Не прошивается Dbox2
Optima
Шью Dbox2 Nokia утилиткой DBOX2 Image-Flashing-Assistent Всё проходит гладко но в конце...... вот лог
PHP:
ëdebug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS
debug: BMon V1.0  mID 01
debug: feID dd    gtxID 0b
debug: fpID 5a     dsID http://Hallenberg.com
debug: HWrev X5  SWrev 0.81
debug: B/Ex/Fl(MB) 32/00/08
WATCHDOG reset enabled
debug: autoboot aborted from terminal
dbox2:root>
dbox2:root> seteth
ethaddr 0x1001ffe3
ethaddr: 00:50:9c:1b:14:40
dbox2:root>
dbox2:root> boot net net net net net net net net net net
debug:
BOOTP/TFTP bootstrap loader (v0.3)
debug:
debug: Transmitting BOOTP request via broadcast
debug: Given up BOOTP/TFTP boot
boot net failed
debug:
debug:
debug: Got BOOTP reply from Server IP 192.168.1.2, My IP 192.168.1.202
debug: Sending TFTP-request for file C/dboxifa_tmp/tftpboot/u-boot
will verify ELF image, start= 0x800000, size= 140008
verify sig: 262
boot net: boot file has no valid signature
Branching to 0x40000
U-Boot 1.1.6 (Tuxbox) (Jan  8 2007 - 22:58:00)
CPU:   PPC823ZTnnA at 67.200 MHz: 2 kB I-Cache 1 kB D-Cache
         *** Warning: CPU Core has Silicon Bugs -- Check the Errata ***
Board: DBOX2, Nokia, BMon V1.0
       Watchdog enabled
I2C:   ready
DRAM:  32 MB
FLASH:  8 MB
FB:    ready
LCD:   ready
In:    serial
Out:   serial
Err:   serial
Net:   SCC ETHERNET
BOOTP broadcast 1
Using SCC ETHERNET device
TFTP from server 192.168.1.2; our IP address is 192.168.1.202
Filename 'C/dboxifa_tmp/tftpboot/u-boot'.
Load address: 0x100000
Loading: *Using SCC ETHERNET device
Filename 'logo-lcd'.
Loading: *##
done
Bytes transferred = 7680 (1e00 hex)
BOOTP broadcast 1
Filename 'logo-fb'.
Loading: *####################################
done
Bytes transferred = 179877 (2bea5 hex)
Options:
  1: Console on null
  2: Console on ttyS0
  3: Console on framebuffer
Select option (1-3), other keys to stop autoboot:  1  0
Bank # 1: INTEL 28F320C3B (32M, bottom boot sect), 32 bit
  Size: 8192 kB in 71 Sectors
  Sector Start Addresses:
    10000000 (RO) 10004000 (RO) 10008000 (RO) 1000C000 (RO)
    10010000 (RO) 10014000 (RO) 10018000 (RO) 1001C000 (RO)
    10020000 (RO) 10040000 (RO) 10060000 (RO) 10080000 (RO)
    100A0000 (RO) 100C0000 (RO) 100E0000 (RO) 10100000 (RO)
    10120000 (RO) 10140000 (RO) 10160000 (RO) 10180000 (RO)
    101A0000 (RO) 101C0000 (RO) 101E0000 (RO) 10200000 (RO)
    10220000 (RO) 10240000 (RO) 10260000 (RO) 10280000 (RO)
    102A0000 (RO) 102C0000 (RO) 102E0000 (RO) 10300000 (RO)
    10320000 (RO) 10340000 (RO) 10360000 (RO) 10380000 (RO)
    103A0000 (RO) 103C0000 (RO) 103E0000 (RO) 10400000 (RO)
    10420000 (RO) 10440000 (RO) 10460000 (RO) 10480000 (RO)
    104A0000 (RO) 104C0000 (RO) 104E0000 (RO) 10500000 (RO)
    10520000 (RO) 10540000 (RO) 10560000 (RO) 10580000 (RO)
    105A0000 (RO) 105C0000 (RO) 105E0000 (RO) 10600000 (RO)
    10620000 (RO) 10640000 (RO) 10660000 (RO) 10680000 (RO)
    106A0000 (RO) 106C0000 (RO) 106E0000 (RO) 10700000 (RO)
    10720000 (RO) 10740000 (RO) 10760000 (RO) 10780000 (RO)
    107A0000 (RO) 107C0000 (RO) 107E0000 (RO)
Filename 'kernel-yadd'.
Loading: *#################################################################
done
Bytes transferred = 675073 (a4d01 hex)
............................................................... done
Un-Protected 63 sectors
## Booting image at 00100000 ...
   Image Name:   dbox2
   Image Type:   PowerPC Linux Kernel Image (gzip compressed)
   Data Size:    675009 Bytes = 659.2 kB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
Starting pid 11, console /dev/console: '/etc/init.d/rcS'
dbox2 - ImageFlashingAssistent
 - Hallenberg.com -
Writing backup: 1024k von 8064k (12%)nfs: server 192.168.1.2 not responding, still trying
------ Extra Informations ------
Selected Network adapter: Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller - Ìèíèïîðò ïëàíèðîâùèêà ïàêåòîâ (0)
IP-Adress of the Network Adapter: 192.168.1.2
IP-Adress of the Dbox: 192.168.1.202
Comport: Ïîñëåäîâàòåëüíûé ïîðò (COM1)
Operatingsystem: Microsoft Windows XP Professional Service Pack 2 (Build 2600)
CPU 1: AMD Athlon(tm) 64 Processor 3000+ @ 2480 MHz
Filename of the Images: PB-Enigma_2x.img
Imagetype: Two Flashs
DBOX-IFA Version: 2.3
------ Powered by http://www.dboxservice-hallenberg.de ------
Доходит до 12% и всё..выдаёт
PHP:
Что не так?? Единственное не пойму какой IP выставить для Dbox. по умолчанию утилитка сама выставляет 192.168.1.202 и я его не трогаю. Подскажите пожалуйста в чём может быть загвоздка, очень срочно надо прошить ресивер.
Всегда прошываю утилитой Dboxboot и Виндовс98..если не шьётся -ремонт или пробовать снова!
IP никакой не нужно выставлять в тюнере!!!
