Sunray4 DVB-S2+DVB-T+DVB-C+Wi-Fi (клон Dreambox 800SE)
allllex
Китайцы выпустили новую версию клона DM800SE.
В основном это тот же клон обычного DM800SE, но с изменениями:
DVB receiver Sunray4 DM800 se SR4
Tuner:Three-in-One DVB-S/C/T, Tuner can be used at the same time.
Powerful receiver for digital TV and Radio programs.
Main features are a 400 MHz processor the DVB receiver 800 HD se supports the Linux TV API
Have a look to HighDefinition TV on your DVB receiver
•10/100MBit compatible Ethernet Interface
•HDMI connector
•plug & play Tuner
•colored OLED display
•plug & play slot for an internal 2,5" SATA hard disk
Technical Features
• 400 MHz MIPS Processor
• Enigma 2, Linux Operating System
• colored OLED - Display
• MPEG-2 / H.264 Hardware decoding
• Tuner: DVB-S,DVB-C, DVB-T
• Tuner Module, Plug&Play
• 2 x Smartcard-Reader (Dreamcrypt CA)
• Mini USB for Service and software update
• 10/100Mbit Ethernet Interface
• 1 x Scart (RGB, FBAS or S-Video)
• HDMI
• 2 x USB 2.0 (e.g keyboard)
• analog modem
• S/PDIF Interface for digital bit stream out (AC-3)
• 64 MByte Flash, 256 MByte RAM
• SATA
- for internal HDD 2,5“
• unlimited channel lists for TV/Radio
• channel-change time < 1 second
• automatic service scan
• directly bouquet-lists
• EPG (electronic program guide)
• multiple LNB-Switching control (supports DiSEqC)
• OSD in many languages and skin-support
• Videotext Decoder
• extern 12V power supply
DVB receiver 800 HD se technical data
DBS-Tuner mit DVB-S2:
Frequency Range 950 .... 2150 MHz
Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
DVB-S2: 10 – 31 Mbaud/s (8PSK) , 10 –30 Mbaud/s (QPSK)
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible, H.264
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical, Toslink
Ausgang Video:
Ausgangspegel FBAS 1 Vss +/- 0.3 dB an 75 Ohm
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, RGB, S-Video
Mini USB service connector:
Function: Update of Firmware
Ethernet:
10/100 MBit compatible interface
Analoge modem:
analoge modem for Internet connection
SATA Interface:
for internal 2,5" HDD
USB
2 x USB 2.0
LNB power and polarisation per tuner:
LNB Current 500mA max.; short-circuit-protected
LNB Voltage vertical < 14V no load, > 11,5V at 400mA
LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
Count of active satellite position:
DiSEqC 1.0/1.1/1.2 and USALS (Rotor Control)
Power consumption:
< 15W at 12V
External PSU
Input:
110-240V AC / 50-60Hz / 0,6A
Output:
12V = / 3,0A
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H): 225 mm x 145 mm x 52 mm
Weight: 1940 g without HDD
1. Появился дополнительный USB порт спереди
2. Заменен однодиапазонный тюнер на трехдиапазонный: S/S2, C, T. Уже продается отдельно. На Триколоре 11804 все в порядке, чувствительность не прыгает и картинка не сыпится.
3. Добавлен внутренний Wi-Fi. Есть вариант и с наружным, вставленным а задний USB слот. Поддерживает протокол N. Отдельно не продается
4. Сим-карта
В комплекте сим-карта sim 2.1
5. На задней панели появилась кнопочка: Mini flashup
Она служит для присвоения IP из встроенной памяти при ERROR
При неправильной прошивке, если на дисплее видим ERROR:
1. Отключаем питание
2. Сетевой кабель должен быть воткнут в бокс.
3. Нажимаем кнопку Mini flashup и держим нажатой.
4. Включаем питание. После старта из встроенной памяти будет назначен IP. Далее заходим в сетевые настройки и переустанавливаем под себя. Эта фича подходит для всех видов боксов, у которых сзади есть эта кнопка.
