- driver: 03.04.2015
- kernel 3.13.5 (Solo², Duo², Solo SE, Zero)
- kernel 3.9.6 (Duo, Solo, Uno, Ultimo)
- xbmc pre-installed (Solo², Duo², Solo SE)
- support for GUI animations (Solo², Duo², Solo SE)
- build python with IPv6 support
- update AtileHD skin
- update and enhance functionality of GraphMultiEPG plugin
- update default services
- update OpenWebIF
- use lsusb with all functions (no busybox lsusb)
- Enigma2 (2014-04-02)
add option to deactivate timer(button STOP or GREEN LONG), THX @busch
add many skin parameters (improved FullHD skin support) THX @hmmmdada
extend dvbapp2 core for additional skin parameters for config lists textOffset, secondfont)
add option to save parental control pin when CI modules are in use
show zap history (button EXIT in TV mode)
save list style type and sort order folder based (MovieList)
support parental control for movie folders
support parental control for deleting movies
add option to hide service name in service list
add option for double-spaced service list
support for any picon size in service list
SkinPro is available for every skin not only AtileHD
opkg install -force-overwrite /tmp/*.ipk
How to Download Cams and Active it:
1-Blue button > Blue button (Cam Center) > Blue button (Manage Cams)
2-Then select and download what you need
3-To active cam press Blue button > Blue button (Cam Center)
4-Select Cam and press Green button (Start Cam)
setup+system+ video enhancement settings+blue button
