Gemini2 Projekt v1.70 Для DreamBox 7025S
Features:
* Own Addon-Server via internet
* Downloading and installation of additional features via internet from Gemini server
* EMM- und ECM- Display switchable
* Behaviour of infobar can be changed via Menu
* System Info: Many extra box infos (for example harddisk-temperature, storage usage, mountpoints)
* Extra Menu: Settings to many extras like Inadyn, HTTPD, NFS-Server, calendar
* Own Scripts can be started via Blue Panel
* Calendar including reminder (can be changed via /etc/calendar.xml)
* Dreambox can be used as printserver
* Kernel modules can be reload separately
* Create your own Satellites.xml
* Support for CDROM/DVD, no matter if IDE or USB port
* Display of current channel stream rates
* SWAP setup and start automatically
* HDPARM values for harddisk can be changed via menu
* Storage location of epg.dat can be changed via menu
* Display of CaIDs via Infobar
* Password can be changed via menu
* Autocamd
* camd scricpt can be edited
* HDD performance
* Weather Plugin with 10 days forecast
* RSS/RDF reader with TOP list from RSS-scout
* Active PiP
* Blue Button with following functions: 1 x (short) Blue Panel, 2 x (short) Blue Panel -> Extras/Settings, 1 x (long) PiP
* The image does now contain a useraddon.xml in /etc ml to enter an own addon server which will additionally be displayed in download menu. The file actually contains a example.
Neu:
* Nemesis skins
* Manually installation of addons can be choosen via browser
* IPK can be choosed and installed via browser
* Installation of plugins without Enigma restart
* Remote control can be choosen classic (Neutrino) or standard (Enigma)
* Settings of Infobar enhanced
This Images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
Download via Database
Thanks a lot and have fun
Your Gemini-Team
Support: www.i-have-a-dreambox.com
Качаем ТУТ
Features:
* Autocamd
* HDD performance
* Active PiP
Neu:
* Nemesis skins
Your Gemini-Team
Качаем ТУТ
