incubusCamd 0.91
cviki
incubusCamd 0.92
Ну вот вышел 0.91 !good!
Пробуем,делимся инфои.
Ну убеите меня,делаите со мной что хотите но я свято чюствую что етот ему всёравно будет ближе мгкамда :rofl:
History:
10/08/2009, V0.91
- fixed a bug on caid tunneling
- fixed a bug when a cw with same old value arrives
- added web interface (the config writer could have some bugs, it is not 100% tested)
- added log of ecm pid selected
- added timeout check on server connection (no more blocking if a fail server is given)
- fixed a check on multi-istances
- added on_screen_messages_ecm and on_screen_messages_emm (emm are disabled, so now is useless), pay attention,
it will pop-up a message on the screen each time an ecm decrypted successfully arrives
- if no more protocol or priority type will be selected (check_priority, cs_protocol_order) nothing will be used by default,
check the config file for more examples and infos
- added possibility to set priority/ignore on ecm pid (check the incubusCamd.prio file for more infos/examples)
- fixed a bug with emu given by cccam protocol servers
- fixed a bug on reading keys from SoftCam.Key file (also added possibility to use char ; or # for comments)
- now all emulators codifies should be ok, i can't test them all, so report if something is wrong (do not forget to use the SoftCam.Key edited
like the one attached in the release pack, because it's not like others softcam.key files)
- fixed a bug on reading config files, wich do not delete spaces ' ' when found
No EMMs are supported yet, so do not hope in that, emms will be implemented in a future version
incubusCamd 0.91 http://rapidshare.com/files/265930731/incubusCamd_0_91.rar
solved once for all bugs with spaces and comments in config files
incubusCamd_0_92.rar http://rapidshare.com/files/265992920/incubusCamd_0_92.rar.html
cviki
Ну вот добился 10 минут стабильного просмотра +++ !good!
Но есть одна проблемка,думою как её исправить :)
Ну вот потрудился до утра и запустил +++, Платформа ХД и виасат 5е на newcamd :yahoo:
Работает стабилно но проблемка осталас с числинностю конекта.Работает до 10 минут,болшего числа конектов несумел довести:big_boss:
Всё исправил !good!
Работает чють шустрее чем mpcs и луче конектиса к серверу а если так то недеюсь песка больше неувидеть.
Иду спать и оставляю на платформа HD а там будет видно.
Но что етот ему работает стабилнее чем mpcs ето факт.
hendrik
...Всё исправил !good!
Так что исправил и каким образом на 0.92?
Делис опытом так как мне трудно попробоват русские проваидеры - 9E не вижу, 36E нет приличного доступа...:pardon:
В readme четко сказано, что надо поставит priority/ignore в фаиле IncubusCamd.prio .
В фаиле IncubusCamd.conf определяются проваидеры и очеред исползования шары и ему.
Если толко шара нужно, пишетса в проваидер инфо
check_priority=cs,cs,cs
и нужное очеред протоколов
cs_protocol_order=cccam,newcamd,gbox,camd35,camd33,radegast,aroureos
Ети две строчки надо в конфигурацию 0.92 обязателно поставит, иначе Incubus 0.92 не будет нормално работат.
hendrik
Incubus v0.92
Может быт кто-то исправит и имя темы?
Сам Incubus v0.92 приложено
  • IncubusCamd_0.92.rar
    596,7 KB · Просмотры: 73
cviki
Да, Платформа ХД до сих пор показывала идеально, от 5е также хорошо!good!
А с +++ через каждые 5 мин бывает стоп картинка и начинаютса фризы.Будет время ешчё на етом паработаю.
cs_protocol_order= сколько newcamd столко +++ показывает стабильно.Вот здесь где то глюк.Другие проваидеры показывают как и говорил стабильно.
А Incubus как и ожыдал работает стабилнее чем mpcs :)
config
[Prov:000000:CaID:0000]
cs_protocol_order=newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamdd,newcamd,newcamd
process_emms_on_cs_mode=1
process_emm_g=0
process_emm_s=0
process_emm_u=0
priority
P: 0500:020710 #+++
P: 4AE1:000000 #Platforma HD
P: 090F:000000 #5e
Добавлено через 3 минуты
Платформа HD на mpcs у меня работала не очень стабильно но на етом emu просто чюдо :)
Добавлено через 38 минут
hendrik может догадываешся почему так может быть с етим cs_protocol_order= на шчёт +++ ?
hendrik
config
process_emm_g=0
process_emm_s=0
process_emm_u=0
priority
P: 0500:020710 #+++
P: 090F:000000 #5e
Первая идея - может быт надо игнорироват 023700 и 030600, чтобы не мешали?
