Board: STb7100-mboard
U-Boot 1.1.2 (STLINUX_2_0p1) (May 30 2007 - 16:03:49)
DRAM: 32 MB
write time out = 1, clock = 40
Flash: 16 MB
In: serial
Out: serial
Err: serial
pll0 freq 531
pll1 freq 399
Net: VFD_Driver Init
VFD_Controller Type : NEW Kathrein VFD
board_version = 3
Button_value = 7
Hit any key to stop autoboot: 1 0
## Booting image at a0040000 ...
Image Name: Linux 2.6
Image Type: SH-4 Linux Kernel Image (gzip compressed)
Data Size: 1714625 Bytes = 1.6 MB
Load Address: 84401000
Entry Point: 84402000
Verifying Checksum ... OK
Starting kernel console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysarea=1280 coprocessor_mem=2m@0x04000000,2m@0x04200000 - 0x00000000 - 0 ...
Linux version 2.6.17.14_stm22_0037 ([email protected]) (gcc version 4.1.1 (STMicroelectronics/Linux Base 4.1.1-23)) #124 PREEMPT Fri Nov 30 14:10:08 KST 2007
STMicroelectronics STb7100 Reference board initialisation
STb7100 version 3.x
Built 1 zonelists
Kernel command line: console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysarea=1280 coprocessor_mem=2m@0x04000000,2m@0x04200000
st-coprocessor: Failed to reserve memory at 0x04000000
st-coprocessor: Failed to reserve memory at 0x04200000
PID hash table entries: 256 (order: 8, 1024 bytes)
Using tmu for system timer
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 29952k/38912k available (2849k kernel code, 8948k reserved, 360k data, 88k init)
PVR=04061100 CVR=30480000 PRR=00009100
I-cache : n_ways=2 n_sets=256 way_incr=8192
I-cache : entry_mask=0x00001fe0 alias_mask=0x00001000 n_aliases=2
D-cache : n_ways=2 n_sets=512 way_incr=16384
D-cache : entry_mask=0x00003fe0 alias_mask=0x00003000 n_aliases=4
Mount-cache hash table entries: 512
CPU: STb710x
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
NET: Registered protocol family 2
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 2048 bind 1024)
TCP reno registered
bigphysarea: Allocated 1280 pages at 0x847b1000.
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Device probe found data for platform device lirc
lirc_dev: IR Remote Control driver registered, at major 61
lirc_dev: lirc_register_plugin: sample_rate: 0
lirc_dev: lirc_register_plugin: plugin lirc_stm owner 00000000
STM LIRC plugin has IRQ 125
Lirc STM: Using IRB mode
STMicroelectronics LIRC driver configured
STPIO layer initialised
STMicroelectronics ASC driver initialized
ttyAS0 at MMIO 0xb8032000 (irq = 121) is a asc
ttyAS1 at MMIO 0xb8033000 (irq = 120) is a asc
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
s_env_mac[0] = 0
s_env_mac[1] = 0
s_env_mac[2] = :
s_env_mac[3] = 5
s_env_mac[4] = 0
s_env_mac[5] = :
s_env_mac[6] = f
s_env_mac[7] = d
s_env_mac[8] = :
s_env_mac[9] = f
s_env_mac[10] = f
s_env_mac[11] = :
s_env_mac[12] = 7
s_env_mac[13] = 8
s_env_mac[14] = :
s_env_mac[15] = c
s_env_mac[16] = e
get ether addr = 0, 50, fd, ff, 78, ce
mac hi address = ce78, lowaddress = fffd5000
SMSC: --> init_module()
SMSC: Driver Version = 1.21
SMSC: Compiled: Aug 11 2007, 14:46:15
SMSC: Platform: ST40 STMICRO r3
SMSC: Driver Parameters
SMSC: lan_base = 0x00000000, driver will decide
SMSC: bus_width = 0, driver will autodetect
SMSC: link_mode = 0x7F, 10HD,10FD,100HD,100FD,ASYMP,SYMP,ANEG
SMSC: irq = 2
SMSC: int_deas = 0xFFFFFFFF, use platform default
SMSC: irq_pol = 1, IRQ output is active high
SMSC: irq_type = 1, IRQ output is Push-Pull driver
SMSC: rx_dma = 256, RX will use PIO
SMSC: tx_dma = 256, TX will use PIO
SMSC: dma_threshold = 200
SMSC: mac_addr_hi16 = 0x0000CE78
SMSC: mac_addr_lo32 = 0xFFFD5000
SMSC: debug_mode = 0x00000007
SMSC: tx_fif_sz = 0x00050000
SMSC: afc_cfg = 0xFFFFFFFF, driver will decide
SMSC: tasklets = 0, Tasklets disabled
SMSC: phy_addr = 0xFFFFFFFF, Use internal phy
SMSC: max_throughput = 0xFFFFFFFF, Use platform default
SMSC: max_packet_count = 0xFFFFFFFF, Use platform default
SMSC: packet_cost = 0xFFFFFFFF, Use platform default
SMSC: burst_period = 0xFFFFFFFF, Use platform default
SMSC: max_work_load = 0xFFFFFFFF, Use platform default
SMSC: -->Smsc911x_init(dev=0x846E45CC)
SMSC: --> Platform_Initialize
SMSC: Lan Base at 0xA2000000
SMSC: <-- Platform_Initialize
SMSC: dwLanBase=0xA2000000
SMSC: LAN9115 identified, dwIdRev==0x01150002
SMSC: FPGA_REV == 0x00000000
SMSC: <--Smsc911x_init(), result=0
SMSC: Interface Name = "eth0"
SMSC: <-- init_module()
nwhw_config: device not found
ata1: SATA max UDMA/133 cmd 0xB9209000 ctl 0xB9209820 bmdma 0x0 irq 170
ata1: SATA link down (SStatus 0)
scsi0 : sata_stm
Generic ST boards onboard flash device: 0x01000000 (16.0Mb) at 0x00000000
Onboard_Flash: Found 1 x16 devices at 0x0 in 16-bit bank
Onboard_Flash: Found 1 x16 devices at 0x800000 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Onboard_Flash: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 2
