PKT mod 8.9 Tideglo rev 0.8.0
Lenina
Куратор "IPBox"
Changes in Points
- Bringing fashion to rev 0.8.0 Tideglo
- Patch for HD and similar phat
- The new driver 1.4 from Pacco for internal readers - does the card CP
- New F1 design fashion
- Two new skins:
PKT_F1-lite - displays less information thanks tuner works faster (default)
PKT_F1 HD - displays all the information
- Charging drivers to change the way readers (faster startup newcsa)
Ustawienia - > Auto TV Out" onmouseout="this.style.backgroundColor='#fff'">- The ability to change TV output when starting the tuner (similar to a firmware DGSA - click on the 'menu' on the front panel when starting the tuner) - BP -> Settings -> Auto TV Out
- Added Romanian language
- Fixed Finnish language
- Volume control right-left
- "Yellow" call to plugins
- Added support for Aspect Ratio of "green" for Media Player
- Update Picon
- Update the channel list
- Added a separate menu for Points Infocenter
- WebcamViewer - Update Camera
- Amendments of speed and code optimization
- Amendment to the GS in the absence of HDD
Regards Polish Team Kathi
WARNING! NOT LIABLE FOR THE USE OF THIS SOFTWARE, unlawfully, REMEMBER THAT LOOK PAY TELEVISION SUBSCRIPTION unpaid is a crime and be subject to imprisonment up to 3 years!
PS
Points Mod version 0.9.x will improve when Tideglo action polsatu HD channels
Ipbox 91: http://e2.pkteam.pl/index.php?dir=IMAGE IPBOX/Enigma2/8.9/&file=91.tar.gz
Ipbox 900: http://e2.pkteam.pl/index.php?dir=IMAGE IPBOX/Enigma2/8.9/&file=900.tar.gz
Ipbox 910: http://e2.pkteam.pl/index.php?dir=IMAGE IPBOX/Enigma2/8.9/&file=910.tar.gz
Ipbox 9000: http://e2.pkteam.pl/index.php?dir=IMAGE IPBOX/Enigma2/8.9/&file=9000.tar.gz
nikolasi
Ради интереса-кто-то ставил?Зы-похоже Игоря плагин перекочевал на поляков:)
homa100
может кто-нибудь переложить для 910 на другой обменник, по этой ссылке не могу скачать..
Lenina
Куратор "IPBox"
Вечером ради интереса хочу попробовать... Благо флешки есть.
Добавлено через 7 минут
Если с Оперой работаешь - переключи язык интерфейса на английский и попробуй заново - все качает.
N!CK
Залейте плиз куда-нибудь еще для 900. У меня по всем ссылкам во всех браузерах
Incorrect format for file ./languages/ru.txt on line 1.
Format is "variable name[tab]value"
nikolasi
в инет.эксплоуре зайди сервис-свойства обозревателя-языки.Там удали русский по умолчанию и все будет работать
Реакции: N!CK
