V10781 EMU NEU:OCTAGON_SF1018_HD_ALLIANCE_V10781__08_12_09
Readme_OCTAGON_SF1018_HD_ALLIANCE_V10781__08_12_09
for Octagon HD SF 1018 HDTV - ALLIANCE :
Changes :
- OSD Menu + Fonts enhanced
- File (device) Copy function add.
--> Playback Mode : Blue Button - File Option : Copy
--> SATA - USB, USB - SATA, USB - USB
- Storage (HDD) Device Sleep function add.
--> If the STB is not used for 10 min, the STB will go to sleep mode (SATA & USB)
- TimeShift Manual Start function add.
--> Menu - Configuration - Recording Option : TimeShift Start - auto, manual, off
- OSD Menu fonts can change with User Font
--> Built font folder in root/var font ordner (Fonts cna copy in this folder)
--> Menu - Configuration - Language Setting : USer Font File - (select font - TTF)
- Standby Power Mode for HDD add. (SATA & USB)
--> Menu - Configuration - A/V Output : Standby Power - Press OK Button
--> Main Power (Standby) : ON/OFF
--> HDD (SATA) Power : ON/OFF
--> USB Power : ON/OFF
--> HDD (SATA & USB) availability in Standby
- Volume offset setting for each service add.
--> Press Audio (Yellow) Button : Sound Level - Low -30%, normal, High -30%, Off
- EPG search history text (Last 5 texts) EPG - Yellow Button
- Using Vol -+ Buttons (Volume control) in EPG and CH.List (Service List)
- SPDIF Dolby new default Menu
--> Menu - Configuration - A/V Output : Dolby Digital Default - ON/OFF (SPDIF)
- KeyManager (BISS) add. : Menu and Enter PIn 8282
- Sace Key Data of USB Stick / HDD
--> Menu - System Settings - Data Transfer : Save Key Data to USB
- ORF problem fix. (Astra19,2E)
- Volume Bar colour change
- Info Bar : Icons change, add. Time Clock Weekday, Signal Bar size reduce
- IN Playback Mode colour, Style and OSD Design adjustment
- Signal bug fix (HD -SD, tuner1 error)
- Info Bar EPG ticker bug fix.
- ITV Edit & Recording bug fix.
- Database bug (Setups) and bug in CH.List Manager fix.
- Netzwerk Mount. bug fix.
- Div. bugs in Playback Mode fix.
- CI Cam Module Message On/Off managed by option
--> Menu - Tools - CAS Menu : CI Message - ON/OFF
Online SW upgrade : oud.gmc.to
IMPORTANT : Advice for Software and Setting Update
Please save/copy Swoftware & Setting files in MAIN Directory from your USB Stick !
Please make after SW update Factory Reset (System Recovery) !
SmartCard Activate :
Pls. Press Menь --> Utilities --> CAS --> OK Button --> Enter PIN 1018
--> SmartCard ON/OFF
KeyManager Aktivate --> Menu + Enter PIN 8282
CAM Start/Stop :
--> Start : Menu + Red Button
--> Stop : Menu + Blue Button
Storage Setup`s (Save/Store to STB) :
Menu --> Installation --> System Recovery --> Press OK Button :
--> System restore to stored Position (recover/restore Backup)
--> Store System Data (Backup Store)
Storage Setup`s to USB Stick/Storage :
Menu --> System Tools --> Data Transfer --> Press OK Button :
--> Transfer All System Data to USB Storage
--> Transfer Service Data to USB Storage (Channel list)
--> Data Download from USB Storage
Sky Premiere Portal (Multifeed) - Taste --> Blue Button
Master Password : 1018
Connection STB to PC :
- Connect STB with LAN Cable to PC
- Menu --> Installation --> Netzwork Settings --> change DHCP off and ON
--> Pls. wait until your IP nummer showing
--> Workstation in PC --> In Address Bar \\ (flashx2) give \\IP number and Press ENTER
--> You can see : Root (LINUX) & Storage (Speicher SATA HDD + USB1 + USB2) !
--> Also can use Samba and FileZila Program !
Date 08 December 2009
!good!
________________________________
Обсуждение - здесь
  • OCTAGON_SF1018_HD_ALLIANCE_V10781__08_12_09.rar
    13,3 MB · Просмотры: 97
