SWF-Vizyon-Cuberevo-8x0/0-E2_V2.0_flash und USB
Lenina
Куратор "IPBox"
SAT - WORLD - FORUM
auf Basis TDT Tideglo V0.7.5
Das SWF präsentiert euch für alle Viyzon-Boxen (800,810,820 und 8000)
unser neues Enigma2-Image.
Diese Image's laufen auch auf den IPBoxen!
Also viel Spaß mit dem neuen Enigma 2
release 0.7.5
- added possibility to search channels by channel name's first letter, just press the remote button with the letter in the channel list
- fixed a bug on input box for remote controller keys
- added nc
- fixed some new memory leak bugs on drivers side
- updated enigma2 cvs 15/12/2009 (don't ask me all the change log, it's too big)
- added working subtitles remote button on live tv
- second recording should now be fine when starting while playback and another recording are active
- timeshift (or record + playback) should be more stable
- VCR scart connector now supports input signal, so you can connect other devices to the box and see automatically the TV signal when cuberevo is in standby or in deep-standby
- fixed WSS over 4:3 Scart connector, do not forget to set it in the A/V Configuration menu (let me know if it works good with TVs)
- updated to python 2.6
- added possibility to set Fan by menu (check CuberevoVFD in the plugin menu)
- added possibility to set brightness by menu (check CuberevoVFD in the plugin menu)
- added possibility to set clock in standby by menu (check CuberevoVFD in the plugin menu)
- added possibility to set led by menu (check CuberevoVFD in the plugin menu)
- added possibility to set scroll mode for channels name in the VFD by menu (check CuberevoVFD in the plugin menu)
- updated dreamTV-HD skin (IMHO now is a little bit cooler)
- fixed some VFD icons showing bugs, more need to be added
- fixed DVB subtitles where they were not allowed over some channels (like Universal Channel with Romanian subtitles, TotalTV and so on: report if now it works good)
- fixed a bug were enigma2 doesn't decode teletext pids on some channels (like Mega, Star, ANT1 in package Netmed: report if now it works good)
- udpated webinterface to last 23/12/2009 cvs
- fixed seeking from current position in avi
- fixed user audio delay in seeking
- enable seeking in mp4 files
- Bootlogo geändert
- cardreader support
- multiboot über swf-panel installierbar (script-executer)
- Enigma2.mo angepasst auf vizyon
- Telnet-login überarbeitet (root / vizyon)
- Videotext auf Wunsch nun Vollbild
- png im Webinterface getauscht (webtv)
- Web-Interface Style geändert
- incubus 0.96, mbox , camd3 mgcamd sind bereits enthalten ( Blue Panel )
Информация отсюда (нужна регистрация) и скачать можно тут же на всю линейку внутреннюю и внешнюю
http://sat-world-forum.com/thread.php?threadid=44071
Только странно, что для USB версии, если распокавать, имидж Е2 не в развернутом виде получается, а в файле "usb_update.img".
Seryi134
Там слева для юсб, а справа для флеш >>>USB Image<<<.......... >>>Flashimage<<<
SWF MOD :
- eigenes SWF-Panel
-User = root
-Passw.= vizyon
Вот перелил на rapidshare.de
IP-Box 91HD
>>>USB Image<<<
>>>Flashimage<<<
IP-Box 900HD
>>>USB Image<<<
>>>Flashimage<<<
IP-Box 910HD
>>>USB Image<<<
>>>Flashimage<<<
IP-Box 9000HD
>>>USB Image<<<
>>>Flashimage<<<
Lenina
Куратор "IPBox"
Да, видать то ли на сайте откуда качал перепутано, то ли по своей ошибке не ту ссылку качал, но оказалось ложная тревога. Вечером буду пробовать.
donot2009
И как это чудо техники по стабильности и качеству?
Чем отличается от Искана Барракуды?
young gun
неужели начал не с "пацаны"!good!
возьми флешку и...пробуй-это ж интересно!
з.ы.у меня пропадает тоже звучок)
з.з.ы.не на этом моде(на 2й баракуде)
Lenina
Куратор "IPBox"
постоянно валится в зелень...
Хорошо бы указывать (лучше в подписи) на каой ресивер производилась установка и какая версия, а то прямо боязно ставить...
edarot
поставил флэш на 910 ,скины лучше не менять только то что там , я в онлайн скин качнул другой и поймал вечную зеленку...
поставил снова и вообщем все ок , да hdd сам примаунтился и появились старые записи что были раньше...
до этого стояла энигма2 сифтим бэта, так вот бросилось в глаза на этом моде картинка не знаю уж почему...стала лучше, HD каналы стали сочнее и прозрачнее(очень похоже на картинку в HD на родных DGS прошивках)
тел LG 42 полный фулл
может кто тоже это заметил?
zapad75
Установил на свой Cube Revo-250HD(IPBox91) и сразу понял про "постоянно валится в зелень...". при старте с включеным mgcamd появляется зелёный экран и тюнер ребутится. и так по кругу..............
sergey71
Установил на свой 9000 полет нормуль по поводу mgcamd я сначала закинул конфиги в keys потом активировал emu перезагрузил и нет никакой зелени пока все хорошо.Пока зелени нет вот только меню на русском языке не работает.
Sani0k
Установил и я на свой 91 вроде зелени нет,скин лучше нетрогать ,иногда пропадает звук...и с часами безобразие -1 час :]
eugeny13
привет.поставил на 910 пока все хорошо.мжкамд работает.шара работает.моё радио с файла m3u работает.ни разу в зелень не ушло.
sergey71
Работает вроде ничего грузится очень долго,может что отключить можно?
sampaul
Долго сидел на PKT 065 Iscan Mod. Решил поставить эту. Целый идёт без проблем и даже HD на П+, которые до этого вешали ресивер моментально, только полный ресет помогал. Есть, правда, пара странностей: иногда на дисплее нет вообще никакой информации и кнопка standbye даже не светится. Не поймёшь - включен аппарат или нет. С часами проблема осталась. А так всё пока нормально.
sampaul
Иногда ресивер теряет тюнер после standbye. Приходится делать ресет. Фризов практически нет. П+ HD каналы стали квакать.
Lenina
Куратор "IPBox"
А ссылочку ipbox9000 дашь или как?
Ее еще нет пока на 9000. Попробовал на 9000 от 910 на флешку поставить и посмотреть - не пошла.
Для 9000 вот здесь надо вылавливать http://np-ulc.net/index.php?&direct...n/1.- Images/10.- Vizyon 8000 - IP-Box 9000HD
По третьей версии открыта своя ветка.
