Q-Box HD - Linux Enigma2 Triple HDTV tuner box
tolik501
No more waiting for the Dreambox 8000
Diablo CAM manufacturers of exclusive available starting in December!
Q-Box HD - Linux Enigma Triple HDTV tuner
With the QBox HD presents the European manufacturer Duolabs a new Linux HDTV tuner Triple ENIGMA 2 set-top box to the top class.
First, all major multimedia hardware components (HDTV HDMI, WLAN, LAN, USB host / client, HDD-Intern/Extern) with the best satellite hardware components (Tripple tuner, 2 x Common Interface, 2 x card reader and Diablo CAM built-in) united.
With this equipment may be operating on course Linux is not missing! Here comes the best user ENIGMA 2 to use.
Thanks to the STI 7101 266MHz processor with Enigma 2 are all standard plug-ins Dreambox compatible HD Series.
The Q-box HD has 2 DVB-S2 HDTV tuner and optional addition of a DVB-T or DVB-C tuner.
The integrated wireless module supports a transmission speed of up to 300Mb/sec.
The digital video stream living are thus no longer hurdles in the way.
The multimedia player supports the formats already DIVX, FLV (Youtube format), MP3, JPG.
A DVD or Blueray can connect through the USB interface and hard drives can be incorporated both externally via USB connected.
Obviously was not saved on internal memory. For the firmware is 1 GB of memory available, with 128 MB of RAM and an extra Safe 8MB memory bootloader security.
Furthermore captivates the QBox HD High Resolution TFT through the front display with 2.2 inch and 65536 colors.
- 266 MHz ST40 CPU SH4 Core. STi 7101 based.
- Linux Operating System
- Linux DVB-API compatible.
- 2,2” TFT high definition Display
- WiFi - 802.11n. Stand-Alone internal Module
3 Antennas. WEP/WPA/WPA2 supported.
- 2 x Common Interface Slots
- Ethernet 10/100 MBit compatible interface
- MPEG-2 / H.264 Hardware decoding
- Tuner: DVB-S2, DVB-C, DVB-T
- 3 x Tuner Module Input - Plug&Play
- 2 x Smartcard-Reader ISO 7816-3 with programmable clock speed
- V.24/RS232 Interface
- 10/100Mbit Ethernet Interface
- 2 x Scart (RGB, FBAS or S-Video)
- HDMI Output
- 2 x USB 2.0 external USB
- 1 x USB 2.0 internal for FileSystem
- S/PDIF Interface for digital bit stream out (AC-3)
- 8 MByte NOR for Secure Bootloader, 128 MByte RAM
- Internal SATA for PVR
Use either as internal SATA HDD 2,5“
- unlimited channel lists for TV/Radio
- EPG (electronic program guide)
- multiple LNB-Switching control (supports DiSEqC)
- OSD in many languages and skin-support
- Videotext Decoder
DVB-S2 Tuner:
Frequency Range 950 .... 2150 MHz
Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
DVB-S2: 10 – 31 Mbaud/s (8PSK) , 10 –30 Mbaud/s (QPSK)
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible, H.246
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Capable Resolution: (1080I, 720P, 480P/576P, 480I/576I)
Audio decoder:
Audio Compression MPEG-1 & MPEG-2 Layer I and II, MP3
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, RGB, S-Video
Serial Interface RS 232:
RS232 bidirectional
BitRate 115,2 kBit/s max.
Plug Connector SUB-D-9
Function: Update of Firmware
Ethernet:
SATA Interface:
For use either as internal HDD 2,5“
USB
2 x USB 2.0 Host
1 x USB 2.0 Host Internal Slot for USB stick to hold the Firmware.
Count of active satellite positioniSEqC 1.0/1.2 SAT POSITION / SAT OPTION
DiSEqC - Rotor Control
Power Supply:
Input:
110-240V AC / 50-60Hz / 0,6A
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H):370 mm x 230 mm x 60 mm
Weight: 2,5 kg ca without HDD
Price: 479.90 Euro
http://www.dreamboxonline.com/forums/showthread.php?p=68997
http://www.satmedia.at/s_product_detail.php?pr_idr=1393&grpname=QBox HD Linux Enigma2 Tripple Tuner
Igool
Очень привлекательное предложение. При достойной софт поддержке- прекрасная альтернатива Dreambox DM8000. Не забываем, что они оба могут работать на Enigma2.
Большое разнообразие в цветовой гамме
[URL=http://imageshack.us] [/URL]
Выход на рынок немного перенесен. Обещали 7 января.
Сайт производителя с подробным описанием возможностей