Как вариант, посмотрев IP адрес, пропишите его в браузере компьютера и попадете на страницу загрузки имиджа через сеть.
http://www.sat-planet.net/showpost.php?p=199127&postcount=4
Рекомендуемый софт: BlackHole-dm800se
http://depositfiles.com/files/409ly6mo7
Софт от других групп:
http://www.sat-universe.com/showthread.php?t=224075
allllex
Как сканировать С и Т каналы.
1. Обнаруживается и отображается пока только один тюнер S, но он сканирует не только S/S2 каналы. Вы используете один и тот же тюнер для сканирования всех диапазонов.
2. Отсканировать все диапазоны можно на любом имидже, не требуется ничего специального. Протестировано на имиджах Sunray & Nemesis.
3. Прежде, чем сканировать каналы на С, или Т диапазоне, вы должны будете узнать Частоты каналов и Скорость передачи символов для Вашей Страны/Области. Как только узнали, Вы можете начать устанавливать конфигурацию тюнера.
4. Первоначально надо вписать транспондеры С и Т диапазона в свой файл satellites.xml. Позиция "спутника" в файле прописывается «от фонаря». Лишь бы такой позиции не существовало в натуре. Пример такого файла в подвеске. Там position="098" для Т. Потом перезагрузите GUI. Это только пример. Вы должны создать файлы со своими местными настройками.
5. Заходите в меню конфигурации тюнера, и устанавливаете настройки тюнера, как на картинке. У вас по кнопке Спутник (влево-вправо) появятся две новых позиции: DVB-T Europe и DVB-C Ziggo. Или что-то другое, прописанное в файле satellites.xml
На картинке выбран спутник DVB-T Europe просто потому, что так был уже откорректирован файл satellites.xml.
6. Теперь выйдите из конфигурации тюнера и выберите физическую опцию сканирования и установите настройки согласно рисунку. Тюнер у вас будет конечно другой. Скриншот только для примера.
7. Нажимаете ОК для начала поиска.
Таким же способом повторяете сканирование для всех частот.
Проводилось тестирование авто. Оно работает, если правильно откорректирован файл satellites.xml. Но если у вас в файле satellites.xml прописаны все стандартные частоты диапазонов, то сканирование идет очень медленно. Если знаете свои частоты от провайдера, то пропишите только их в разделе файла satellites.xml
Главное, что Вы должны помнить, это частоты. Надо вводить спереди 01. Например, если частота для Вашей области 643.000, в начало строчки помещаете 01, перед 643. Получается запись частоты 01643.
Для скорости передачи символов вам нужно в большинстве случаев поставить 0 впереди, таким образом, 8000 будет вводиться как 08000.
И еще одно замечание тем, у кого стоит дайсик.
Чтобы отсканировались и работали С и (или) Т каналы, в дайсике должен быть освобожден 1(2) входа. Они никуда не подключаются и дожны быть пустые. Антенна Т и (или) С конечно должна быть подсоединена в задние(ее) гнездо(а) бокса. Какой вход освободите, не имеет значения.
Если у вас уже все отконфигурено и в дайсике есть пустые лишние входы, то это они и будут. Тогда в скрине Параметры приема, вместо
LNB - LNB1
вы выставляете номер своего свободного входа дайсика. Тогда не придется лезть на крышу и освобождать вход дайсика.
Можно на крышу не лезть, а прописать вход со спутника, который вам мало нужен. Но тогда каналы с С или Т работать будут, а каналы со спутника заглохнут.
Отсканированные каналы прописываются в боксе как очередной спутник.
В DreamBoxEdit они тоже видны как отдельный спутник. И с ними можно делать все то же самое, как с обычными спутниковыми каналами.
  • satellites.zip
    4,8 KB · Просмотры: 173
allllex
Новый secondstage bootloader ssl84b для dm800se с симкой sim2
- Использовать только с оригинальными драйверами 9-11-2011
- nfi,bin и ipk файлы подвешены
- лучше использовать уже готовые имиджи с новым ssl
все самые последние имиджи с новым ssl доступны здесь:
http://www.dreamoem.com/forumdisplay.php?35-SIM2-images-for-Sunray4-SR4
  • sim2_800SE_SSL84B.rar
    546,4 KB · Просмотры: 167
Odyssey
Alex1362
если нужно в Украине могу помочь
Karl_Hlamkin
Все делаю по инструкции частота у меня 170 скорость 6750 не находит каналов dvb-c. имедж домика 9 .
