Enigma 2 Nightly Build: 0.9.2 version
nikomar
Originariamente inviata da ReadMe
release 0.9.2
- fixed Polsat HD channels and many other HD channels (i.e.: Sky Calcio HD, Sky Olimpia HD and so on)
- updated kernel to version 2.6.23.17-0123
- added gdata for python plugins
- added romanian language (thanks to otheitis and his team)
- improved remote controller responses time
- made general OS system optimizations
- updated Enigma2 CVS to the 13/03/2010
- fixed USB booting for: cuberevo-mini-fta, cuberevo-250hd, cuberevo-2000hd (usb file system must be ext2 type)
- added wifi drivers (zd1211 chipset, if you need them do an insmod /lib/modules/zd1211b.ko)
P.S.: PIP is temporarily disabled.
For USB version boot (file system must be ext2 type): mkfs.ext2 -I 128 -b 4096 your_device
where your_device could be /dev/sdaX, /dev/sdbX, or similar.
Enjoy it! Tideglo
http://enigma2.sifteam.eu/index.php?dir=Enigma2 NightlyBuild/Enigma2 NightlyBuild 0.9.2/
Добавлено через 17 часов 16 минут
Enigma 2 0.9.2b for Flash only.
Originally Posted by ReadMe
release 0.9.2b
FLASH only release
- fix for passwd on flash
- fix for wpa_supplicant.conf on flash
- added possibility to edit file /etc/ipkg/official-feed.conf
I did a mistake on building the flash images, so you could get some errors with wpa access... this version will solve those bugs.
On USB there is not this problem, because on USB you have always the good chmod permission on all the system.
http://enigma2.sifteam.eu/index.php?dir=Enigma2 NightlyBuild/Enigma2 NightlyBuild 0.9.2b/
nikomar
Ну теперь хоть звук есть на канале 1+1 International с Сириуса и Рикор ТВ можно смотреть :)
