MaskaV
Enigma2 OpenSource SH4 Duckbox Project GIT-3052 PKT SVN-1248 HAARP v3 Image
Image is designed for installation in USB or SATA device
Support receiver: Kathrein UFS910
Added by sh4 Duckbox Team:
- fix optimize for size in stm24 and add it to ufs910 config
- [make/ffmpeg] - updated ffmpeg 0.6.1
- [eplayer3] playback aac-he streams with aac-lc
- fix timing problem in filepush
- [Player2 179/191] possible fix for chopped DTS sound on some files
- [e2 nightly-0]introduce 3D Mode for OSD ( paint OSD twice in Side by Side or Top and Bottom )
- [libeplayer3] support for OSD 3D modes for subtitles
- [libeplayer2, libeplayer3] Close directory file handles after looking for subtitle files
- [ufs910, stm24 205/207] fix cracking noise on cinch/scart
- new BusyBox 1.19.2 (stable) config and patches
- extend streamproxy to support linuxdvbapi5
- [player2_191/player2_179]resturucture dts fix. The fix now only applys to DTS streams and the playback time is only corrected on time differences up to 50ms this MAY fix some issues with async sound
- [USF912/UFS922] garbage displaying Polish UTF-8 letters on VFD fixed
- [player191] adoptions from p179; bugfix for 710x receiver (HD channel problems)
- [player2_191] fsynth bugfix
- fix ufs910 audio on scart
- use utf8 as python default
- adapt wrong page_offset and improve mem
Added by PKT:
- add new WebInterface v 1.6.7
- new function "live ecm" in infobar
- show Channel Number on Front Pannel + ON/OFF in setup menu
- upgrade CrossEPG svn 268
- fix qwerty VirtualKeyboard
- fix Backup/Autorestore function | LABEL=RECOVERY required
- fix channel number showing on VFD if long channel name
- set home directory to /root
- EPG description on channel list -> ON
- change reading of ecm.info
- new converters and skins modifications
- fix dimmer action when channel switch
- fix parsing PROV, CAID, PID
- moving EPG support to KeyMapper
- ReferencePKT optimization
- set PKTGoldHD as default skin
- fix CIFS mount if passwd is empty
- MPlayer fix GS of EOF
- upgrade formating device in Install Manager
- update API of MyTube based on last CVS source
- update EmuManager v1.0.6:
add sh4Cam support & gbox fix
- font FIX moved to Skin setup
- remove unnused files or BP menu settings modification
- fix showing processes
- res_emu in standby add in BP->Settings
- tune and fix sys_info
- add showing /Loaded modules/ in BP ->Menu ->System
- update WIFI scripts:
* add detecting of supported USB WLAN adapters
* user is informed about unsupported device
* optimize selecting WLAN driver
* optimize starting WLAN driver
- fix show event-progress in channel selection
- fix crossEPG
- PKT InstallManager 1.2.2
- PKT KeyMapper 1.5
- update Permanent Clock
- fix EMUManager russian translate
- add green button support in Media Player
- fix streamproxy after reboot
- Add Auto 3D Skin Switch by Dr.Best
- add support for fake cccam
+ change only in HAARP V3 version
- picons update
- added BPanel activation in MoviePlayer ( key blue )
- added compatibility to standard non PKTeams skins
- fix dot on VFD if channel number is not available
- fix for radio mode wallpaper
- fix showing picons on channels list, when are located in /hdd/picon folder
- added /media/usb/picon to picons search folders
- 2nd generation of speed up channels zap
- add standby smooth extingushing TV
- channel list update 28-10-11
- display quality improvement
- new BluePanel 2D v3.1.19 with graphic interface:
-- added function to check update is needed
-- added color & numeric keys actions support to immidiate plugin/function/menu activation
-- 1st row - keys: 1, 2, 3, 4
-- 2nd row - keys: 5, 6, 7, 8
-- 3rd row - keys: red, green, yellow, blue
-- added menu key action support
-- added changelog information menu
-- added synchronization of local time and date from NTP server
-- added on/Off the smooth extinguish TV while switching to standby mode
-- add Enable/Disable cardreader for 1008+ in Blue Panel (default: OFF)
- fix missing reference.dat
- [UFS910] add CAM Support in BluePanel (default: OFF)
- fix international fonts switch in Skin Setup
- add SATA Support for UFS910 (THX lamerek)
Regards
Polish Koders Team
http://www.2shared.com/file/MPUVuv1u/PKT_UFS910_E2_HAARP_v3_Image.html
Казется у полских друзеи проблеми с сервером и пока download отсюда.
У PKT открился новии раздел UFS910 на англииском и немецком.
engl65
Added by PKT:
- fix crossEPG
- PKT KeyMapper 1.5
- picons update
Regards
Polish Koders Team
Товарищ, а каким образом побороть недостатки польских имеджей в отношении русского языка. Читать невозможно эти каракули: нет буквы Ш, нет Й, в некоторых словах нет первой буквы Т. И как примонтировать расшариные папки на компе для просмотра на ТВ. Заранее спасибо.
aleks.62
И как примонтировать расшариные папки на компе для просмотра на ТВ. За ранее спасибо.
Редактировать файл cifs.conf. Находится здесь - /var/config/
Потом зайти в Mount Manager и нажать синюю кнопку. Там пояснение есть...
Работает...
Заменить шрифты. /usr/local/share/fonts/
Взять можно из энигмы AAF... Интернациональные видимо убрали...
P.S. Изменение кнопок. Звук и каналы как положено...
