Readme_OCTAGON_SF1018_HD_ALLIANCE_V10783__18_12_09
for Octagon HD SF 1018 HDTV - ALLIANCE :
Changes :
- In Standby mode, After stopping Recording,and Power-On again, there will be "No signal" ==> fix.
- MPEG-4 CAM Modul Support add.
- Fast Scan is not working because of PID Filter setting wrong
- YC Output bug fix.
- CI CAM Modul zapping speed improved
- If HD resolution is 576P, the condition display through SCART Output
- If 1080i Stream, in the Service List, the PIP range problem fix.
- Changed RECALL Button function
--> one time - Recall List
--> press again - Recall --> jump to last CH View
- In Play List, Listing up the contents without sorting capital letter
- Playfilelist ui breaking bug fix.
- PayTv Symbol (Icon) in CH List add. (left)
- Marked Channels in CH List new colour (scope white)
- Div. Translations misstakes fix. (Div.Languages)
Online SW upgrade : oud.gmc.to
IMPORTANT : Advice for Software and Setting Update
Please save/copy Swoftware & Setting files in MAIN Directory from your USB Stick !
Please make after SW update Factory Reset (System Recovery) !
SmartCard Activate :
Pls. Press Menü --> Utilities --> CAS --> OK Button --> Enter PIN 1018
--> SmartCard ON/OFF
KeyManager Aktivate --> Menu + Enter PIN 8282
CAM Start/Stop :
--> Start : Menu + Red Button
--> Stop : Menu + Blue Button
Storage Setup`s (Save/Store to STB) :
Menu --> Installation --> System Recovery --> Press OK Button :
--> System restore to stored Position (recover/restore Backup)
--> Store System Data (Backup Store)
Storage Setup`s to USB Stick/Storage :
Menu --> System Tools --> Data Transfer --> Press OK Button :
--> Transfer All System Data to USB Storage
--> Transfer Service Data to USB Storage (Channel list)
--> Data Download from USB Storage
Sky Premiere Portal (Multifeed) - Taste --> Blue Button
Master Password : 1018
Connection STB to PC :
- Connect STB with LAN Cable to PC
- Menu --> Installation --> Netzwork Settings --> change DHCP off and ON
--> Pls. wait until your IP nummer showing
--> Workstation in PC --> In Address Bar \\ (flashx2) give \\IP number and Press ENTER
--> You can see : Root (LINUX) & Storage (Speicher SATA HDD + USB1 + USB2) !
--> Also can use Samba and FileZila Program !
Date 18 December 2009
www.octagonfunclub.net
www.octagon.gmc.to
www.nlb.to
www.minicat.tv
www.hdfreaks.cc
viel spass beim testen
mfg
Octagon88
___________________________
Обсуждаем здесь
Changes :
CAM Start/Stop :
www.octagon.gmc.to
www.nlb.to
www.minicat.tv
www.hdfreaks.cc
mfg
Octagon88
Обсуждаем здесь
