OCTAGON_SF1018_HD_ALLIANCE_V10801__24_03_10
for Octagon HD SF 1018 HDTV - ALLIANCE :
Changes :
- Freezing Screen when Flash writing fix.
- Diseq Command error fix.
- Voltage changing issue when receiver turn to standby condition during recording fix.
- Not appearing popup message for plugin download fix.
- Audio delay sync feature added and it can set on AV Output Menu
--> Menu - Configuration - A/V setting : Audio Sync Delay 0 ms..20ms...400 ms
- Recording fail message appears in case default recording device is set incorrectly fix.
--> receiver will ask to find correct recording device.
- Ch. Search improvements : BlindScan, Auto & Manuell Search
--> Incorrect channel searching result between two TP which has very near frequency fix.
- Eutelsat 16E scan bug fix.
- TP Datenbank update : Eutelsat 16E
- New SAT add. : Eutel sesat 1 - 16E
- Receiver hangup in System Informaiton Menu fix.
- API Version , Driver version update
Online SW upgrade : oud.gmc.to
Обсуждение здесь.
Changes :
Обсуждение здесь.
