Gemini2 v1.60 для DreamBox 7025
seal
Администраторы
Features:
* Own Addon-Server via internet
* Downloading and installation of additional features via internet from Gemini server
* EMM- und ECM- Display switchable
* Behaviour of infobar can be changed via Menu
* System Info: Many extra box infos (for example harddisk-temperature, storage usage, mountpoints)
* Extra Menu: Settings to many extras like Inadyn, HTTPD, NFS-Server, calendar
* Own Scripts can be started via Blue Panel
* Calendar including reminder (can be changed via /etc/calendar.xml)
* Dreambox can be used as printserver
* Kernel modules can be reload separately
* Create your own Satellites.xml
* Support for CDROM/DVD, no matter if IDE or USB port
* Display of current channel stream rates
* SWAP setup and start automatically
* HDPARM values for harddisk can be changed via menu
* Storage location of epg.dat can be changed via menu
* Displaying CaIDґs in the Infobar
* Change the password out from menu
* Autocamd
* camd scricpt can be edited
* HDD-Performance
New:
* Weather Plugin with a 10 day preview
* rss/rdf Reader with TOP list from rss-scout
* PIP is now active
* Blue Button now has the following functions: 1 x (short) Blue Panel 2 x (short) Blue Panel Extra/Settings 1 x (long) Picture in Picture (PIP)
* Youґll find the useraddon.xml in /etc/useraddon.xml where you can add your own Addon Server. At the moment there is an example entry and would also be shown additonally in the BP beneath download and install
Attention:
* Do not use old Gemini2 skins!
This Images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
Download via Database
Thanks a lot and have fun
Your Gemini-Team
Качаем ТУТ
