7729gs
а какие именно должны быть конфиги только приорити реплей игнор ньюкамд листы?
bvolody
Еще mg_cfg и SoftCam.Key.
LiqLover
В RTi 1.5.3 в /dev/dvb/adapter0/ уже есть устройство ca1 . Если mgcamd_1.31 запускать с ключом B {00}, то ключи приходят, но картинки нет.
root@AZBoxHD:~# killall mgcamd_1.31
killall: cannot kill pid 1917: No such process
killall: cannot kill pid 1918: No such process
killall: cannot kill pid 1959: No such process
root@AZBoxHD:~# /usr/bin/mgcamd_1.31
tuxbox mgcamd v1.31 by mixvt (compiled Oct 29 2008 19:11:00)
[mg] Net:1:7:2:3s Show ecm:1, emm:0 Up:5 Au:0 Dir:0 Osd:no:80:0 Cache:3 Log:3:192.168.1.2:514 Reread:0
[mg] Ecm cache time: 720
Box type: dbox2
root@AZBoxHD:~# Conax.Key error 2: No such file or directory
SoftCam.Key error 2: No such file or directory
AutoRoll.Key error 2: No such file or directory
[config] newcamd route =
newcamd keep alive: 300, incoming port: 12000
[mgcam] emm thread started
[mgcamd] tps update started.
/var/keys/tps.bin error 2: No such file or directory
[newcamd] Connecting to ...
[newcamd] Login to as accepted (104ms)
[newcamd] Card data from (198ms):
Userid 18 caid 500 providers 2
Idents: 030600 040600
[newcamd] Login to (99ms)
[newcamd] Card data (187ms):
Userid 195 caid 4AE1 providers 1
Idents: 000000
got 153 cmd 9F
[mg0] namespace 1680000 t-id B on-id 70
[mg0] descramble on 1, source 0
[mg0] service 2B66 index 0 pmt pid CEE (1)
ECM: CaID: 0x0500 -> CaPID: 0x07DA ProvID: 040600
[mg0] No viaccess key(s) found for id 40600 keynr 08
[mg0] -> ECM to newcamd
[mg0] <- CW from newcamd (100ms)
[mg0] 100 msec -- Thu Dec 15 19:57:37 2011
===== Viaccess ECM on CaID 0x0500, pid 0x07da ======
prov: 040600
cw0:0 6C 3E 2D D7 E5 4A 8A B9
cw1:0 EC 33 EF 0E 71 6E 65 44
[mg0] <- CW from newcamd (970ms)
[mg0] 970 msec -- Thu Dec 15 19:57:41 2011
prov: 040600
cw1:0 EC 97 F5 78 28 9D 91 56
[mg0] <- CW from newcamd (655ms)
[mg0] 655 msec -- Thu Dec 15 19:57:51 2011
prov: 040600
cw0:0 93 A0 CB FE B7 1A C2 93
[mg0] <- CW from newcamd (577ms)
[mg0] 577 msec -- Thu Dec 15 19:58:00 2011
prov: 040600
cw1:0 6A 0D 07 7E 12 A4 9B 51
Есть ли способ поправить это?
allllex
Ну и что? Эмулятор все равно неправильно определяется тип бокса, и картинки нет.
Box type: dbox2
Здесь уже эмулятор определяет неправильно не девайс, а тип бокса.
LiqLover
Ссылка не создается:
root@AZBoxHD:/# ln -s /dev/dvb/adapter0/ca0 /dev/dvb/adapter0/ca1
ln: /dev/dvb/adapter0/ca1: File exists
root@AZBoxHD:/#
То есть нет способа поправить работу mgcamd?
allllex
А ты читать умеешь? Что написано?
ca1: File exists
А написано что файл уже существует!!!
LiqLover
А ты читать умеешь? Что написано? ca1: File exists
Читать умею. И понимаю, что File exists означает невозможность создать ссылку са1 на са0, так как уже есть устройство са1.
Что и подтверждается логом.
Вот работает с В 06
OpenAzBox 1.6.0 AZBoxHD
AZBoxHD login: root
[mg] Net:1:5:2:3s Show ecm:1, emm:0 Up:5 Au:0 Dir:0 Osd:no:80:0 Cache:3 Log:3:192.168.1.2:514 Reread:0
[B]Box type: mips dreambox (dm7025, dm800)
/dev/dvb/adapter0/ca2 error 2: No such file or directory
/dev/dvb/adapter0/ca3 error 2: No such file or directory
[/B]root@AZBoxHD:~# Conax.Key error 2: No such file or directory
[config] newcamd route =  : :10000
[newcamd] Connecting to  :10000...
