chewbacca, при переключении на некоторые каналы пишет: Service not found (SID not found in PAT).
http://forum.sat-expert.com/faq-po-e2/13828-oshibka-timeout-reading-pat.html почитал поправил, но все равно вылазит.
Картинки нет все равно
Ну вот, зеленый экран зацикленный
Сделаю все заново, для чистоты эксперимента.
В общем переставил еще раз Энигму. Сделал все по инструкции. Шара не работает никак.
Конфиги:
mpcs.conf
[global]
Nice = -1
ClientTimeout = 5
ClientMaxIdle = 9999999
LogFile = /tmp/mpcs.log
MaxLogSize = 500
[dreambox]
User = root
#EMM = 1
______________________________________
mpcs.server
[reader]
Label = HTB
Protocol = newcamd
Device = xx.xx.xx.xx,50046
Account = 123456789,987654321
IDENT = 0500:020710;0500:023700;0500:030600;
Fallback = 0
Group = 1
ReconnectTimeout = 20
mpcs.user
[account]
User = root
Pwd =
Group = 1
Лог:
>> STREAMBOARD << mp-cardserver started at Thu Feb 5 03:22:04 2009
2009/02/05 3:22:04.812 661 s version=0.8k-rc16d, system=sh4-dbox2-linux, nice=-1
2009/02/05 3:22:04.813 661 s max. clients=30, client max. idle=9999999 sec
2009/02/05 3:22:04.813 661 s max. logsize=500 Kb
2009/02/05 3:22:04.814 661 s client timeout=10 sec, cache delay=0 msec
2009/02/05 3:22:04.814 661 s shared memory initialized (size=201276, fd=3)
2009/02/05 3:22:04.815 661 s 13 biss keys loaded:
2009/02/05 3:22:04.815 661 s 00: 0212:0064:0064:0001:10091932362462BC10091932362462BC
2009/02/05 3:22:04.815 661 s 01: 0322:0001:1111:0007:0327022C106251C30327022C106251C3
2009/02/05 3:22:04.815 661 s 02: 0322:0001:1111:000E:0327022C106251C30327022C106251C3
2009/02/05 3:22:04.816 661 s 03: 0322:0001:1111:0006:0327022C106251C30327022C106251C3
2009/02/05 3:22:04.816 661 s 04: 0322:0001:FFFF:0001:0327022C106251C30327022C106251C3
2009/02/05 3:22:04.816 661 s 05: 0322:0001:1111:0008:0327022C106251C30327022C106251C3
2009/02/05 3:22:04.816 661 s 06: 0322:0001:1111:0011:0327022C106251C30327022C106251C3
2009/02/05 3:22:04.817 661 s 07: 0322:0001:1111:0014:0327022C106251C30327022C106251C3
2009/02/05 3:22:04.817 661 s 08: 0322:0001:FFFF:0001:0327022C106251C30327022C106251C3
2009/02/05 3:22:04.817 661 s 09: 0385:0007:0001:0011:260839671204384E260839671204384E
2009/02/05 3:22:04.817 661 s 10: 0385:0001:FFFF:0001:0327022C106251C30327022C106251C3
2009/02/05 3:22:04.817 661 s 11: 0385:0001:0001:0001:0327022C106251C30327022C106251C3
2009/02/05 3:22:04.818 661 s 12: 0385:0001:0001:0001:0327022C106251C30327022C106251C3
2009/02/05 3:22:04.818 661 s Cannot open file "/var/keys/mpcs.sid" (errno=2)
2009/02/05 3:22:04.819 661 s userdb reloaded: 0 accounts freed, 1 accounts loaded
2009/02/05 3:22:04.820 661 s signal handling initialized (type=sysv)
2009/02/05 3:22:04.820 661 s can't open file "/var/keys/mpcs.srvid" (err=2), no service-id's loaded
2009/02/05 3:22:04.821 661 s monitor: disabled
2009/02/05 3:22:04.821 661 s camd 3.3x: disabled
2009/02/05 3:22:04.821 661 s camd 3.5x: disabled
2009/02/05 3:22:04.821 661 s cs378x: disabled
2009/02/05 3:22:04.822 661 s newcamd: disabled
2009/02/05 3:22:04.822 661 s radegast: disabled
2009/02/05 3:22:04.822 661 s cs380x: disabled
2009/02/05 3:22:04.825 661 s logger started (pid=662)
2009/02/05 3:22:04.828 661 s resolver started (pid=663, delay=30 sec)
2009/02/05 3:22:04.831 661 s proxy started (pid=664, server=xx.xx.xx.xx)
2009/02/05 3:22:04.836 661 s dm: initialized (pid=665,
[email protected]et)
2009/02/05 3:22:04.845 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:06.175 665 c01 plain dm, emm=0-client 127.0.0.1 granted (root, au=0)
2009/02/05 3:22:06.176 665 c01 detected box type UFS910 E2
2009/02/05 3:22:06.765 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:06.765 664 p02 expected MSG_CLIENT_2_SERVER_LOGIN_ACK (E1), received FF
2009/02/05 3:22:06.766 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:06.769 665 c01 root (0500&023700/7922/0002/40:56B9,00-00): not found (498,2 ms)