---------- Сообщение добавлено в 23:39 ---------- Предыдущее сообщение размещено в 22:47 ----------
Все ок разобрался все работает
ujuf66
Доброго времени суток.
Встроенный вифи адаптер будет работать только на прошивке которая придёт с рессивером из китая или на любой вновь установленной?
wampir
Сегодня получил посылку САНРАЯ тюнер и медиаплеер АНДРОИД ТВ БОКС Е-66 полное ХД БОКС ОБОШЁЛСЯ С ПЕРЕСЫЛКОЙ 2100 РУБЛЕЙ а рессивер 218 долларов и пересылка 40 долларов Испытал плеер отлично работает а главное малеьнький и есть сеть и вай-фай Сегодня буду разбираться с рессивером Там находится 2 картоприёмника
ujuf66
С тиви боксом тебе не сюда, но уж коль речь зашла, хочу спросить, он ведь типа HD понимает, а как ты собираешься HD фильмы на нём смотреть, NTFS от не понимает, вифи у него даже на 54 не тянет, а элементарный HD фильм тянет на 8 гигов?
wampir
НОВЫЙ ФОРМАТ ВИНДЫ extFat чтобы не портить флеху так как NTFS работает в динамическом режиме поэтому флеха быстро дохнет а так берёшь флеху форматируешь либо ext3 или 4 в линуксовском формате а через командер загружаешь с поддержкой линуксовского формата но с плеером у меня проблем нет а вот с санраем 4 пока глухо имиж китайский снёс загрузил который побольше ПИТЕР ПЕН а руссого языка нет только надисплее может загрузчик другой надо имидж брал отсюда http://www.dreamoem.com/forumdisplay.php?35-SIM2-images-for-Sunray4-SR4 а что дальше делать пока незнаю читать походу надо Не подскажете азы где взять на коны
ujuf66
Могу посоветовать отличный форум
http://dream.altmaster.net/forumdisplay.php?f=33
там есть практически всё, сам жду кетайца DM800se+
ещё можешь заглянуть
http://www.sat-universe.com/forumdisplay.php?f=375
http://sat-planet.net/forumdisplay.php?f=677
http://www.dreambox.it/dm800se.htm
ujuf66
Я так и не понял как ты собираешься смотреть HD фильмы через БОКС.
extFat это виндовый формат, боюсь твой БОКС о нём не подозревает, а флэхи отформатированные в ext3 или 4 винда даже не монтирует, о каком командоре может идти речь.
wampir
Тоталкомандере грейпак и других большиньких сборках есть плагины с помощью которых винда видит ЛИНУКСДИСК и пожалуйста загружай либо по сети можно перегнать В медиаплеер вставляешь микроСД на 16-32 гигабайта монтируешь в медиаплеере и можешь туда перегонять либо диск HDD USB примонтируешь отформатируешь в линуксе сделаешь домашним и всё работай с торентами и медиафайлами либо хотя-бы вот таким линуксом http://greenflash.su/publ/11-1-0-67 на основе его сделан имидж санрая или вот этим который тоже поддерживает русский язык ftp://austrumi.ru.lv/ на основе которого сделан имидж вот этой железки Clarke-Tech ET9000 народ несёт какую-то ерунду про эти рессиверы если имидж дримбокс сделают от аустрими он также будет быстро работать
wampir
А эмулятор для триколора где взять никто не подскажет а то у меня есть карта 52 серии на 820 опене работает нормально и куда его вставлять а санрай4 пишет отсутствие дре эмулятора
wampir
Выбрал имидж Domica 9a греческой сборки Бесплатные каналы работают теперь надо поставить правильный эмулятор с этого форума http://www.domica.biz/index.php Почему поставил домику руссий язык и ПО ВСЁ ЕСТЬ либо немецкий от озон
pioneer1
Есть официальная карта NDS и номер ресивера,к которому она привязана. Как всё это хозяйство запустить на Санрее?
allllex
niftyman
allllex, а какой имидж Вы сами считаете наиболее оптимальным для данного тюнера?
