PKT mod 8.0 Tideglo rev 0.8.0
Lenina
Куратор "IPBox"
Zmiany Tideglo
release 0.8.0
- readded ipkg
- readded optional kernel modules (like external usb card reader, openvpn module and so on)
- readded rcS_user.sh file
- fixed some deadlocks
- CleanupWizard now checks stat on /var/
- updated arab language (credits go to yahya of cubebox board)
- fixed some audio bugs (let me know how the audio is now)
- added persian language (credits go to copol)
- fixed a bug on Unicable
- added by default pacco's sci drivers (so everybody will stops on claiming about this, i thougth it was not too difficult to add them)
- optimized scrolling text on the front panel display (no more blinking effect)
- fixed the menu harddisk manager (format, verify filesystem and so on)
- added channel number in the skin by default
- fixed teletext remote control button interceptor
- the "freezing bug", aka BUGGETTONE, now seems happening less than previous version because of a trick used (this doesn't mean
it is fullfixed)
- enabled PiP function (press red button then blue button, then press OK to select channels, you will enabled the PiP like every enigma2 box),
to use it with mgcamd for example just set boxtype value equal to 06 (this is tested and working for multi descrambling)
- added more compatibility with few mkv files
- fixed CI cams (broken since 0.7.0)
- fixed teletext bug for channel resize
- fixed image resize bug
- updated cutlist editor keymap
- fixed a crash of cutlist editor
- updated keymap for record and timeshift handling (record is managed with REC button, timeshift with PAUSE and STOP buttons)
- updated keymap for deleting backward and forward chars over all the input boxes
- fixed a bug when e2 crashes and teletext is active, at reboot was no more possible to use remote controller
- automatic switch on scart if enabled by "A/V configuration menu" is now working
- enable 12V output over the tuner by default (currently i was not able to fix the 12v option in the e2 menu)
- fixed some bugs on DVDPlayer (thanks skaman)
- fixed GMT time syncronization between enigma2 and front panel display
- added possibility to set in CuberevoVFD plugin panel the daylight and 12h/24h mode in the front panel display time
- solved a bug on enigma2 timers rebooting in a loop after deepstanby
- added BlindScan function (it will works only with Sharp tuner, the only one wich support blindscan, sold by default on all latest DGS stbs)
WARNING: currently the blindscan function is just a sample of how it would works, it must be completed, so i'm not interested in any bug report regarding it
Enjoy it! Tideglo
http://uploadhyper.com/file/23587/9000.tar.gz.html для внешней флешки 9000
http://uploadhyper.com/file/23595/910.tar.gz.html для внешней флешки 910
ivanko
А возможно ли этим модом актуализировать mod PKT 7.5.1 через ADONS. Спасибо...
Lenina
Куратор "IPBox"
Кто-нибудь может подсказать какие строчки и на что надо поменять в кеймапе чтобы громкость на кресте появилась?
N!CK
И тут проблема с временем. Ставлю ГМТ+2, но часы отстают на час
VadimIv
SifTeam Extreme RC1 - меня как-то вставила больше...
Какие-то непонятки с mgcamd... или бред какой-то в логе или ключи обновляются, но картинкии нет.
Но сильно не разбирался, бросил.
На сколько я понял они появляются после "Restart EMU"
Ждем 0.8.1... и Iscan что-то грозился сваять на базе 8.
N!CK
Не стабильная какая-то относительно таймера. То зависнет, то еще что-то....
N!CK
Вообще странная прошивка. С МЖкамдом глюк какой-то, эму коннектится с 127.0.0.1. Перепрошил заново, думал исправится. Так появился глюк с видеодрайвером. Клацаешь по каналам - он отваливается
koios
Хотелось бы по самбе видеть русские имена файлов, а для этого, как я понимаю,требуются вот эти модуля:
nls_cp1251.ko, nls_koi8-r.ko, nls_utf8.ko
вот только где б их раздобыть.....
nikolasi
С ядра линукса...Держите
  • Новая папка.rar
    4,2 KB · Просмотры: 52
igoron
Николаси а не подскажете как их подгрузить... я про языковые модули
заранее благодарен
koios
nikolasi,
Насколько я понимаю - не так все просто, эти модули должны быть под сборку линукса для sh4 и под вот такую именно версию ядра 2.6.17.14_stm22_0041.
И как следствие ваши модули пишут
insmod /lib/modules/nls/nls_cp1251.ko
insmod: can't insert '/lib/modules/nls/nls_cp1251.ko': invalid module format
