Enigma 2 Nightly Build: 0.8.5 version
Lenina
Куратор "IPBox"
Originariamente inviata da ReadMe
HISTORY:
release 0.8.5
- fixed AC3 audio dropouts over SPDIF with downmix set to off on few HD channels (report if the bug still there on some channels)
- fixed the enable/disable 12v option in advanced enigma2 menu configuration
- fixed a high cpu usage bug on enigma2
- fixed pgup and pgdown buttons, now they are mapped to be used for channel changing
- added possibility to change bootlogo on flash images
- fixed a bug on few receivers that on 0.8.0 made them not working
- fixed a stability bug on all receivers
- fixed bug on the second tuner for scrambled channels
- added NTSC, 480i and 480p video modes support (i don't know if it works or not, i can't test it)
To people having problem with date/time:
since version 0.8.0 date/time is managed on the same way used on DGS firmwares, so if you at first are having a bad value
for date/time, just go into telnet console and type the command: date -s YYYY.MM.DD-hh:mm:ss
Replace YYYY with the year, MM with month, DD with day, hh with hour, mm with minute, ss with seconds.
After this type: cubefpctl --syncfptime
Now set your GMT offset on enigma2 configuration menu.
WARNING: using PIP with the second tuner on scrambled channel could make the tuner stops to work,
a full box restart is needed to make it working again.
I will try to fix this on next versions.
Enjoy it! Tideglo
USB and Flash versions here: http://enigma2.sifteam.eu/index.php?dir=Enigma2 NightlyBuild 0.8.5/
Взято отсюда http://forum.sifteam.eu/ipbox-hd-enigma2/66726-enigma-2-nightly-build-0-8-5-version.html#post489474
zapad75
Установил на 91HD. Снег, зелень(Тюнер "Шарп"). Откатился на PGI 0.5.
chewbacca
Модератор "AzBox"
Да более-менее. Только часы на час спешат и EPG не работает.
for date/time, just go into telnet console and type the command: 1
аглицким по белому написано:
Людям, у кого проблемы с датой и временем
Лезем на рес телнетом и даем команду
date -s YYYY.MM.DD-hh:mm:ss, где YYYY - год, MM- месяц, DD-день, hh.mm.ss время соответствено.
Потом
Lowik
Привет, Tideglo пишет:
"To people having problem with date/time:
Now set your GMT offset on enigma2 configuration menu."
Попробуй, установить время вручную через телнет:
буквы заменить на дату и время и cubefpctl --syncfptime
EPG не работает изза разницы времени.
P.S. Пока это писал уже уточнили ....
zapad75
когда же уже выйдет прошивка с поддержкой тюнеров шарп? а то ставлю енигму поиграюсь и назад откатываюсь на пги!bad!
igoron
ЕПГ не работает, в списке каналов напротив названия канала нет названия передачи.
Шрифта от искана 808.
Что можно сделать?
тоже самое было в енигме 075,080 и теперь в 085. Тюнер 200HD
chewbacca
Модератор "AzBox"
Что можно сделать?
Первое что надо сделать, это начать читать перед тем как писать.
2 поста выше смотри. А насчет шрифтов - поиск - обсуждалось неоднократно.
igoron
я конечно то ли ***** то ли лыжи не едут.
время синхронизировал - толку 0. епг как не было так и нет.
время идет правильное, если на инфо нажимаю график текущей передачи рисует, название тоже есть, а епг нет.
если не трудно ткните пальцем что с шрифтами нужно сделать.
скопировал шрифты от искана не помогло, в факе нашел приатаченный багамас шрифт - скопировал тоже не помогло.
Помогите если не трудно как разрешить, мозг уже пухнет
или обратно на 070 откатыватся....
возможно проблема именно в модели тюнера
VadimIv
Хмм...
Единственный мод, который на HD канале (DiccoveryHD с Поверхности) проработал почти всю ночь. Хотя одна попытка снега (пресеченная) была. По-моему даже снег был на экране довольно продолжительное время (кстати другого цвета) но потом убрался перекл. каналов.
Под утро начал заикаться звук. Пощелкал каналами - результат - ни один канал с 36Е не работает ("Tune Error" или "SID не найден в PAT"). 75Е вроде работает.:unsure:
По быстрому попробовал перенастроить спутник, пересканить транспондер - не помогает.
После работы буду разбираться...
young gun
я думаю из за профилактики:)
VadimIv
Спасибо за инфу!
Вполне возможно, что как-то повлияло....
Но вообщето другой мод на этом же ресивере в другом разделе - показывал, правда всеми каналами не щелкал.
donot2009
Я так понял, что проблему со временем и ЕПГ через телнет решаем?
А еще есть какие-нибудь заподлянки от Тидегло ?
Стоит ее ставить или нет? Стабильно пашет?
young gun
ставь rc 1 (погорячился :)),или жди iscan mod,и дополнение к своему посту удали,забанить тя могут.
а этот мод я не ставил-сам жду iscan mod.
VadimIv
Если можно, подробнее!:)
Добавлено через 1 час 32 минуты
У меня ругается, говорит "Invalid date"
Перегрузился в DGS, потом в Энигму - время стало правильным.
Сделал на всякий случай
Но информации о передаче после названия канала в списке каналов - не появилось!
И ЕPG не работает.
donot2009
Чем больше я узнавал Е2 тем больше мне нравилась прошивка на DGS
nikolasi
хм-о епг.Его есть два варианта-европейский и русский.Европейский на +++ НЕ РАБОТАЕТ.Открываете скин.хмл скина задаете поиск в акелпад по слову ExtendedDescription и все ExtendedDescription переименовуете в Description.Там их 3 или 4 штуки.Сохраняете и прегружаете гуи.вот вам и описание и епг на наших каналах.Тидего делает для европы....
