Релизы Е2 от АВСОМ для IPBox 99xx
janigor
Е2 для 9900:
Е2 для 99:
Аддон для Е2 для 99хх:
Русская инструкция:
[/HIDE][/HIDE]
nikomar
IPBox 99HD релиз 101011
http://abipbox.com/?file_id=30
AB IPBox 9900HD & 9900HD Plus
http://abipbox.com/?file_id=31
Changelog:
- uboot - bootargs for mutliboot
- enigma2 - add off/on fan by standby
- busybox - add tar with j and z
- rootfs - add fw_printenv, fw_setenv for change bootargs
- in deep standby only power LED lights
Добавлено через 23 часа 30 минут
релиз r101012
AB IPBox 99HD
http://abipbox.com/?file_id=32
Changelog:
- fixed bugs when tuner and channel list were not set up in wizard
- fixed allinone panel
- fixed swap manager
http://abipbox.com/?file_id=33
janigor
Enigma2HD_r101012 for AB IPBox 99xxHD
Changelog:
Known issues:
- DVB-C tuner not supported yet
- Irdeto cards not working yet
- HE-AAC audio not working yet
Релиз появился и на их аплоаде
nikomar
Enigma2HD_r101022
Enigma2HD_r101022
Changelog:
- based on python 2.6
- supports playback of more video formats than before
- fixed restoring of backup system
- fixed more small bugs
Known issues:
AB IPBox 99HDhttp://abipbox.com/?file_id=34
AB IPBox 9900HD & 9900HD Plushttp://abipbox.com/?file_id=35
Добавлено через 2 часа 30 минут
IP99HD_e2hd_r101022_USB
http://www.ab-forum.info/download/file.php?id=29451
IP9900HD_e2hd_r101022_USB
http://www.ab-forum.info/download/file.php?id=29452
НУЖНА РЕГИСТРАЦИЯ!!!
nikomar
релиз 101116
AB IPBox 9900HD and AB IPBox 9900HD Plus e2hd 101116 Flash version
AB IPBox 9900HD and AB IPBox 9900HD Plus e2hd 101116 USB version
http://abipbox.com/tips-downloads/downloads-ab-ipbox-9900hd-and-9900hd-plus
AB IPBox 99HD e2hd 101116 Flash version
AB IPBox 99HD e2hd 101116 USB version
http://abipbox.com/tips-downloads/downloads-ab-ipbox-99hd
Enigma2HD_r101116 for AB IPBox 99xxHD
Changelog:
- new keymap.xml (now works "Stop" button to stop playback file from HDD via "Files" button)
- used newer version of gcc-4.2.4 = more free space in flash memory (around 1MB)
- added function: in standby mode Enable/Disable display (Menu/Setup/System/Customize/Setup mode - Intermediate - in line Enable Display in Standby)
- fixed bug: by pressing pause on playbacked file from HDD box restarts itself
- added function: wakeup box when Timer recording in stanby mode is set up (Menu/Setup/System/Customize/Setup mode - Intermediate - in line Wakeup before recording - yes)
- added function: wakeup box when Timer recording in Deep stanby mode is set up (This happens automatically, when deepstandby timer recording is preset, display is enabled in deepstandby)
- added ntp time
Known issues:
janigor
Enigma2HD_r110211 for AB IPBox 99xxHD/55HD
Changelog:
- added in software manager upgrade
- added internet update function
- fixed backup/restore image (now works on USB-FAT32)
- added VLC streaming live channel (only SD channels)
- fixed CIFS mount (нужно проверить)
Known issues:
- DVB-C tuner not supported yet (хреново)
Nikolayevih
Установил последнюю Е2 от АВ, все нормально. Но черт дернул установить плагин enigma2-plugin-extensions-dvdplayer_1.0_all.ipk, телнет выдал какую то ошибку (не успел прочитать, что то про винт) и из меню пропала вкладка плагины.
Nikolayevih
Так распакуй его на винт 7-ZIP-ом и посмотри куда он там что прописывает и что меняет.
Обновление Е2
Menu - Setup - Software management - software - update
new cardreader driver - add nagra3, irdeto,...
После обновления пропала вкладка плагины.
