AAF Summer Dream E2 Flash
levan
incubusCamd configuration file #
# All configuration options in this file observe the same format: #
# <configuration_name>=<configuration_value> #
# Each section are [<section_name>:<option_1>:<option_x>] like. #
# No matter about white spaces on any place or UNIX/DOS style files #
########################### general configuration ############################
[General]
# Enable (1) or disable (0) background execution
# 0 - Off
# 1 - On
background_execution=1
# This sets the level of console output for debugging:
# 0 - No debug messages, 1 - First level debug messages, 2 - Second level debug messages,
# 3 - Print all debug messages
debug_level=3
# This option enables (1) or disables (0) the writing of debug information to the
# console.
log_to_console=1
# This option enables (1) or disables (0) the writing of console output to a log file
log_to_file=0
# When log_to_file is set to 1, this is the path and filename to write console
# ouput to.
logfile_name=/var/bin/incubusCamd.log
# Used to activate on-screen messages. Username and password required if
# HTTP authentication is enabled on enigma.
on_screen_messages_show=1
on_screen_messages_username=root
on_screen_messages_password=
on_screen_messages_key_update=1
on_screen_messages_wait_for_key_update=0
on_screen_messages_ecm=0
on_screen_messages_emm=0
#When activated, camd will listen on the specified port for connections. All
#log activity will be broadcast in real-time to connected clients.
console_logs_broadcast=1
console_logs_broadcast_port=666
########################### provider configuration ###########################
[Prov:000000:CaID:0000]
decoder_type=1
card_server_url_0=cccam://
########################### servers configuration ############################
[Servers]
# card_server_url=cccam://<username>:<password>@<hostname>:<port>
########################### CaIDs tunneling configuration ############################
[CaIDTunnel]
1833:1702:000000
Добавлено через 1 минуту
cviki, Тоже самое не активный кам
Добавлено через 6 минут
Я думою проблема, где то в var/etc/incubusCamd.sh4_e2
alex1059
levan, а права 755 установил на эти файлы?
lexxz
вот лог инкубуса на плтформу помогите разобраться в чём проблема:
ECM[di:1] **** [Tue Aug 25 14:49:01 2009] Start processing ECM...
CaID: 4AE1 - .
Provider ID: 000000 - Supported.
Ecm PID: 0079
Raw Encrypted ECM:
81 00 26 56 0E 02 3B 05 00 4A 94 12 2F FC 6E 03
0D A2 F2 1A BE 4E BB AA 34 47 E7 29 26 34 78 A1
0D 5E C2 42 4E 6A 7A FD 88
Decoder: Using Newcamd protocol card-server.
[Newcamd] Connecting to card-server...
cam[di:1]: No card-server configured.
Control words:
CW0 (NOT SET): 00 00 00 00 00 00 00 00
CW1 (NOT SET): 00 00 00 00 00 00 00 00
cam[di:1]: Client disconnected.
cam[di:-]: Invalid message. Ignoring service request.
cam[di:-]: Removing inactive service (SID: 0000).
cam[di:-]: Message data:
9F 80 32 23 03 0D AD 07 00 13 01 81 08 00 5A 00
00 16 A8 00 9C 82 02 01 00 84 02 03 E9 1B 07 D1
00 00 04 0B B9 00 00
SID:0dad, NS:005a0000, TSID:16a8, ONID:009c, PMT PID:01e9, DM:2, DMX:0
Root CA Info | CA Descriptors: 0
PID Section | Type: 1b [MPEG4 Video], PID: 07d1, CA Descriptors: 0
PID Section | Type: 04 [MPEG2 Audio], PID: 0bb9, CA Descriptors: 0
cam[di:-]: Can't decode. CA info not found.
cam[di:-]: Removing inactive service (SID: 0dad).
по протоколу нькамд он ваще работает?
den2503
Че то не пойму как настроить строку. Я так понимаю помимо настройки сервака нада устанавливать идент, но как поставить для +++ 2 идента 023700 и 030600 в одной строке. Если 1 строка с идентом 023700 то не работает ХД
blakcrad
Народ не партесь вы с инкубисами и мпцсами, через плагины закачайте самд3 последней версии , пропишите логин пароль и один порт и будет вам счастье :)
погонял и я энтот имидж - действительно давольно качественный,
но на спорт хд продержалься до песка часов 5 !bad!
lexxz
на камд у меня фризы на плюсах , а на мпсэс даже на предыдущем имедже на плюсах ХД было щастие , просто хочется смотреть платформу нормально , менял провайдеров шары ,но ничего не меняется провайдеры гоорят нада мжкамд , а прикрутить его проблема ,на инкубусе 86 был наилучший эффект , но очень медленно каналы переключались
yavor1
вот мой конфиг -ти толко поменяй сервер, юзер и пас- и софткам кей фаил и тоже ъпдейт скрипт для инкубус 0.92, а я с файл менажер заредил инкубус 0.90, а потом поменял с переименований incubusCamd0..92 на incubusCamd0.90, тоже даю в директории сетуп
  • incubusCamd.rar
    303,1 KB · Просмотры: 34
MaskaV
cviki,sposibo za config,nakonec udalos zapustit 0.92.No na platforma HD vse rovno gljuki iz za etih durackih dvoinih pid.
blakcrad
lexxz,
по камд3 есть несколько вариантов подключения, так вот
редактировать нужно только camd3.servers ( тут пароль и т д) , ну и если есть необходимость создать фильтр filter.services.txt ( для более быстрого переключения каналов, и не будет фризов ( при условии что у вас установлена последняя версия самд3 ) исключения - очень плохой интернет.
St0nE
Приветствую! Замучали фризы по Camd3.. причем на всех имиджах.. правил только camd3.servers и добавлял filter.services... Все, больше ничего не менял. У кого на Camd3 идет без фризов, отпишитесь плиз, может еще что в конфигах поправить надо... и напишите по какому протоколу camd3 работает, 357 или другие.. инет отличный, оптика.
Спасибо
blakcrad
St0nE, 357работает
Фризы могут быть не из за эмулятора а например по причине перегрева ресивера...
Может действительно стоит попробовать другой эмулятор, но у меня нет фризов ни на мпцс ни на самд3...
Xronon
St0nE
Хммм, странно... а я уже запарился.. Минут 15-20 нормально работает все, а потом начинает фризить... видео отстает от звука, потом выравнивается, но может и вообще зависнуть..
n@mo
sathacko
St0nE, точно такое у менянаблюдается и сейчас - дело у меня в плохом интернете, наверняка и у вас тоже.Пропингуйте и протрассируйте серваки. и почитайте может поможет http://forum.sat-expert.com/emuliatory-emu/14745-zatyki-na-kamd3.html
mpelion
у меня все ок по camd3 и mpcs у меня настроен по camd3 никаких проблем
TapaH
Странная проблема - ставлю чистый имидж, даже после полного сброса кати, а он вылетает на некоторых моментах в зеленку... К примеру захожу меню - AAF Panel - все ок, но пытаюсь оттуда выйти и на моменте нажатия кнопки exit yн пульте, находясь в разделе AAF, стабильно уходит в зеленку в 100% случаев... Свап есть.
UPD: Поставил правильный mgcamd и проблема решилась
rokirovka
А как убрать часы при просмотре канала,в меню установил нет,все равно не убираются
Еще вопрос,как редактировать каналы
