Софт(ПО) и программы для AB CryptoBox 7ххHD
janigor
  • 700HD_V1.14.20433_09-05-2018.7z
    4,1 MB · Просмотры: 9
tmmillena
Здравствуйте. Нужен софт с поддержкой Eutel Sat 36 для тюнера CRYPTOBOX 752 HD COMBO
janigor
Альтернативный софт
CR_7xxHD_V1.14.21452_25-02-2020
- Youtube OK
- Youporn OK
- Redtube OK
- Radio OK
- after uploading, restore the factory settings !!!
- activate emu ... X-tras - 0000
- activate Youporn - 0000
- upload from a cfg file or enter data for newcam servers, cccam through the IP Tuner browser: 9999
- upload channel list (the list available from FTP does not save the FAV group names after uploading, you must give the name by remote control)
ПС Не проверял ютюб за неимением ресиверов
  • CR_700HD_MINI_V1.14.21452_25-02-2020.rar
    4,3 MB · Просмотры: 5
  • CR_700HD_V1.14.21452_25-02-2020.rar
  • CR_750HD_V1.14.21452_25-02-2020.zip
    4,4 MB · Просмотры: 8
  • CR_752HD_V1.14.21452_25-02-2020.zip
    4,7 MB · Просмотры: 25
janigor
Альтернативный софт
CR750HD/CR752/CR700/CR700Mini_V1.14.21772_09-05-2020
- Youtube OK
  • 700HD_MINI_V1.14.21772_09-05-2020.zip
    4,2 MB · Просмотры: 2
  • 700HD_V1.14.21772_09-05-2020.rar
    4,1 MB · Просмотры: 5
  • 750HD_V1.14.21772_09-05-2020.zip
    4,3 MB · Просмотры: 1
  • 752HD_V1.14.21772_09-05-2020.rar
    4,6 MB · Просмотры: 11
janigor
Альтернативный софт
AB CryptoBox 750HD_V1.09.21903_19-06-2020
  • AB CryptoBox 750HD_V1.09.21903_19-06-2020.zip
    4,3 MB · Просмотры: 0
janigor
AB CryptoBox 750 HD 16M V 1.09.21936 06/29/2020 - test
- alternatywny soft_patch
The ability to record playlists in the receiver's memory has been added.
Increased number of recorded IPTV channels
To download, create an IPTV folder on the flash drive and write the playlist in m3u format there.
We connect the flash memory to the receiver and press the "Page +" button, select the list and click "OK".
You can switch between lists by pressing the "TV / Radio" button.
It should look like this: - TV list - Radio list - IPTV list.
  • AB CryptoBox 750HD_16M_V1.09.21936_29-06-2020.rar
    4,3 MB · Просмотры: 2
janigor
  • AB CryptoBox 750HD_Patch_V1.15.21964_23-7-2020.zip
janigor
CR752HD_V1.14.22066_03-08-2020
- alternative SW
  • 752HD_V1.14.22066_03-08-2020.zip
    4,6 MB · Просмотры: 12
janigor
CR700HD/CR750/CR752_V1.15.22010_03-09-2020
- alternative SW to test
  • 700HD_V1.15.22010_03-09-2020.zip
    4,1 MB · Просмотры: 6
  • 750HD_V1.15.22010_03-09-2020.zip
    4,3 MB · Просмотры: 7
  • 752HD_V1.15.22010_03-09-2020.zip
    4,6 MB · Просмотры: 18
janigor
Альтернативный софт
  • 700HD_V1.15.22438_22-01-2021.zip
    4 MB · Просмотры: 2
  • 700HD_MINI_V1.14.22438_22-01-2021.zip
    4,1 MB · Просмотры: 0
janigor
Вот отзывы по последним софтам :mad:
Po nahrání tohoto posledního testovaciho FW mě přijímač nenabíhá a vždy když už to vypádá že najede na obraz,tak se hned vypne do Stand-by.A tak pořád dokola. Když ale při nabíhání mačkám tlačítko exit, tak najede.Když se zase rozhodnu po najetí přijímač vypnout červeným tlačítkem na ovladači do stand-by módu, tak poté mě začne zase dokola bootovat.Po nahrátí jsem samozřejmě dal tovární nastavení. Nevím teda jak ostatním, ale vracím se o pár verzí zpět.Jsem spokojený s verzí 752HD_V1.14.21772.S touhle verzí mě připadá přijímač takový svižnejší než s těmi posledními verzemi.
Cryptobox 752HD.
После загрузки последнего тестового софта мой ресивер не загружается. Когда должно уже появиться изображение ресивер переходит в стендбай. И так по кругу. Но если при запуске ресивера нажму кнопку exit, то он запустится. Если захочу выключить пультом в стендбай, то снова начинает ресивер перегружаться по кругу.
Cryptobox 752HD.
Tiež pozorujem, že po vypnutí prijímača opäť sám znova nabootuje. 750HD.
Также при выключении ресивера он сам снова запустится.
janigor
AB_CryptoBox_75xHD_V1.15.22455_04-02-2021.bin
Changelog EN:
  • Fix - CAMs work again
  • Fix - STB wakes up from deep standby
Исправленные версии.
ПС
Если ресивер в стендбае и пропадает электричество, то при появлении электричества ресивер запустится. Ранее в таких случаях ресивер возвращался в стендбай.
  • AB_CryptoBox_752HD_V1.15.22455_04-02-2021.rar
    4,5 MB · Просмотры: 7
  • AB_CryptoBox_750HD_V1.15.22455_04-02-2021.rar
    4,2 MB · Просмотры: 5
