Tideglo Rev 0.7.5
релиз 0.7.5
- Добавлена возможность поиска каналов по первой букве канала зовут, просто нажмите кнопку дистанционного с письмом, в списке каналов
- Исправлена ошибка в окне ввода ключа для удаленного контроллера
- Добавлен NC
- Исправлены некоторые новые утечки памяти ошибок на водителей стороне
- Enigma2 CVS Updated 15/12/2009 (и не спрашивайте меня все журнале изменений, это слишком большая)
- Добавлена возможность удаленного рабочего субтитры кнопки в прямом телеэфире
- Вторая запись теперь будет хорошо, когда начала воспроизведения во время записи другой и активных
- Timeshift (или запись + воспроизведение) должно быть более стабильным
- VCR SCART разъем теперь поддерживает входной сигнал, так что вы можете подключить другие устройства в поле и посмотреть ТВ-сигнал автоматически при Cuberevo находится в режиме ожидания или в глубоких ожидания
- Исправлены ВКХ над 4:3 разъем Scart, не забудьте установить его в A / V меню Конфигурация (дайте мне знать, если он работает хорошо с телевизорами)
- Обновление для Python 2.6
- Добавлена возможность установить вентилятор в меню (проверка CuberevoVFD в плагине меню)
- Добавлена возможность установить яркость в меню (проверка CuberevoVFD в плагине меню)
- Добавлена возможность установки часов в режиме ожидания в меню (проверка CuberevoVFD в плагине меню)
- Добавлена возможность создавать привели к меню (проверка CuberevoVFD в плагине меню)
- Добавлена возможность устанавливать режим прокрутки названия каналов в ПФО в меню (проверка CuberevoVFD в плагине меню)
- Обновлен кожи DreamTV-HD (IMHO сейчас немного охладитель)
- Исправлены некоторые ошибки VFD значки, указывающие на более должны быть добавлены
- Исправлены DVB субтитров, где они не позволили более некоторые каналы (например, Universal Channel с субтитрами румынский, TotalTV и так далее: новый доклад, если он работает хорошо)
- Исправлена ошибка была Enigma2 не PIDs декодирование телетекста на некоторых каналах (например, "Мега", звезда, ANT1 в пакете Netmed: доклад если сейчас она работает хорошо)
- Udpated Webinterface к последнему CVS 23/12/2009
- Исправлен поиск от текущей позиции в AVI
- Исправлено пользователем аудио задержка в поиске
- Включить в поисках файлов MP4
Наслаждайтесь этим! Tideglo
Изменения в Очки
- Все наши шкуры в конце концов хорошо работают (allienHD, balckGlassHD & infinityHD) - я надеюсь,
- Решена проблема с медленными каналами изменений и свободный выделите список каналов
- Решена проблема "wywalaniem" Media Player
- Добавлена панель информации в Media Player
- Добавлен менеджер программного обеспечения для архивирования собственные данные
- Другие изменения в skinach но я не помню, что
- Улучшена синхронизация времени с NTP-сервер (по умолчанию)
- Для продвинутых пользователей: добавлена возможность запускаться при загрузке Enigmy2, внешнего сценария pendriv'a (sdb1) znajdującegosię в корневом каталоге под именем: в начале, для, например, автоматически восстанавливать некоторые данные или сделать автоматическое архивирование, или что вы хотите.
ВНИМАНИЕ! Это версия 0.7.5 Rev Tideglo так что все недостатки, эта версия будет в этом тоже (читал аудио отсева, т.д.)
Angehängte Datei (EN)
910.tar.gz (39.77MB) Сайты загрузки: 2
91.tar.gz (39.71MB) Сайты загрузки: 1
900.tar.gz (39.77MB) Сайты загрузки: 2
chewbacca
Модератор "AzBox"
Изменения в Очки
зачем переводить электронным переводчиком и постить этот бред сюда?
не проще выложить в оригинале, люди найдут как перевести.
и где ссылка на мод?
