Lenina
Куратор "IPBox"
SWF-Vizyon-8x0/0-E2_V5.1.9_flash und USB
based TDT Tideglo V1.0.0
The SWF you presents for Viyzon boxes 800, 810, 820 and 8000
Enigma2 our new image.
Languages: de, en, fr, it, nl, pl ru
This Image's run on the IPBox!
So have fun with the new Enigma 2
Tideglo Changes: [/ B]
release 1.0.0
- Enabled-list movie menu also on 100HD, 200HD, 250HD (press PLAY button instead of FILE on other receivers)
- Fixed some playback bugs
- Updated patches crossepg (compatible with last version crossepg)
- Fixed some compatibility CI-CAM
- First try to fix timezone bug (time should always be ok now, and running standby mode)
- Unicable is now more customizable (check enigma2 configuration)
- Synced with enigma2 10/29/2010 cvs
- Separate SWF Panel
- Gs-fix
- SWF Emustarter
- Adjust volume (volume control of individual channels)
- New button functions: Long Exit -> SWF panel, long time, "Info" -> Emustarter long "Photo" -> Snapshot
- Auto Resolution
- Netzerkbrowser (nfs cifs)
- Boot Plus
- Crush
SWF Server
Emus-on-panel download SWF (SWF panel Emuverwaltung)
Image download updates via SWF panels (SWF panel backup restore)
Plugins download (SWF-panel-Info button-green)
- Integrated multi-boot
Key1 = flash
Key2 = SDA1-USB
Taste3 = SDA2-USB
Taste4 = sda3 IDE
Taste5 = sda4 IDE
Taste6 = SDB1-USB
Taste7 = SDB2-USB
Taste8 = sdb3-USB
Taste9 = SDB4-USB
Taste9 = NFS
- Backup function for the Flash image (Settings, emus, keys and other personal property are secured) Prerequisite a USB stick (SWF) or a connected HDD / Skins, fonts, emu, keys, Plugins, etc. are loaded from the stick (if available)
- Usb / flash-update online for future images
- Standard-Skin, Concinnity910-HD
-User = root
Ipbox 9000 FLASH VERSION http://hotfile.com/dl/82393311/8728f64/SWF-8000-E2_v5.1.9_flash.tar.gz.html
Ipbox 9000 USB VERSION
http://hotfile.com/dl/82392979/28edf7c/SWF-8000-E2_v5.1.9_usb.tar.gz.html
IPBox 900 DOWNLOAD FLASH VERSION
http://hotfile.com/dl/82396236/031868f/SWF-810-E2_v5.1.9_flash.tar.gz.html
IPBox 900 DOWNLOAD USB VERSION http://hotfile.com/dl/82396228/7a9e2f3/SWF-810-E2_v5.1.9_usb.tar.gz.html
IPBox 910 DOWNLOAD FLASH VERSION http://hotfile.com/dl/82396701/84932c6/SWF-820-E2_v5.1.9_flash.tar.gz.html
IPBox 910 DOWNLOAD USB VERSION http://hotfile.com/dl/82396693/f99dbe0/SWF-820-E2_v5.1.9_usb.tar.gz.html
release 1.0.0
- Gs-fix
- SWF Emustarter
- Auto Resolution
- Boot Plus
- Crush
SWF Server
Key1 = flash
Key2 = SDA1-USB
Taste3 = SDA2-USB
Taste4 = sda3 IDE
Taste5 = sda4 IDE
Taste6 = SDB1-USB
Taste7 = SDB2-USB
Taste8 = sdb3-USB
Taste9 = SDB4-USB
Taste9 = NFS
-User = root
