Редактор каналов
janigor
Свежая версия редактора каналов:
http://forum.sat-expert.com/downloads.php?do=file&id=79
Changelog PCEditor 1.2.46 Beta 6a:
- Fixed: Crash when drag/dropping channels
Changelog PCEditor 1.2.46 Beta 6:
- Fixed: Pasting cable channels set the wrong QAM value
- Fixed: In-place-editing of cable transponders set wrong data
- Fixed: Adding favorites to favorite groups didn't set the sequence according to image favorite behaviour
- Fixed: Showing QAM value for cable transponders
- Fixed: Only appropriate Satellites are shown when in-place editing satellites
- Fixed: When editing transponders/satellites only the appropriate satellites for a channel are shown
- Fixed: After creating HD channels, they were shown as SD channels
Plus a few more minor fixes
janigor
Редактор каналов:
Changelog PCEditor 1.2.46 Beta 7:
- New: Support for CubeRevo-Mini
- New: Removed Non-Unicode version
- Fixed: SatcoDX import from generated SatcoDX files
- Fixed: Sometimes existing satellites were not shown in LNB Edit
- Fixed: Missing short name for channels when manually creating a new channel
- Fixed: Deleting duplicate channels was impossible when using SID as criteria
- Updated: PCEditor now supports SQLite databases up to version 3.5.8
- Updated: Database satellite/transponder data for creating new database R5929
Plus a few minor fixes
http://forum.sat-expert.com/downloads.php?do=file&id=92&act=down
janigor
Редактор каналов:
Changelog PCEditor 1.2.46 Beta 8:----------------------------------------------------------------------------
- New: Support for next database revision R7052
- New: Create new database R7052
- New: Update database R5929 to R7052
- New: Flash CubeRevo images from hard disk
- New: Sorting and grouping by second column for CubeRevo
- New: Turkish language file
- Fixed: Import of SatcoDX files version 103
- Fixed: Some HD channels were not shown in PCEditor
- Fixed: When drag/dropping channels, channel number is automatically updated now
- Fixed: Value for "Dolby Default Out" was not saved
- Fixed: When creating all_noboot backups, only kernel_root backups were created
Remarks
As there is not enough space left in "/tmp" on the CubeRevo/AB9000 HD for flashing
all_noboot or kernel_root_db images, the image now can be copied to hard disk. Flashing is
started from hard disk then. To achieve this, tick the checkbox "Flash from Hard disk"
in the flashing dialog.
The channel list for the CubeRevo/AB9000 HD can now be sorted by two columns. If you
want e.g. to sort by provider and then channels within the providers, click on the
provider column. Then hold the CTRL-key and click on the channel name column (service).
http://forum.sat-expert.com/downloads.php?do=file&id=99
janigor
Новая бета, под новую ревизию базы каналов в новом софте, который выйдет на днях
Changelog PCEditor 1.2.46 Beta 9:
- New: Support for database revision R7329 (IPBox 9000/CubeRevo)
- New: Update database R7032 to R7329 (IPBox 9000/CubeRevo)
- New: Create new database R7329
- New: CSV export files now have consecutive numbers in file name
- New: Channel switching via PCEditor for IPBox 9000/CubeRevo
- Fixed: Question about platform type when creating database R5929
- Fixed: Wrong channel numbering when importing SatcoDX files
- Fixed: No radio favorite groups when importing Dreambox channel list
- Updated: Polish language file
http://www.pceditor.de./download/Setup_PCEditor_1.2.46_Beta9.exe
janigor
http://pceditor.de/download/Setup_PCEditor_1.2.46_Beta10.exe
Changelog PCEditor 1.2.46 Beta 10:
- New: Support for database revision 7934 (Image Revision 8022 or later)
- New: Update database R7327 to R7934
- New: Settings entry for Power Mode (in HDD settings)
- Fixed: Wrong FEC data for IPBox 9000/CubeRevo when editing transponders
- Fixed: Select modulation and transmission for IPBox 9000/CubeRevo when editing transponders
- Fixed: Crash when dropping a favorite at the end of the favorite list
daniel10
Ребята,подскажите пожайлуста в чём может быть проблема.Не могу закачать каналы в рессивер через PC Editor последней версии.В комп каналы заливаются,а обратно выдаёт ошибку типа ilegal port 500 что то в этом духе, табличка по средине экрана.Раньше пользовался старой версией Editorа и тоже такая проблема была но не сразу появилась.Пару раз я заливал каналы через Editor вроде всё было нормально.Настройки никакие нетрогал.Помогите что нужно зделать,а то надоедает после смены имиджа постойнно каналы заново инсталировать да мотор настраивать.Может в компе что подправить надо?Уже незнаю на что думать.Не с того,не с сего слетело эта функция???Понятия неимею почему.Здесь кто то уже писал по этой проблеме,да найти чё та немогу.Выкладывали и скрины тоже.