2009/02/05 3:22:06.770 665 c01 root (0500&030600/7922/0002/49:64CA,00-00): not found (432,2 ms)
2009/02/05 3:22:08.750 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:08.751 664 p02 expected MSG_CLIENT_2_SERVER_LOGIN_ACK (E1), received FF
2009/02/05 3:22:08.752 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:08.753 665 c01 root (0500&023700/7922/0002/40:56B8,00-00): not found (281,1 ms)
2009/02/05 3:22:08.754 665 c01 root (0500&030600/7922/0002/49:64CB,00-00): not found (216,2 ms)
2009/02/05 3:22:08.755 665 c01 root (0500&020710/7922/0002/40:66AB,00-00): not found (150,3 ms)
2009/02/05 3:22:11.213 665 c01 root (0500&020710/7922/0000/40:66AA,00-00): timeout (5008,1137717261 ms)
2009/02/05 3:22:19.206 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:19.206 664 p02 expected MSG_CLIENT_2_SERVER_LOGIN_ACK (E1), received FF
2009/02/05 3:22:19.207 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:19.209 665 c01 root (0500&030600/7922/0002/49:64CA,00-00): not found (470,2 ms)
2009/02/05 3:22:19.209 665 c01 root (0500&020710/7922/0002/40:66AA,00-00): not found (403,1 ms)
2009/02/05 3:22:21.197 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:21.197 664 p02 expected MSG_CLIENT_2_SERVER_LOGIN_ACK (E1), received FF
2009/02/05 3:22:21.198 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:23.683 665 c01 root (0500&023700/7922/0000/40:56B9,00-00): timeout (5011,1137729731 ms)
2009/02/05 3:22:29.341 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:29.341 664 p02 expected MSG_CLIENT_2_SERVER_LOGIN_ACK (E1), received FF
2009/02/05 3:22:29.342 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:29.344 665 c01 root (0500&023700/7922/0002/40:56B8,00-00): not found (471,2 ms)
2009/02/05 3:22:29.345 665 c01 root (0500&030600/7922/0002/49:64CB,00-00): not found (402,2 ms)
2009/02/05 3:22:31.337 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:31.337 664 p02 expected MSG_CLIENT_2_SERVER_LOGIN_ACK (E1), received FF
2009/02/05 3:22:31.338 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:33.813 665 c01 root (0500&020710/7922/0000/40:66AB,00-00): timeout (5006,1137739861 ms)
2009/02/05 3:22:37.165 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:37.165 664 p02 expected MSG_CLIENT_2_SERVER_LOGIN_ACK (E1), received FF
2009/02/05 3:22:37.166 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:37.168 665 c01 root (0500&030600/27D9/0002/4D:5C86,00-00): not found (520,1 ms)
2009/02/05 3:22:37.169 665 c01 root (0500&020710/27D9/0002/4E:63DA,00-00): not found (520,2 ms)
2009/02/05 3:22:37.505 665 c01 root (0500&020710/27D9/0002/4E:63DB,00-00): not found (1,0 ms)
2009/02/05 3:22:37.522 665 c01 root (0500&023700/27D9/0002/4E:53C8,00-00): not found (3,1 ms)
2009/02/05 3:22:37.522 665 c01 root (0500&030600/27D9/0002/4D:5C87,00-00): not found (2,1 ms)
2009/02/05 3:22:39.169 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:39.169 664 p02 expected MSG_CLIENT_2_SERVER_LOGIN_ACK (E1), received FF
2009/02/05 3:22:39.170 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:41.653 665 c01 root (0500&023700/27D9/0000/4E:53C9,00-00): timeout (5006,1137747701 ms)
2009/02/05 3:22:48.048 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:48.048 664 p02 expected MSG_CLIENT_2_SERVER_LOGIN_ACK (E1), received FF
2009/02/05 3:22:48.049 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:48.051 665 c01 root (0500&023700/27D9/0002/4E:53C9,00-00): not found (545,1 ms)
2009/02/05 3:22:48.051 665 c01 root (0500&030600/27D9/0002/4D:5C86,00-00): not found (532,1 ms)
2009/02/05 3:22:50.055 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:50.055 664 p02 expected MSG_CLIENT_2_SERVER_LOGIN_ACK (E1), received FF
2009/02/05 3:22:50.056 664 p02 proxy xx.xx.xx.xx:50046 newcamd525 (fd=4)
2009/02/05 3:22:52.513 665 c01 root (0500&020710/27D9/0000/4E:63DA,00-00): timeout (5009,1137758561 ms)
В логе видно not found, timeout...
Может в этом причина ?
