RTi Core 1.2 MOD by Darkmantk v2
Core RTi 1.2_E2_Backup.MOD by Darkmantk
E2_AZbox backup
MOD 1.2 by RTi Darkmantk Core v2
Changelog:
-LatestDrivers-
Fix-WLanFix DVI (premium and premium +)
-StreamingFix-MediaCenter0.3.1-RTiSoftwareInstaller
- FIX CAMD Manager
-FullScreen-VideomodeAuto Changesin changed to shoutdown menu
FIX-NetworkBrowser
Pingflood in skin-Keymapby AzConcinnity-HD (Default)
-MyTubePlayer19/08/11- AzExplorer - ipkg build tools
-TechsatKeyDownloader-Channellist (DTT USA, Astra19.2E, Hotbird13E)
HD-Skin Glass16 installed as optional
-Glasssysutil
Well as promised, I brought my full backup with everything I have I got to the RTi 1.2
I recommend that you back up the folder / etc/enigma2 as it is where you store the configuration settings and channel lists. And then if you want to put them in the backup.
Bring CCcam installed as standard, but is only configured for Techsat.
Some things I could not test because my deco is Elite model, but are caught GIT files for example if the WLAN operates in the GIT version should work fine here too.
The image has nothing to do with Spaz and unique plugin does not bring any of that image, we're working on it but when the time comes that I see the light of the RTi fixing things.
I modified the manual that created the RTi to explain how to install the AzUP Firm, now it will not leave the ext4 option because the current kernel does not support that format.
NOTE: This new version is heavier and I have incorporated the Skin Glass and Glass HD 16 Utility Sys and occupy these two enough memory for those who do not want these extras either the skin or the utility sys, or both will explain how must do to uninstall them.
Uninstall HD Glass Skin 16
For telnet write this:
Code:
ipkg remove enigma2-skin-hdglass16-3.16Desinstalar Glass Sys Utils
Code:
ipkg remove enigma2-plugin-glasssysutil-3.77Recuerda that if you uninstall the Skin put before another default. The image brings the default skin AzConcinnity-HD. But I added this because there is enough people who like to use it.
DOWNLOADS
http://www.multiupload.com/NL1W1V6G00
http://www.megaupload.com/?d=2VPLJZ0I
Добавлено через 2 часа 22 минуты
намудрили с CAMD Manager не запускает не WiCard 1.08 не OsCam 18.17.
заменил на CAMD Manager от v.1.2 и всё заработало.
цвет пропадает (scart)
E2_AZbox backup
Changelog:
-LatestDrivers-
- FIX CAMD Manager
FIX-NetworkBrowser
-Glasssysutil
Code:
Code:
DOWNLOADS
