ENGLISH :
Readme_OCTAGON_SF1018_HD_ALLIANCE_V10765__28_10_09
for Octagon HD SF 1018 HDTV - ALLIANCE :
Changes :
- Record copy function add.
- FAV Groups increase to 32 folders (self editable)
--> Menu - Ch. List Manager - Favorites)
- HDMI Dolby Digital new function add.
--> Menu - AV Settings - HDMI Dolby Digital : ON/OFF
- Timer Setting (REC) : new function
--> EPG Programm Information add. (EPG)
- Russian Keyboard add.
- EPG Search function improved
- Wireless WLAN (Wifi) function improved
--> minor bugs fix.
--> Wireless network setting related error fix.
--> Netzwerk Setting part modified
- Scramble file REC + Play with CI Cam modul
- When scramble record Play, Record function add. (on same time)
- Dolby Digital improvements :
--> HDMI & SPDIF
- AAC Audio Codec fix.
--> TPs of Sirius, Thor und Turksat
- New OSD Design in Service CH. List (OK Button) add.
--> Right Above : [Alle Ch.] T1 T2 (Tuner 1 & Tuner 2)
--> Above : A~Z CAS Transponder Provider etc.
- TimeShift bug fix. by low SR...
- Bug. by Timeshift fix. , when change Audio Track
- Freeze on Turksat 42E fix. (Samanyolu, ATV, TGRT, XAZAR etc.)
- Video Output Mode improved, when is higher 576p (hide)
- Divx Playback improved
- Some of Wordscharacters in VFD Display change (upper case)
- File list option increased (Playback Mode)
- STATIC IP setting bug fix. (DNS Setting)
- BlindScan & Netzwerk Search improved
- IRD Copyschutz increased (Clone SW protection) + CMD Res. fix.
- FDU CH Database upgrade - FDU 1.3 Version
- Micom-Chip driver update
Online SW upgrade : oud.gmc.to
IMPORTANT : Advice for Software and Setting Update
Please save/copy Swoftware & Setting files in MAIN Directory from your USB Stick !
Please make after SW update Factory Reset (System Recovery) !
SmartCard Activate :
Pls. Press Menü --> Utilities --> CAS --> OK Button --> Enter PIN 1018
--> SmartCard ON/OFF
CAM Start/Stop :
--> Start : Menu + Red Button
--> Stop : Menu + Blue Button
Storage Setup`s (Save/Store to STB) :
Menu --> Installation --> System Recovery --> Press OK Button :
--> System restore to stored Position (recover/restore Backup)
--> Store System Data (Backup Store)
Storage Setup`s to USB Stick/Storage :
Menu --> System Tools --> Data Transfer --> Press OK Button :
--> Transfer All System Data to USB Storage
--> Transfer Service Data to USB Storage (Channel list)
--> Data Download from USB Storage
Sky Premiere Portal (Multifeed) - Taste --> Blue Button
Master Password : 1018
Connection STB to PC :
- Connect STB with LAN Cable to PC
- Menu --> Installation --> Netzwork Settings --> change DHCP off and ON
--> Pls. wait until your IP nummer showing
--> Workstation in PC --> In Address Bar \\ (flashx2) give \\IP number and Press ENTER
--> You can see : Root (LINUX) & Storage (Speicher SATA HDD + USB1 + USB2) !
--> Also can use Samba and FileZila Program !
Date 28 October 2009
Changes :
--> minor bugs fix.
--> HDMI & SPDIF
CAM Start/Stop :
