PKT UFS912 Enigma2 Nibiru Image
metalzavod
Для Kathrein UFS 912
Enigma2 OpenSource SH4 Duckbox Project GIT-1916 PKT mod SVN-689 Nibiru Image
Image is designed for installation in a flash memory.
Before installing - updatescript must be loaded.
Added by sh4 Duckbox Team:
- stv090x/stv090x.c optimize snr/ber
- [libeplayer3] fix blocking at end of file
- [eplayer3] add mapping for ff and fr
- [libeplayer3] fix fast reverse begin of file
- [libeplayer3] fix audio output with fast reverse
- [libeplayer3] fix .srt subtitle, seg fault if subtitle line is empty
- [libeplayer3] fix reverse
- [libeplayer3] change fast reverse to show the first frame on bof
- [libeplayer3] fix fast reverse loops
Added by PKT:
- add support for FTDI & PL2303 in BP Menu
- add EPG saving
- add CrossEPG 0.6.1 (default off; Enable/Disable in BP->Settings->CrossEPG; main CrossEPG setup Menu->Setup->CrossEPG)
- add WIFI support RT3070 & RT2870 Drivers [BP->Setup->WIFI]
- add RT73 WIFI support (test only - propably not work)
- add DVDPlayer
- add record & timeshift patch @ Main Menu->Setup
- add EPG recovery even if new image is loading to flash (This function work only with PKT Image >= SVN-689 and next releases. Before flashing Image by Emergency procedure restart in Main Menu is required to restore EPG)
- update InfocenterPKT
- update PKT Emu Manager v1.02
- update PKT Skin Setup
- add VidBrowser to MediaCenter
- update all PKT Skins
- add PKT ChannelControl (new tool to adjust volume separately on selected channel)
- add PKT_KeyMapper (new tool to mapping Color buttons):
default keys definition:
*short key_red=Radio
*short key_green=Aspect Ratio
*short key_yellow=Audio Selection
*short key_blue=Blue Panel
*long key_red=Channel Controle
*long key_green=Screen Saver
*long key_yellow=Skin Setup
*long key_blue=Emu Manager
Known Issues:
- SCART not work
с официального сайта - загрузка
альтернативная ссылка - загрузка
file.php
2wladi
Поделитесь опытом создапия SWAP.
Все перепробовал но не в какую : актуализировал до версии 691, проделал все вменю но SWAP не появляется
yavor1
в блу панеле попробовал?
2wladi
Да все перепробовал, если я правильно понял SWAP можно создать на физическом носители к примеру УСВ
УСВ форматировал ФАТ32 обозвал SWAP, но нив какую
А вы не пробовали Получилось ли
Имедж не плохой время переключения и старта можно сказать прима
