2007/06/13 v1.23, tps au (look on U: option), remove old tps.au file if any ! PW mecm. *** experimental @box client (client only, no forwarding), config file - peer.cfg, cards list in /tmp/mg.info,reports itself as version 2.0A (there was no such @box version, can be detected). if @box client enabled, it always will be tryed first for irdeto, ignoring P: option. tested using own local @box "hub", this is recommended mode to use. U:, N:, G:, P: options changed, read config file. osd on disconnect/reconnect to newcamd servers (if S: +02).
исправлен Premiere MECM
