CUBEREVO HD TWIN TUNER PVR
chewbacca
Модератор "AzBox"
Вот новая модель, развитие 9000-го
The CubeRevo is similar to the popular AB Com IP Box 9000 apart from it comes with a far superior updated front panel display which provides extended Tuner and Recording information, which is not available on the AB Com version. The CubeRevo is from the original manufacturer and software writers DGStation.
To date the CubeRevo is by far the best box we have seen, they don't get much better than this, build quality and audio/video quality is excellent in both high and standard definition and across all DVB formats S/S2/T/C. The CubeRevo features are amazing and third party support on the internet is endless.
The CubeRevo comes with Plug and Play tuners (2xDVB-S2 as standard) which can be switched between Satellite, Cable and Terrestrial, we keep a full range of tuners in stock. On our site we offer a couple of cost and no-cost tuner options but if you have a particular requirement please let us know by email or telephone.
Amongst the many connectors on the rear the CubeRevo includes an ethernet port which means you can share its connection as well as connect it to your home network and drop files directly on the hard drive using ftp. On the internet you can also view the units menus via its Web Interface from anywhere, allowing you to see EPGs, set recordings and even download the recorded files.
Furthermore the CubeRevo is very well supported with third party applications and Plug-Ins on internet forums offering a whole host of features such sharing applications (gbox, newcs, cccam), emulators for the two in-built card slots and even email plugins. There are also two Common Interface CAM slots and DivX playback is also an option coming soon. Software updates can be performed over your LAN, via USB cable or USB Keyring. The remote is multi-functional for TV and other items.
Files/recordings can also be saved to any USB keyring.
  • LINUX open source (some parts under the terms of GPL, accordingly expandable)
  • DVB-S compliant, DVB-S2, DVB-T, DVB-C supported (shipped with 2xDVB-S2)
  • Smart tuner supported(Plug & Play)
  • MPEG-2 MP@HL Video Decoder
  • MPEG-4 AVC/H.264 HP@L4 Video Decoder
  • DIVX supported (coming soon)
  • MP3 decoder
  • Dolby AC3 downmix decoder
  • HDMI with HDCP supported
  • Multi-format Audio Decoder
  • High Definition and Standard Definition
  • DVB Common Interface (2 slots) supported
  • Format resolution: 1080i, 720p, 576p
  • USB 2.0(Host) supported
  • USB 1.0(Client) supported
  • Network Interface Supported( high speed Ethernet
  • VFD Display : Capability for display of various information
  • SCPC and MCPC receivable from C/Ku-band satellites
  • Channel list editing
  • Favorite channel list editing
  • True-color On-Screen Display (OSD)
  • Full Picture In Graphic (PIG) function
  • Electronic Program Guide (EPG) for on screen channel information
  • Subtitle & Teletext supported
  • Parental lock facility by channel and program event
  • Silver color and Black color supported
  • SATA-I(1.5Gbps) supported
Added hardware parts for future use.
  • S-ATA cable and 3.5" HDD cradle(bracket)
  • 2 x mini PCI socket for several kinds of tuner
  • 2 x smartcard reader
  • IPTV function to be added
Цена £479.00​
