janigor
“The True Standard of HD Zapper”
Vu+ have been very quiet lately, working away behind the scenes on their new creation, there was no mention of the Vu+ Zero at Anga 2014, so for many the Vu+ Zero will be a bit of a surprise.
So what is it, and is it any good ?
Let’s find out.
Features:
The Zero is a very small and compact, a bit like it’s price tag, make no mistake this is a budget STB, but don’t let it’s small size and price-tag fool you.
Hardware:
• 2K DMIPS Single Core Dual Thread 750MHz CPU
• 1x Fixed DVB-S / S2 tuner
• 256MB Nand Flash / 512MB DRAM
• Dolby Digital Plus & DTS Supported
• 1 x Smartcard-Reader (Xcrypt)
• 2 x USB 2.0 Ports
• 10/100 Mbit Ethernet Port
• 1 x HDMI 1.4 video / audio output (digital)
• Full HD 1080p Output
• 1 x RCA video output (analog)
• DiSEqC 1.0/1.1/1.2, USALS
• External 12V power supply
• Power Switch
• Fanless Silent Operation​
Software:
• Linux Operating System
• Media Player
• Downloadable Plug-Ins supported
• HbbTv
• EPG supported
• Unlimited channel lists for TV / Radio
• Automatic & Manual Service Scan Supported
• Multiple LNB control (DiSEqC) supported
• OSD in many languages
• HD 1080p Skins Supported
• Skin change supported​
As you can see, it’s certainly not lacking in features for a low cost STB.
Inside the box:
I am testing a pre-production model here, therefore the box that mine arrived in may well be different from the final retail models. Mine arrived in a cardboard box, with a sticker on the front of it, showing the Black and White Editions of the Zero.
On opening the box up, you find the following inside:
• Vu+ Zero Satellite Receiver
• Quick Start instruction manual
• Remote Control (the same popular Universal type that is supplied with other models in the Vu+ range and will come in either Black or White, depending which colour Zero you choose)
• 2x AAA Battery’s
• Hdmi 1.4 cable
• A/V Cable (3.5mm Jack – RCA)
• IR Blaster
• External Power Supply unit​
    37 KB · Просмотры: 3
    52,1 KB · Просмотры: 2
janigor
Прошил последней BlackHole 2.1.4, так же быстро работает как и все вушки.
Завтра покупаю новый ресивер. Какой посоветуете брать- vu+solo или vu+ zero? Оба 118 евро...
mocckba, брал бы "zero", параметры солиднее.
boris.kova
Тоже вчера купил Zero,впечатляющая коробочка,симпатичная и работает хорошо.Ещё не полностью освоил,но,думаю.разберусь.
sasa80_80
Помогите незнаю что купить или zero или openboxs3 mini? Vu+zero на линоксе смогу ли я разобраться?
Привет! картинка на ву будет лучше да и возможностей просмотров больше. Непрогадаешь..неразберешся- поможем !good!:)
sasa80_80
Спасибо! Самое главное меня интересует ввод ключей например сейчас взломана кадировка Pawer vu смогу ли я смотреть не на этом тюнере? И как вводить ключи можно ли с пульта?
---------- Сообщение добавлено в 12:30 ---------- Предыдущее сообщение размещено в 12:26 ----------
Смогу ли я смотреть кодировку Power vu на этом тюнере и как вводить ключи возможно ли с пульта или нужен компьютер? Потомучто мне сказали что там ни все так просто и нужен на все действия компьютер нужно быть программистом даже редактировать каналы и то через комп так ли это
На форуме есть инструкции как ичто:) ну нет там ничего страшного и непонятного . Ну если хочешь смотреть только халявные каналы без шары..то бери опенбокс с3..если шарик...то ву.
Kisa
Можно, вот только просмотр практически без проблем гарантирован на ву, чего не скажешь об опене.
DrDron
недавно купил себе Зеро. Доволен! Смотрю +++ шуру. Всё быстро работает! До этого был Азбокс элит не о чём говорить...