Заранее Спасибо.
daniel10, у меня похожее вчера было , отключи файервол и все ОК
daniel10
Зделал.Не помагает.Та же история.
Он пишет что то типа база данных не сохронена.
janigor
1) Попробуй заливать файл списка каналов, который находится неглубоко в директориях и в названиях папок нет русских букв.
Например bp gfgrb: C:/channels/db520.dat
2) Попробуй заливать базу не открывая ее предварительно в редакторе.
File->Download DB-> выбор локального файла
daniel10
Привет janigor!
Разные способы перепробовал пока чё та нечего невыходит.Но меня смущает ещё одна вещь в настройках.Какие настройки должны быть выполнены например в Tools?И какие настройки должны быть в Export/Import? Может тaм чего то нетак?
Спасибо за помощь.
janigor
Есть там параметры в Options, правда я не знаю точно зачем они поскольку развернутой инструкции по редавтору просто нет. :(
Просто попробуй выставить там Set DynDNS - твой ресивер.
- New: DynDNS support for backup, flashing and upload/download channel database
- New: Menu DynDNS in menu "Options" for quicker switching to DynDNS mode and back
И в опциях Channel switching mode - тоже выстави свой ресивер.
- Fixed: Channel switching mode for Relook 400s now works with username
and password. (See Settings | Relook 400s for username and password.)
тоже не знаю зачем этот параметр :(
daniel10
Спасибо janigor! Но нечего не помагает.Уже незнаю на что думать.С реса каналы скачиваются, а обратно некак.В настройках я нечего нетрогал.Значит комп.Видно какие то апдейты прошли которые чё та,где та блокирнули.Обидно.Теперь особо с имиджами непоэксперементируешь.Потому что нужно будет постоянно настраивать мотор и каналы инсталировать.
Спасибо за помощь!
krycek
Не факт. Я например с обоих компов попробовал - и та же история, а у меня отродясь никаких файерволов и антивирусов не водилось за ненадобностью. Так что видно просто издержки кривизны этой софтины, ибо она фактически ничем особо не отличается от такого же глюкавого редактора для первых Мутантов(=Reelook'ов), разве что стала русский более-менее понимать, а вот с коммуникациями как были галюны немеряные, так и остались.!bad!
Ну, тут я твой пессимизм совершенно не разделяю, ибо что тебе мешает взять и закинуть отредактированный DB-файл в ресивер просто, вручную, по FTP? Лежит он в ящике по адресу var/db.dat , так что сие отнюдь не есть проблема.:pardon:
Да и вообще, не стоит ИМХО особо напрягаться по данному поводу, потому как не сегодня-завтра зарелизят уже официально анонсированную Энигму и как говорится, поверит чукча в счастье на земле :yahoo:
janigor
JonDoe обещал на днях выпустить версию редактора с уже пофиксеной выгрузкой списка с ресивера.
Danim
Обьясните каким образом редактируются каналы в ресивере? Софт 8107.
В меню "Редактирование транспондеров и каналов" есть опция "редактирование спутников и транспондеров" А где функция редактирования каналов? Как выйти на редактор каналов?
Viraje
Скачайте сначала с ресивера базу данных, а потом редактируйте в TV Channel Edit.
Danim
Спасибо за ответ.Печально что в софте ресивера нет редактора каналов.
На п.к косить более 4_ёх тысяч каналов занятие не из приятных.
Может есть смысл сбросить в заводские установки? Эмулятор при этом слетит или нет?
janigor
Danim,
Все есть, прочитайте инструкцию.
Нажмите ОК, для вызова списка каналов, а затем кнопку i.
появится возможность удалять, перемещать и т.д.
Но, на компе это все делается намного быстрее. :)
Danim
При покупке ресивера в упаковке отсутствовала инструкция. Спасибо за подсказку.На компе редактировать каналы можно при наличии такового. Данный ресивер брался родственникам и в случае чего тягать к ним каждый раз комп (или от них ресивер) не совсем правильное решение :)
Viraje
Инструкции на форуме выкладывалась уже не раз!
Для 900 - http://rapidshare.com/files/152110745/900HD_RUSw.rar.html
Для 9000 - http://rapidshare.com/files/146619303/9000HD_RUSw.rar
А редактирование в ресивере неудобно не потому что это Айпибокс, а вообще в любом, просто намного дольше, чем софтовым редактором!
