Я чувствовал где-то подвох. СПАСИБО.mikola, просто надо дать команду сохранить настройки saveenv
Мой лог при старте.
Кто-что подскажет.
Board: STb7100-mboard
U-Boot 1.1.2 (STLINUX_2_0p1) (May 30 2007 - 16:03:49)
DRAM: 32 MB
write time out = 1, clock = 40
Flash: 16 MB
In: serial
Out: serial
Err: serial
pll0 freq 531
pll1 freq 399
Net: VFD_Driver Init
VFD_Controller Type : NEW Kathrein VFD
board_version = 3
Button_value = 7
Hit any key to stop autoboot: 0
## Booting image at a0040000 ...
Image Name: Linux 2.6
Image Type: SH-4 Linux Kernel Image (gzip compressed)
Data Size: 1714625 Bytes = 1.6 MB
Load Address: 84401000
Entry Point: 84402000
Verifying Checksum ... Bad Data CRC
STB7100-REF>
deejay,
при реанимации вставляй этот МАС адрес: 00:1D:EC:00:3B:E9 может поможет, это мак китайца.
Я ещё пару месяцев назад говорил модерам .. уберите этот чёртов мак (setenv ethaddr 0:50:fd:ff:78:ce) с фака, хорош народ путать.
6th Erasing
CLK_BCH_HDMI : 108.0
TCP bic registered
6th E
TCP highspeed registered02MHz
NET: Registered protocol family 1
CLK_D
NET: Registered protocol family 17
CLK_RTC
VFS: Mounted root (cramfs filesystem) readonly.st-copr
Console: colour dummy device 80x
Freeing unused kernel memory: 88k freed
Dentry cache hash tabl
/etc/init.d/rcS running...3
mount: Can't find / in /etc/fstab
remap_area_pte: p
: Successc 0
mount: Mounting / on (null) failed: Success
remap_area_pte: new pte 353e
Mounting other file systems...[ OK ] 84
Mount-cache hash tab
Bringing up the loopback interface...[ OK ]
Setting up hostname...(none)
6th Erasing 89
[ OK ]PU: STb7
BusyBox v1.1.0 (2006.03.02-09:48+0000) Built-in shell (ash)
FSYN1_
6th Erasing
io scheduler anticipatory registered Writing 77
280 coprocessor_mem=2m@0x04000000,2m@0x04200000n
io scheduler deadline registered
PARAM : stdin=serial
6th Writing
PARAM : stdout=serialcheduler cfq register
the reference tree was released on W650
stos_core: module license 'ST Microelectronics' taints kernel.
stos_core_init_module(): Initializing STOS Module
stcommon_core_init_module(): Initializing STCOMMON Module
Setting all Group priorities done
PTI Clock: Cut 3.0 detected -> setting PTI workaround clock.
TC_Ram test...
Writing...
Reading...
ok
Preproc Clock: Cut 3.0 detected -> setting Preproc clock.
stpio_core_init_module(): Initializing STPIO Module
Load module fdma [254] by insmod (pid 112)
STFDMA_ClbckMgr: task created ... Priority=99
Load module stpti4_core by insmod (pid 114)
Load module stclkrv_core by insmod (pid 115)
hdmi_i2c_init : Initializing I2CHDMI kernel Module
the adapter name is i2c-ssc-0 number 0
the adapter name is i2c-ssc-1 number 1
the adapter name is i2c-ssc-2 number 2
