V10775 EMU NEU : OCTAGON_SF1018_HD_ALLIANCE_V10755__24_11_09
Evdok
Модератор "Octagon"
Readme_OCTAGON_SF1018_HD_ALLIANCE_V10775__24_11_09
for Octagon HD SF 1018 HDTV - ALLIANCE :
Changes :
- 2nd Internal Card slot aktivated (Dual SmartCard support)
- Record & Playback function of/from PC HDD add. (Mounting)
--> Menu - System Tools - Storage Manager : Current Device --> Network Drive - Netzwork Setting
--> Menu - Configuration - Recording Option : Record Device --> Network Drive
- PIG (Live picture) in EPG, CH.list and Service List Manager detachable funvction add.
--> Menu - Configuration - Display Setting : OSD Typ --> Picture in Grafik (PIG) & Transparent (no PIG)
--> Soon more ... Exp. CH List , in place of PIG will add. EPG Information
- EPG showing faster (Infobar, Quick EPG, EPG)
- Multifeed Portal function improved :
--> Window displaced (left-justified)
--> Window reduced
--> PMT and EIT identification fix.
- ITV HD (Astra28E) bug fix. ( http://en.kingofsat.net/pos-28.5E.php )
--> Advanced Search : TP Freq + SR + Pol. + VPID APID PCR enter + start search
--> Advanced Search : 11426 27500 Hor. 3401 3402 3401 + start search
- New Trick (Skip) Mode function :
--> Menu - Configuration - Recording Option : Commercial Skip - 10, 15, 20, 30 (Second)
- Trick Mode function fix. (Record, Playback and TimeShift Bar)
--> Use Play Button for Trick Mode function
--> Independent if TimeShift on/off
- Dont showing Quick CH. list by direct ch zap. via RCU numerics
--> QUick Ch. List will make detachable (hide) ... soon
- Start Scan TP after BlindScan cancel (EXIT Button)
- NIT (Netzwork) Search imporved + speed fix.
- EPG bug fix. of Thor 0,8W, EIT info TP 12456 MHz
- Internal Card reader in CAS Menu dont go Hide when reboot STB
- EMU (newcs mgcamd incubus cccam newcamd camd3 etc.) dont need Start afer STB reboot (menu red button)
- All Playback Icons change in Green colour (Spooling, Trick Mode, TimeShift, Recording, Playback)
- Timer ICON for Playback in EPG change to Green colour, change too in Menu - System Tools - Timer Setting
- Add. Space in Infobar when is CH number higher then 999
- New function in Language Setting :
--> Menu - Configuration - Language Setting : Teletext Language
- Add. Special Character showing on VFD Display for Turkish Language
- Teletext improved : correct showing of special characters (div. Lang.)
- It can't overwrite when it move file to other folder with same name
--> support add like as file-1, file-2
- Show latest result on the EPG search window
- Support history of last keyword. (soon will be support 5 history keywords)
- AUTO Detect function improved,need longer time but result better
- Change transparency to low value on the INFOBOX. (for clear font image.)
- CAM Modul + SmartCard bug fix.
- New functions in Menu - Installation - System Recovery :
--> Reset configuration (Delete all user configurations)
--> Reset Service Data (Delete all Ch. list)
- Server URL for Online Sw update add. (Server URL : oud.gmc.to)
--> Menu - Instalaltion - Network Setup : Firmware upgrade Server - Server http//... oud.gmc.to
Обсуждение - здесь
  • OCTAGON_SF1018_HD_ALLIANCE_V10775__24_11_09.rar
    13,1 MB · Просмотры: 40