Сделано по аналогии с октагоном - http://forum.sat-expert.com/enigma/17897-imidzhi-ot-polish-kathi-team-obsuzhdenie-10.html
Менять здесь - /usr/local/share/enigma2/
  • keymap.rar
    2,4 KB · Просмотры: 66
freeols
Товарищ, а каким образом побороть недостатки польских имеджей в отношении русского языка. Читать не возможно эти каракули: нет буквы Ш, нет Й, в некоторых словах нет первой буквы Т. И как примонтировать расшариные папки на компе для просмотра на ТВ. За ранее спасибо.
Русский шрифт устанавливается так: 1-Синяя кнопка, 2-Skin Setup, 3-кнопка "EPG" -Fonts Fix и ждем когда установится из Интернета
omst
Хороший имидж - много красивостей, но откатился на первую версию; причина - начиная со второй поляки пофиксили cifs (по прчине доступа с пустым паролем).
Однако после этого русские названия файлов (cifs!) стали недоступными.
Может кто знает почему?
zaman
Быстрая прошивка. Элегантная. Тока в зеленку ее загнать - как два пальца.... :(
Grey_
Авторезолюшн у кого нибудь работает? Что то у меня ни на этой ни на второй версии никак...
VET1969
Что-то никак сетку настроить не могу. Указываю все как в бутарге - не пашет. Включаю DHCP - зависает с сообщением "пожалуйста подождите активации настроек вашей сети".
Как победить?
MaskaV
Смени язик на english,неужели так трудно запомнить все столетнии особенности PKT имиджеи на любом тюнере:нелюбовь к другим язикам,сколько раз можно наступать на одни и те же грабли.
Пока все не настроено,не менять язик.
VET1969
Язык не менял. Пробовал настроить сетку пользуясь мастером установки (с самого начала, при первом старте) - ничего не вышло, и потом, уже после выхода из всех мастеров, пробовал и из стандартного (меню, настройки, система, сеть) и через блю панель (интерфейс вызывается тотже).
Что только не настраиваю, нажимаю ОК для активации, спрашивает "вы уверены что хотите…", жму Йес, пишет Настройки активированы, тест не проходит, вхожу в установки адаптера User interface - No. Фигня какаято нездоровая. Но ведь у всех работает!
Рестарт нетворк ничего не дает.
Так, порылся в настройках - похоже мак адрес слетел. Видать ошибся при установке. Наверное в этом дело. Завтра уже поменяю, спать нужно.
Проверил. МАК в бутарг прописан корректно, но Нетворк Тест из Блю панели говорит INVALID MAC: FF:FF:FF:FF:41:40; дальше IP, Mask & Gate - пустые. В общем - активизировать проводной интерфейс так и не удалось.
Язык интерфейса стоял и стоит английский.:unsure:
axe16
Enigma2 OpenSource SH4 Duckbox Project GIT-3285 PKT SVN-1348 HAARP v3c Image
Image is designed for installation in SATA/USB device
Kernel stm24-207
- new BusyBox 1.19.3
- [stmfb] fix wrong alpha behaviour
- [tuxtxt] add freezer work on hd
- update: boost 1.48.0 and ffmpeg 0.8.7
- update: curl v7.23.1
- [player191] readd orfhd sound fix
Added by PKT:
- add sh4Cam support & gbox fix
- fix crossEPG
- PKT KeyMapper 1.5
+ change only in HAARP V3c version
- picons update
- new BluePanel 2D v3.1.21 with graphic interface:
- screenshot OSD fix
- fix GS on GlassHD skin
- upgrade e2 to 2011-09-13-experimental
- fix exception on hddtemp running on box with no sata port
- fix GS in TimeShift path Menu
- fix sata HDD sleep in standby
- add new Webinterface v1.6.8
- add WebMedia 4.0
- add new Multimedia items in BP
- fix firmware update checking
- [ALL] extinguishing fix
- [ALL] MediaPlayer GS fix - RuntimeError
- [ALL] fix crash system after Factory reset
- [ALL] probably sleeping hdd fix in standby
- [ALL] set default highSR=OFF
- [ALL] fix Left/Right Key action in KeyMapper
- [ALL] add % loaded e2 process while BOX have VFD display
- [ALL] fix exit from CutListEditor
- fix SATA Support for UFS910 (THX lamerek & B4Team)
FTP login: user: root, passwd: pkteam
http://www.2shared.com/file/iKOAo_EZ/PKT_UFS910_E2_HAARP_v3c_Image.html
Andrew-69
Поставил этот имидж, все настроил, включая ш..ру, но возникла одна проблема: при выключении в ждущий режим и последующем включении Кати изображение появляется как-бы в негативе, все темно и никак не исправляется, только как перезагрузкой ресака. Кто поможет?
dortmundez
1 - а что поляки больше не делают имидж для внутренней флеш?
2 - что можно поставить сегодня во внутрь из е2 чтоб эмуль тоже влез?
(титан не предлогать)
Satti
по моему это MME-V2, внутрь легко влазит эмуль, ключи, мидиаплеер, скин HD, подняв частоту процессора до 300 мгц наблюдается стабильная и шустрая работа без swap-флешки, после установки я удалил: все лишние языки, скин пикон дэфаулт, медиацентр.
dortmundez
да я его установил но фида нету - нет возможности скачать mgcamd
где качнуть можно для установки руками если нельзя с фида?
omst
Конец цитаты.
Так:
-синяя кнопка - System-Standby Mode-Extinguish - и - Deacivate.
Satti
лови, раскидай по папкам и будет тебе счастье :)
P.S. если файлы с архива позакидать, но медиацентр оставить то не хватит места во внутренней флеши
  • Flash-MME-V2.rar
    893,4 KB · Просмотры: 52