[newcamd] Login to  :10000 as   accepted (106ms)
[newcamd] Card data from  :10000 (203ms):
got 148 cmd 9F
[mg0] namespace 1680000 t-id 2 on-id 70
[mg0] service 27E3 index 0 pmt pid 78 (1)
 ECM: CaID: 0x0500  -> CaPID: 0x07DB ProvID: 040600
 ECM: CaID: 0x0500  -> CaPID: 0x0BC3 ProvID: 030600
[mg0] -> ECM to newcamd  :10000
[mg0] <- CW from newcamd  :10000 (264ms)
[mg0] 264 msec -- Sat Dec 17 15:02:03 2011
===== Viaccess ECM on CaID 0x0500, pid 0x07db ======
prov: 040600
cw0:0 1E 08 3B 61 2D 12 76 B5
cw1:0 2B A8 70 43 C2 28 65 4F
[mg0] <- CW from newcamd  :10000 (539ms)
[mg0] 539 msec -- Sat Dec 17 15:02:10 2011
prov: 040600
cw0:0 DE 3C 3F 59 29 7D 7D 23
Картинка есть.
Останавливаю, меняю В 06 на В 00, пытаюсь создать ссылку.
root@AZBoxHD:~# killall -9 mgcamd_1.31
killall: cannot kill pid 1890: No such process
killall: cannot kill pid 1891: No such process
killall: cannot kill pid 1892: No such process
root@AZBoxHD:~# ln -s /dev/dvb/adapter0/ca0 /dev/dvb/adapter0/ca1
Запускаю эмулятор и видим, что не работает:
[B]Box type: dbox2[/B]
Есть идеи как побороть ?
allllex
Ты же видишь, что при теперешней конфигурации имиджа автоматически создается девайс са1. Но это уже другой девайс, а не копия са0, когда ты создавал сим-линк.
И эмулятор уже не может автоматически определить тип имиджа. И он определяет его как dbox2.
1. Надо править эмулятор, или
2. Надо сделать так, чтобы девайс са1 не создавался автоматом. Тогда прописывай свой сим-линк.
Поэтому тебе дают выше правильный совет.
LiqLover
Причину, по которой перестал работать метод с созданием линка на устройство я понял сразу. Поэтому и задал первый вопрос в посте о том, что линк не создается. Так как не знал, есть ли простой способ, как решить данную проблему. Моих небольших знаний для этого не хватало. Так как выяснил, что решения нет, то напишу на форуме RTi, может и поправят что-нибудь. Всем спасибо за разъяснения.
allllex
Только заикнешься об эмуляторе на этом сайте, сразу получишь бан.
Если ты используешь RTi 1.5.3, то на этой версии лично у меня Мгкамд летает. Как они перешли на новое ядро от Опенсата, открывает все каналы, что на одном спутнике, что на разных, одинаково быстро. У тебя что то другое. Поставь B {06}, и забудь. У меня бокс - элит. Про другие боксы не знаю. Напиши в подписи марку своего ресивера, будет понятней.
LiqLover
К сожалению, у меня премиум плюс и на нем каналы переключает реально медленее (с момента нажатия кнопки до появления картинки другого канала 5-8 секунд против 3-4 на 1.4). А на 1.4 отсутствие нормальной регулировки звука достало. Викард переключает быстрее, но начинает заикаться минут через 10 просмотра. Вот и нет счастья :)
glavin
allllex, Для тех, кто хочет решить проблему с ускорением работы эмулятора мгкамд, вы предлагаете вариант, как этот вопрос вы решили для себя. Эмулятор запускается сразу и сам выбирает, какая позиция параметра В ему больше подходит.
Это только для тех у кого стоит enigma?
gorr
ситуация была аналогична
попытался разобраться
причина - системная конфигурация (модель , ревизия платы системной) и оптимальный скин
попробуй простой скин
должно работать без проблем
по кайней мере у мееня так и получилось
PS
все что здесь обсуждается касается естественно энигмы 2
allllex
Это для первых версий Е2 для азбокса. В последних версиях не работает, потому то са1 уже имеется в боксе при загрузке.
shpilka
Помогите настроить открытие каналов БИСС. Установил MGCAMD 1.35 шаринг работает, когда включаю канал кодированный БИСС крутятся шестерёнки и висит. Установил ЕНИГМУ OPENRSI через обновление в заводской прошивке. MGCAMD установил через плугины добавить.
shpilka
Разобрался, изменил атрибут файла softcam.key на 755 и всё пошло.
