OCTAGON_SF1008_HD_INTELLIGENCE_V10816__30_04_10
for Octagon HD SF 1008 HDTV - INTELLIGENCE :
Changes :
Bug fix. :
- Hangup problem when delete the folder in Play List fix.
- Local offset and summer time not support after factory reset fix.
- Unicable bug fix. when standby
- DVB Subtitle - subtitle display size problem on the screen when data is as HD video size fix.
- When plugin auto start, USB detect problem if remove the USB then insert again after
rebooting the STB with USB inserted.
- Hangup when move the folder which contains ts file fix.
- Not able to process if network drive folder name has space fix.
- FDU Channel data deletes when user area format fix.
- Hangup when mp3 file play on WIFI WPAPSK mode fix.
- Time not updating in timer setting menu fix.
- SF1008 - Single Tuner Model: 2 channels(Same TP) recording by timer or EPG support fix.
- When only plugin folder is exist in Data Transfer menu, not able to open the firmware box fix.
New Functions / improvements :
- WIFI function modified : ssid scan function and simplificated.
Monitoring function : (Auto setup when re-plug/link)
- MKV H264 1080p FULL HD files supported. Hangup or not able to play the mkv
--> Most of the files are able to play but specific file break while play
- Blocking problem if network link disconnected when using the net driver.(Not possible while rec.)
- TS recording / decoding speed. (Break problem when HD decoding / recording)
- Font size adjustable when using User font - Font Size : -5 ~ +5
--> Menu - Configuration - Language Setting : User Font File
--> Firstly create /var/font Folder and copy own user font
--> Menu - Configuration - Language Setting : User Font File select
--> User Font Language : All
--> User Font Size Correction : -5 ~ +5
- Delete Stored position (Delete stored System Data)
--> Menu - Installation - System Recovery : Delete stored position
- Mgcamd imporved
- Commercial Skip (TrickMode) extented
--> Menu - Configuration - Recording Option - Commercial Skip : 10 Sec., 30 Sec., 1 Min., 2 Min., 4 Min.
Modification :
- Russian OSD text revise
- SF1008 - Single Tuner Model :
--> Menu - Configuration - Display Setting - Front Display scroll : off,Continuous,Once enabled !
- PTI Plugin Structure changed. Check new PTI Plugin Document (octagon.gmc.to)
System Information :
- API Version 27.May
- Driver Version 13.April
- Root File System 6.April
- Build Version : 3006
Online SW upgrade : oud.gmc.to
Обсуждение здесь: Софт OCTAGON SF1018 & SF1008 V10816 от 30.04.10 ОБСУЖДЕНИЕ.
Changes :
Bug fix. :
- Mgcamd imporved
Modification :
