E2_RSP_3.17b_TDT_1142
nbv127
Появился новый имидж E2 . Выложил сюда
http://rapidshare.com/files/231123461/E2_RSP_3.17b_TDT_1142.rar.html
Stick Image for Kathrein UFS-910 1w or 14w
RSP menu on RED button. Former RED command was moved to PLAY
- A very good and up-to-date settings list (28E-30W)is included.
We will have frequently updated lists made by EnF70, settings you can download from RSP Panel
- We recommand you, still keep AC3 downmix on for stability and fewer (or even, no) green screens.
- We also recommend to format partitions with ext3 fs.
A few words on changes since the former E2 RSP 2.02 TDT 953:
TDT:
- new libplayer2
- enable keyboard and mouse support
- enigma2_01052009
- Switch to MediaPLayerExtended
- CSAT FR fix
- wma support
- mkv AAC
- vob support
- scan and recording both working
- all scan problems and "No SID in PAT", fixed
RSP:
- New WEBIF by tic2000
- RSP panel reaction speed increased
- Name server issue, fixed
- Intelligent EMU management:
- each time you choose emu install, latest revision of EMU on server are checked and menu is redesigned, to include them
- in the emu start/stop menu you will see only those that you have installed
- you cannot re-install an emu if you don't remove it first
- "RECORD" labeled partition is automatically mounted on /hdd/movie; the other partitions are mounted in /tmp/[device]
- when mounting the HDD you can see only valid Linux partition
- it supports cifs; you have to enable it in the menu and edit the configuration file (var/config/amnt.cfg) using the appropriate PC IP address,
login username and password and the folder name you want to mount.
Установился нормвльно , русский есть на VFD . сейчас поставил на канале HD +++ утром посмотрю как насчет песка
blakcrad
nbv127,
встал прекрасно, но вот касяк - мпцс не запускаеться, скачал с аплоуда самд3902 - запустил - ключи идут а картинки нету:pardon:,
..... проблемка решилась - перезагрузкой ресивера...
теперь потестим на мазайку...
tolli
This file is neither allocated to a Premium Account, or a Collector's Account, and can therefore only be downloaded 10 times.
This limit is reached.
To download this file, the uploader either needs to transfer this file into his/her Collector's Account, or upload the file again. The file can later be moved to a Collector's Account. The uploader just needs to click the delete link of the file to get further information.
Перезалейте плиз, ещё раз.
blakcrad
И снова песок есть ... ну когда же его уже не будет то ...
Кстати русский на панели ресивера есть и отображается корректно...
мпцс работает если с не большим исправлением http://forum.sat-expert.com/e2/14283-mpcs-dlia-rsp-mod.html
Есть приятная новость -
Симпатичный вебинтерфейс - и стрим HD каналов по vlc идет идеально !
Ещё ( может мне кажется ) но качество на HD стало выше - картинка более кристальная.
Перешёл с самд на мпцс - мпцс как всегда рулит , и мазайки не наблюдаеться , оставлю на хд канале , посмотрю сколько без песка проработает.
Несомненно имидж стал намного стабильней и живее.
den2503
Подскажите, можно поставить БА на установленную во внутреннюю флэш ЭНИГМУ??? (черная жемчужина)
blakcrad
во первых жемчужину обсуждаем в другой теме
во вторых жемчужина на ба итак есть
в третьих флешь имидж уступает ба имиджу и нет смысла урезаную версию ставить на ба .
Добавлено через 18 минут
песок появился при не до настроенном самд3 ( фильтры не включил ),
сейчас на идеально настроенном мпцс песка не наблюдаю,
начинаю подозревать что наш песок связан на прямую с эму...
сам имидж кажется просто супер стабильным...
И ещё - исправлен формат каналов мпег4 - теперь изображение 4\3 так и выводиться 4\3.
по всей видимости этот мод энигмы на данный момент лучший .
den2503
Ну вот, не так меня понял. У меня установлена жемчужина во внутреннюю флэш, а хочу учтанавливать бругие имиджи на БА. Есть такая возможность или нет?
master73
Блин,мне опять не везет.Зигружается полностью имидж,ниче не делаю,нажимаю синюю кнопку на пульте получаю зеленый экран.:(
blakcrad
нажимаю на синию кнопку - попадаю в радио, ( может начнешь не с синей кнопки а с меню? )
У меня не было ни одного зеленого экрана... по крайней мере пока ... буду ковырять дальше пока не надоест или пока зелень гденить не вылезет
LANG
master73 надо другую usb флешку
у меня тоже так было поменял и все.
master73
:).Я не правильно выразился,естественно до этого основное настроил сеть, каналы...
master73
Разобрался.Глупый вопрос,возможно не втему,а как здесь замаунтить несколько папок с компа ?
blakcrad
мне кажется что картинка стала ПРОСТО ОФИГЕТЬ. - мама мия.
значит мне это не показалось :)
Попытался пристроить пиконы как в ааф - не прокатило ( зеленый краш ),
Кто знает куда или как их приткнуть?
siant
Кто прояснит - это совпадение, или такой порядок, что теперь у каждой группы, выходит энигма на новом, индивидуальном билде.Так TDT раздаёт, или в данном случаях RSP оказались проворнее - мне кажется AAF или PKT сделали бы поинтереснее румынов...Следует ли ожидать от немцев версии на 1142, или у них сразу 1200 выйдет?)
nbv127
blakcrad, да песок появляется чаще когда эму стопорится но на Платформе HD работает лучше чем на ++++ , я имею ввиду каналы HD, сейчас поставил мпцс посмотрю футбол и поставлю на HD-канале
