V10822 Octagon Sf1008 Hd Intelligence 20.05.10
IMPORTANT Information :
Pls. make Factory Reset and Format HDD !
Bug fix.:
- Fails when recording(via network) a event with specific font fix.
--> pecial letter (character) making no recording. This is corrected
- REC file name set as previous event name when weekly or daily timer recording fix.
--> 6 minutes buffer from the event starting time.
- Timer reservation error fix.
- Screen breaks on ORF HD channel fix.
- 2 x INFO Button : EPG content ...missing characters fix.
New Functions / improvements:
- Timer conflict works not correctly
- Prevent collision between play alarm and recording
- JPEG mode of playlist,you may select one file and will be able slide(view) all the images
- Delete user font function add.
--> Menu - Configuration - Language Setting : RED Button (Delete All User Fonts)
- Display as '*' for keyboard password
- Affirmation function by HDD Format and File System add.
--> Menu - System Tools - Storage Manager :
--> Format : File System (FAT32/JFS) + Format OK
- Löschen Plugins function add.
--> Menu - Utilities - Plugin : BLUE Button
- Advanced Showing in Timer Settings function add.
--> Menu - Systeme Tools - Timer Settings :
--> Calender (Yellow Button)
Modification:
- File name repetition in playlist and channel name shows at right part
- In quick service list, channel which is not able to modify marked by dark silver
- VFD not able to display Turkish charactor "I" - 1 tuner model
- In PIP, Main/Sub same channel will not decode (PIP List)
System Information:
- API Version 17.Mai 2010
- Treiber Version 19.Mai 2010
- Root File System 17.Mai
- Build Version : 3099
Online SW upgrade : oud.gmc.to
Файловый архив.
Обсуждение.
Bug fix.:
Modification:
System Information:
Файловый архив.
Обсуждение.
