Ufs 922
The HDTV twin receiver UFS 922 is
suitable for the reception of digital satellite
TV and radio programmes.
This unit enables reception of both highdefi
nition TV (HDTV) and conventional TV
(SD).
The multifunctional receiver is equipped
with two independent reception and
signal processing systems as well as an
integrated hard disk with a 500-Gbyte
memory capacity.
Depending on the broadcaster‘s data
rate, this feature allows one to record
approx. 300 hours of standard-TV and
radio broadcasts, as well as roughly
100 hours of HDTV broadcasts and to
view these either in real-time or timeshifted
(timeshift function) without any
loss in quality.
The integrated Common Interface can
accommodate two CA modules for Pay-
TV programmes.
The receiver‘s 16-digit alphanumeric
display shows the programme names,
while 16 status icons inform you on the
current receiver status (e.g. Dolby Digital,
HD, timer ...).
The HDMI interface allows one to
connect the receiver to the HDMI
interface on a suitable fl at-screen
TV for optimal viewing comfort. A
YPbPr connection, a video composite
connection and two Scart connections
are additionally provided. The receiver is
fi tted with an optical audio output so that
the Dolby Digital data stream AC 3 can
be transmitted to a Dolby Digital stereo
system.
The integrated Premium tvtv-EPG is
not only a well-structured electronic TV
magazine, but also offers a facility to
take programmes from the respective
EPG and include them in the timer.
In addition, it is possible to sort
programme information according
to categories and to create and
administrate one‘s own programme tips.
What‘s more, the Premium tvtv-EPG
also features an extensive search
function which enables one, for
example, to search for reruns, actors or
key words.
The USB port on the receiver front panel
makes it possible to update receiver
software.
The receiver‘s operational system is
LINUX-based.
The receivers are available in black and
silver.