I: 0500:023700
I: 0500:030600
Вторая идея - может быт написат 7 рас newcamd в строке
хотя должен хватит и одного раза?
# you can also declare only one type: cs_protocol_order=newcamd
cviki
Один Невцамд на первом конекте нормально а на втором уже тормоз.С двумя два нормально с тримя три и так дальше.Что интересно на 9е и 5е етого ненаблюдаетса.
Вполне реально что надо игнорировать остальные иденты так как понимаю на 9 и 5е только по одному иденту идут.Скоро буду дома попробую.
Ну и если заработает так будем иметь в полне приличный emu,ну так как и mgcamd !good!
hendrik
ОК,
ожидаем резултата.
Я уверен, что ети ignore ряды очен нужные.
Со своеи стороны могу сказат, что 0.92 хорошо работает как CCCam ЕМУ.
Если получит Incubus 0.92 работат на официалную имидж (например на 1.07 beta), был бы очен хорошо :rofl:
Насчет официалнои 2.00 ничего сказат не могу и не собираюс...:stop:
cviki
hendrik зачем тебе надо чтоб он работал и на например 1.07 и что ты смотриш по CCCam EMU?
Ну просто чюдо :) оставил на HD Liffe а шчяс посмотрел работает идеально.
Вот ето EMU
hendrik
На 1.07 работает нормално DISEqC 1.1, а у меня пока 7 LNB стоит. Может быт, будет болше...
Ну и качество HD картинки - нет смысла сравниват с e2, если TV нормалныи.
CCCam EMU пока для официалки нет.
У нас CCCam исползуетса очен много, так как Dream основнои тунер. Про Kathrein почти никто не знает и не хочет знат...
И по CCCam можно видет все что надо.
cviki
Ну добился ешчё менше фризов на +++ но до конца довести неудаётса.Может гдето промох.
А ignore как раз болше мешает:)
hendrik
У меня наоборот - мучился много с Sky UK Arts 1 HD - там очен много хороших концертов в HD, и толко применение Ignore для ненужного
CAID 0961 помогло сразу !good!
Иначе "малевич" :]
sathacko
Ну просто чюдо оставил на HD Liffe а шчяс посмотрел работает идеально.
Вот ето EMU
выложи пожалуйста если не трудно конфиг-файлы чтоб прописать логин и все пошло!Смотрю +++hd и PLATFORMA HD
cviki
config
########################### general configuration ############################
[General]
background_execution=0
debug_level=0
log_to_console=0
log_to_file=0
logfile_name=/var/bin/incubusCamd.log
softcamfile_name=/var/keys/SoftCam.Key
priofile_name=/var/keys/incubusCamd.prio
on_screen_messages_show=1
on_screen_messages_username=root
on_screen_messages_password=
on_screen_messages_key_update=
on_screen_messages_wait_for_key_update=
on_screen_messages_ecm=
on_screen_messages_emm=
console_logs_broadcast=0
console_logs_broadcast_port=666
webif=0
webif_port=668
#[Prov:000000:CaID:0000]
cs_protocol_order=newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd,newcamd
process_emm_g=0
process_emm_s=0
process_emm_u=0
########################### servers configuration ############################
[Servers]
#card_server_url=newcamd://username:p[email protected]:10550:0500:028800/0102030405060708091011121314
Добавлено через 16 минут
sathacko напиши как тебе +++hd и PLATFORMA HD показивает?
alex1059
Кто-нибудь нормально настроил этот эмулятор для энигмы? Показывает с затыками. Нужны файлы конфигурационные. Кто настроил выложите пожалуйста.
arkan_net
Поставил 0,92. Жрет процессор жутко.
Согласен с chewbacca. 0,88 работает просто шикарно, уже пару недель пользуюсь только им.
alex1059
arkan_net,
настроил 0,88. Все работает нормально кроме платформы. Она долго открывается. У тебя также?
