allllex
Имидж от группы
Nemesis 2.2 SVN 073 - 26-02-2011
http://www.genesi-project.it/forums/showthread.php?17341-Nemesis-2.2-SVN-073
Сайт разработчика: http://www.genesi-project.it/forums/forum.php
По умолчанию установлен только эмулятор gbox. Возможности скачать другие эмуляторы с сайта автоматом, нет.
Как установить эмуляторы, написано здесь:
http://forum.sat-expert.com/340354-post19.html
allllex
Форум умер...
Но имидж обновился до Nemesis2.1
http://www.file-upload.net/download...-dm800se-e2-OE-1.6-_15-02-2011-16-16.zip.html
English Technical Info:
• OE git repo opendreambox-1.6 of: 11-02-2011
• Enigma git repo Experimental of: 15-02-2011
• Enigma2-Plugins git repo of: 14-02-2011
• Linux version 2.6.18-7.4-r9.0 (r9.1 for DM8000)
• Web Interface: 1.6.6
• Busybox 1.15.3-r24.6
• Date image 15-02-2011 svn 066
• Bitbake 1.8-dream
• Secondstage Last
• Drivers date Last
Function keys:
• BLUE - Panel EDG-Nemesis
• BLUE> 1s Extensions
• 2x BLUE - Addons
• Yellow - Timeshift
• YELLOW> 1s Plugin
• GREEN-EPG Control Center
• GREEN> 1s subservices
• RED - Record Menu
Main features:
• Panel EDG-Nemesis 2.1
• No reboot after installing the enigma settings from Blue Panel
• Reduced reboots after installation of enigma Blue Panel
• New ADDONS Management (the old Repository will be stopped)
• Skin Based on HD-Glass 15 by shamann
• Shortcut for Package Manager IPK on Blue Panel (Blue->Blue)
• Shortcut for Software Update on Blue Panel (Blue->Blue)
• Shortcut for Extansions Manager on Blue Panel (Blue->Blue)
• Shortcut for Network Browsing on Blue Panel (Blue->Red)
• Improvement/Fixed Extansions Manager
• Improvement/Fixed Software Update
• Improvement/Fixed OPKG Package Manager
• Manage Panel for OPKG Package Manager
• Fade Management for InfoBar (On Show, On Hide, On Zap)
• Full support for e2_loadepg
• Support for your own scripts
• Manage Start / Stop Services
• Manage Start / Stop Services on boot
• Manage kernel modules
• New Information System
• Separate Management Third Party Programs
• Support for a private server addons
• Picon support for OSD channel name or reference
• Support for LCD Picon name or reference channel (800 and 8000)
• OLED Picon support for name or reference channel (800se)
• Mode Vision LCD
• Support for swap files
• Support for EZ-Inadyn IpUpdate
• Support Proxy
• Support OpenVPN
• Replaced with OpenSSH Dropbear
• Support for SFTP
• Support for readers Smargo
• Support for readers Omnikey
• Support for USB WiFi (500hd, 800 and 800se)
• Samba server, Samba client, NFS Server
• Running Linux commands
• Choice InputBox (default) or VirtulaKeyBoard (experimental), for EPG Search and Run Command
• Fixed Mediaset EPG
• EPG black list, excluding channel MHW epg (see / etc/enigma2/epg.blacklist)
• Support for DVD writer external
• Support for mkv files
• Support for formatting USB Device
• Support for most of the pens DVB/T USB on the market
• New Management Panel to Manage/Install DVB/T USB Drivers
• Updating image directly from the Software Update
Extra Info Bar:
• Manual or Automatic
• Setting Auto show delay
• Set delay information ECM
• Set delay information EMM
• Picon SAT
• Picon Provider
• Picon Encoding
• Add management for new 4 encoding
• Info Orbital position for most of the SAT
• Show / Hide Network
• More Info
EPG Control Center:
• Setting path EPG USB, CF or HDD
• Integrated CrossEPG loader directly form Sat, by Skamania
• Integrated CrossEPG plugin by Skamania
• Manual EPG download
• Scheduled EPG download, via Enigma 2 Timer
• Load EPG directly into the cache without restarting enigma2 enigma2
• Backup EPG Cache enigma2
• Clearing the Cache enigma2 EPG
• Log scheduled download CrossEPG
• EPG Search
• History Research EPG
Kernel Modules:
• OpenVpn (tun)
• Usb To Serial (usbserial, ftdi-sio, pl2303)
• Nfs Server (nfsd)
• smbfs
• udf
• Wifi
• USB DVB/T
• And more
vadiaravolk
Nemesis 2.2 HD
800seHD
[B]Info Tecniche Italiano:[/B]
• Enigma git repo Experimental of: 23-02-2011
• Date image SVN(073), 25-02-2011
• Bitbake 1.8-dream
• Secondstage #82
• Drivers date Last
[B]Function keys:[/B]
• BLUE - Panel Nemesis
• 2x BLUE - Addons
• YELLOW> 1s Plugin
• RED - Record Menu
[B]Main features:[/B]
• Panel Nemesis 2.2
• Mode Vision LCD
• Support Proxy
• Support OpenVPN
• Support for SFTP
[B]Extra Info Bar:[/B]
• Picon SAT
• Picon Provider
• Picon Encoding
• More Info
[B]EPG Control Center:[/B]
• EPG Search
[B]Kernel Modules:[/B]
• OpenVpn (tun)
• Nfs Server (nfsd)
• smbfs
• udf
• Wifi
• USB DVB/T
• And more
[B]Bug Conosciuti:[/B]
• Display dm800se
• Gestione periferiche DM8000 (cmq risolvibile manualmente)
Special Thanks to betatester
Special Thanks to Xplanet for Logo
Special Thanks to blu8 for spinner
Special Thanks to shamann for based skin
Special Thanks to developper skaman for CrossEPG
Very Special Thanks to SifTeam's developpers for USB DVB/T Modules Support (Very Great Work)
Special Thanks to developper Claudio72 for StayUP
Special Thanks to Lukkino for opentv source code
!!! ATTENZIONE - IMPORTANTE:
!!! QUESTO FIRMWARE NON CONTIENE CHIAVI, NE' EMULATORI, NE' INDIRIZZI PER SCARICARE MATERIALE ILLEGALE DI NESSUN TIPO.
!!! EDG-NEMESIS NON E' RESPONSABILE IN NESSUN MODO DELL'USO CHE GLI UTENTI NE FARANNO, DI LORO SPONTANEA VOLONTA'.
!!! WARNING - IMPORTANT DISCLAIMER:
!!! THIS FIRMWARE DOES NOT INCLUDE KEYS, NO EMULATORS, NO URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
!!! EDG-NEMESIS IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
NON DIAMO SUPPORTO ALLE IMG CARICATE IN MULTIBOOT-WE DO NOT SUPPORT THE LOAD IMG MULTIBOOT
СКАЧАТЬ
edgar3390
Кто подскажет, на nemesis возможно найти и поставить плагин раскладки neutrino или нет?
allllex
Нет, там навороченный имидж с навороченной панелью, который использует свой файл keymap.xml. Поэтому стандартная замена этого файла в папке /enigma2 ни к чему хорошему не приводит.
Единственное, что ты можешь сделать, руками править сам файл keymap.xml. Он находится по пути, где лежат все расширения в питоне.
edgar3390
allllex
Пройди по пути /usr/share/enigma2/
Там лежит файл keymap_neutrino.xml
Вот его попробуй переименуй в keymap.xml. А оригинальный где нибудь сохрани на всякий случай. И посмотри, что получится. Не понравится, вернешь оригинальный обратно.
ОК - Список
Вверх или вниз - Переключение каналов
Отдельно инфобара нет.
edgar3390
ОК - Список
Других вариантов нет? Хотелось бы, чтоб инфобар был влево-вправо, а вверх-вниз -переключение каналов. Но, в принципе и так сойдет...
allllex
Нет, открывай его и правь, если умеешь.
gold99
allllex, что может быть с erpg плагином,постави имидж с нуля ,загрузил плагин на канал передач,все работало всю неделю,с понедельника после обеда загружаю программу передач,все загружается,а программа не появляется на каналы нтв мир,украина,и т.д..ставишь по новой прошивку все появляется..
allllex
Если имеется ввиду Епг на тех каналах, где его не официально, то надо обновляться в понедельник вечером. На некоторый каналы программа задерживается. Автообновление не предусмотрено. На вторую часть вопроса отвечаю, не знаю, у меня такого не было.
gold99
allllex, спасибо большое за ответ!!!
Добавлено через 35 минут
allllex, извини,сейчас подключил свой старый 800 дрим,прошивка такая же,и erpg загрузилось нормально,что за хрень..? У меня так уже было на 800se,после перепрошивки все грузилось нормально...мистика какая то..
allllex
Могу только сказать, что епг после обновления появляется не мгновенно. Надо походить и постоять на каналах. И не выключать бокс на ночь. Его нормальный режим отключения Standby. У меня тоже дрим 800 в одной комнате, а у меня дрим800SE. Везде стоит одна и та же программа закачки ЕПГ и никакой разницы в ЕПГ у меня нет.
LuckyManX
а вот графическое епг у них глючное...
то которое надо вызывать по долгому нажатию на инфо...
ловил зеленку на нем кучу раз... часть инфы просто не отображалась...
edgar3390
Установил на немесис oled пиконы по следующей инструкции:1. Распаковываю файл skin_user_xml.zip и копирую на бокс в/etc/enigma2
2. Распаковываю файл picon_oled.zip, (имя каталога должно быть "picon_oled"") и копирую на бокс в /media/usb .
Но возникает проблема, при переключении каналов на другой провайдер, некоторые пиконы отображаются на дисплее бокса не корректно. Подскажите, как устранить проблему?
Alexdars23
Подскажите плиз как на сей имидж v2-2 прикруть эмулятор, имидж стоит на USB флешке с ВА, понимаю что с помощью скрипта, но постоянно пишет ошибку - то нет сязи с сервером, то не верный формат HTML файла. Думаю многим полезна будет эта инфа, от тех, у кого эмуль работает.
gold99
Доброго дня всем...!!! Подскажите,как прикрутить 3G модем на этот имидж..?
Alexdars23
LuckyManX,
Спасибо разобрался, хотя обычным это не назовёшь, для имиджа EDG-NEMESIS 2.2 нужен свой extra url который кидаем в папку /ect, перегрузаемся жмем два раза синию кнопочку и скачиваем эмуль. Вот тут инфа по этому вопросу http://dream.altmaster.net/showthread.php?t=3066&page=4 Ещё раз всем спасибо!
edgar3390
Ну кто может, ответьте пожалуйста, у кого как работают на немесисе олед пиконы, наблюдаются глюки или нет?
