Oscam, Wicardd, MCAS и другие эмуляторы на Openbox
salzaking
MCAS Плагин. Как можно ввести сервер client?
Вход можно Порт. Сервер не открыть окно для ввода.
Если вы не можете войти с помощью пульта дистанционного управления.
BISS ERT HD, ERT1 и ERT2 2 3 ° EAST возможно?
Как можно обновить ключи на файл?
СПАСИБО
    87,7 KB · Просмотры: 6
salzaking
Решение найдено. Введите адрес сервера. Требуется 1407 с дистанционным управлением.
Другой вопрос еще и потому, ключевой файл.
Где вы должны keydata.bin?
под вар / ключи ???
программа KeyEditor редактирует файл keydata.tmp
  • KeyEdit.zip
    290,5 KB · Просмотры: 84
salzaking
No problem. I thought here is English not welcome, so I tried to explain in Russian words!:)
Is it also possible to use BISS with MCAS?
With the Key Editor, it is not possible to add this keys.
Or there are newer finished keydata.tmp with Biss and others to download?
Thanks alot
salzaking
Thanks. I know that Plugin ;-). But with coconut dont work the Biss channels ERT1,2 and ERT HD on 3°East.
Thats because i ask here if its possible with mcas.
You know where i can write of the Problem with coconut Plugin ? Maybe the progger can fix that?
Thanks
salzaking
Need BISS for this Channels, but the problem with this channels, SX6 shows Error, because the Receiver reads the Programs as unencrypted.
With Oscam Ymod it works, Wicard and Mcas or Coconut NOT.
When i use Oscam, it´s not possible to use oscam and X.Cam3.5 for the same Time.
With OScam don´t work my Home Clients.
salzaking
3 Clients for my Homesharing (Irdeto,Viaccess and Nagravision) Server use Oscam. Protocol cccam.
With X-Cam 3.5 i have no problems with that cards. Oscam YMod for SX6 Stapi Error in PMT....
But only in Ymod works the ERT 1, ERT2 and ERT HD channels.
So it would be very fine if the progger from coconot Biss can fix this error ;-)
Do you know where i can post this problem? So that it reads the developer?
Regards
sergik01
What emu is server? X-Cam is a server?
I only know XCAM2 v3.5. But it's a client, not server for cards.
Oscam YMod 18561 - only works with cards.
>> OSCam << ymod cardserver started, build #18561 (sh4-linux-stapi5)
sversion=ymod, build #18561, system=sh4-linux-stapi5
salzaking
Server ist Oscam on Raspberry PI.
Yes i know. Openbox SX6 use only as Client. With X-Cam2 Plugin No Problems.
On Oscam YMod Plugin no Clients works, only oscam.keys with ERT 1 and so on, with it OK.
salzaking
Problem was mcas and coconut Plugin active at same time.
Mcas off and the channels with coconut work.
Thanks for the help here in great forum
wicardd
[email protected]
Для One-Two
Вообще One-Two мне хорошо помог, дал направление, куда двигаться.
Спасибо! Возвращайтесь!
Но вот новость. Пару дней назад Oscam стал открывать только Первый и НТВ.
Пришлось заменить название файла snippet.tbl91 на snippet%04X.tbl91и такое же название в конфиге. В этом случае возможно его автообновление.
В итоге в конфиге надо писать (работает):
[3kemu external /var/keys/libdreemu.so ua=6600000000000000 params=/var/keys/ee.bin ident=4ae1:11 postdr=3kicg delay=0 emmcache=1,3,2 group=1]
[3kicg external /var/keys/libdreicg.so emmfilter=91 ua=ED000002 params=/var/keys/initial_snippet.bin,/var/keys/snippet%04X.tbl91 ident=4ae1:fe,11 emmcache=1,3,2 delay=0 group=2]
