Default AAF_MultiPartinstaller1.6_UFSxxx
build another program to use Multipart for BA.
It's NOT to replace KCC but we can use this untill VisMan has more time to add multipart to KCC.
It's like BA_help from GOst4711.
Only we made a few more options.
- Install BA on UFS922 in Flash (with org. image or new E2 flash image)
- Installing a image from Flash / BA / UFS_Image for UFS910 and UFS922.
- Install a image from ../UFS_Images
- Reboot
- delete image
- rename image
- Set Boot image
- drag and drop from UFS_Images to Installed images list
- Copy settings, channels, var, amount.ini from running image
When installing a image you will be asked to change the name (or keep the name)
The image that is set for boot has a blue color.
Here are the copy options:
Copy channels:
/usr/local/share/enigma2/bouquets*
/usr/local/share/enigma2/userbouquet.*
/usr/local/share/enigma2/lamedb
/usr/local/share/enigma2/satellites.xml
/etc/tuxbox/satellites.xml
Copy Settings:
/usr/local/share/enigma2/settings
Copy Picons:
/usr/local/share/enigma2/picon (complete dir)
Copy mount:
/usr/automount/amount.ini
/etc/auto.misc
/usr/local/share/enigma2/automounts.xml
Copy Var:
/var/emu/*.*
/var/etc/*.*
/var/etc/autostart/start-config
/var/keys (complete dir)
Copy BlueKey action:
/var/.blueKey or /var/etc/blueKey (depending on copy from )
Copy Plugins:
/usr/lib/enigma2/python/Plugins/Extensions/ + selected plugin ( if selected )
Copy bootp.conf:
/var/baroot/ba/ba/{imagename}/bootp.conf
/var/baroot/ba/ba/{imagename}/bootp2.c
Danke an Black_64 für dieses Tool und das gute HowTo von joergurmel,
sowie den AAF-Betatestern
Добавлено через 5 минут
Фаили положил в фаилообменник:http://forum.sat-expert.com/downloads.php?do=file&id=391
- Reboot
- delete image
- rename image
- Set Boot image
Copy channels:
Copy Settings:
Copy Picons:
Copy mount:
/etc/auto.misc
Copy Var:
/var/emu/*.*
/var/etc/*.*
Copy Plugins:
Copy bootp.conf:
