V0.82
- second try fixing caids tunneling (with PremiereHD card on betacrypt, i can't test it so, i don't know if it works or not)
- first try fixing caid 0603 (same as premierehd, i can't test it, please report if it works or not)
- fixed long ecm bugs
- full support for cccam 2.1.0 protocol
- many minor fixes for stability (hope this version will be better than last one)
KNOWN BUG: sometimes with the timeshift option enabled you can occur problems during standby or channel change,
so you need to restart the cam
Судя по списку изменений должен понимать длинные ECM. Говорят очень быстро соображдает.