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Creating 8 MTD partitions on "Onboard_Flash":
0x00000000-0x00020000 : "Boot firmware : 0xA000.0000-0xA001.FFFF"
0x00040000-0x00200000 : "Kernel - 0xA004.0000-0xA01F.FFFF"
0x00200000-0x002a0000 : "Config FS - 0xA020.0000-0xA029.FFFF"
0x002a0000-0x004e0000 : "Root FS- 0xA02A.0000-0xA04D.FFFF"
0x004e0000-0x00ae0000 : "APP_Modules 0xA04E.0000-0xA0AD.FFFF"
0x00ae0000-0x00c00000 : "EmergencyRoot 0xA0AE.0000-0xA0BF.FFFF"
0x00c00000-0x01000000 : "OtherData 0xA0C0.0000-0xA0FF.FFFF"
0x00020000-0x00040000 : "BootConfiguration 0xA002.0000-0xA003.FFFF"
ST40_start_host_control
ST40_start_host_control proceeding
ST40-ehci ST40-ehci.2: ST EHCI Host Controller
ST40-ehci ST40-ehci.2: new USB bus registered, assigned bus number 1
ST40-ehci ST40-ehci.2: irq 169, io mem 0xb91ffe00
ST40-ehci ST40-ehci.2: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: Product: ST EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.17.14_stm22_0037 ehci_hcd
usb usb1: SerialNumber: STB7100_EHCI
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver libusual
pegasus: v0.6.13 (2005/11/13), Pegasus/Pegasus II USB Ethernet driver
usb 1-1: new high speed USB device using ST40-ehci and address 2
usb 1-1: Product: USB2.0 Hub
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usbcore: registered new driver pegasus
usbcore: registered new driver asix
usbcore: registered new driver cdc_ether
usbcore: registered new driver net1080
usbcore: registered new driver zaurus
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
stssc layer initialized
STMicroelectronics - Coprocessors st231 Init
st231-0 Coprocessor -------------------------------------------
flags 0001 RAM start at 0xa4000000 size 0x00200000
cop. addr 0x04000000
Channels : Not defined
IRQ : not used
st231-1 Coprocessor -------------------------------------------
flags 0001 RAM start at 0xa4200000 size 0x00200000
cop. addr 0x04200000
IRQ : not used
TCP bic registered
TCP highspeed registered
NET: Registered protocol family 17
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 88k freed
init started: BusyBox v1.2.1 (2007.10.12-18:30+0000) multi-call binary
/etc/init.d/rcS started...
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0001c2c8: 0xfbc8 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0001c2cc: 0xef8f instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0001c2d0: 0x7df7 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0001c2d4: 0xdc63 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0001c2d8: 0xfc38 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0001c2dc: 0xaf52 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0001c2e0: 0xd674 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0001c2e4: 0x6d55 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0001c2e8: 0x8b0a instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0001c2ec: 0x5239 instead
Further such events for this erase block will not be printed
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00041248: 0x8b96 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0004124c: 0x4fce instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00041250: 0x7ba4 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00041254: 0x5270 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00041258: 0xca3d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0004125c: 0x193c instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00041260: 0x04e5 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00041264: 0x17fe instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00041268: 0x7e8c instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0004126c: 0x090f instead
Bringing up the loopback interface...
Setting up hostname...
eth0: 192.168.0.125/255.255.255.0 gw 192.168.0.1 dns 192.168.0.1
SMSC: -->Smsc911x_open(dev=0x846E45CC)
SMSC: -->Lan_Initialize(dwIntCfg=0x00000011)
SMSC: <--g_GpioSetting set
SMSC: <--Lan_Initialize
SMSC: Testing ISR using IRQ 2
SMSC: ISR passed test using IRQ 2
SMSC: Mac Address is set by parameter to 0xCE78FFFD5000
SMSC: -->Phy_Initialize
SMSC: dwPhyId==0x00C0001C,bPhyModel==0x0D,bPhyRev==0x01
SMSC: Successfully Verified Loop Back Packet
SMSC: Passed Loop Back Test
SMSC: <--Phy_Initialize, result=TRUE
SMSC: Tx will use PIO
SMSC: Rx will use PIO
SMSC_WARNING: Gpt_CancelCallBack: Failed
SMSC: <--Smsc911x_open, result=0
SMSC: Multicast: enable dwBitNum=31,addr=01 00 5E 00 00 01
Please press Enter to activate this console. config/start.sh does not exist.... running /app/start.sh
telnetd: bind: Address already in use
PARAM : boot_param_version=9
PARAM : board=stb7100ref_27
PARAM : bootcmd=bootm a0040000
PARAM : bootdelay=1
PARAM : ethaddr=00:50:fd:ff:78:ce
PARAM : bootargs=console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysarea=1280 coprocessor_mem=2m@0x04000000,2m@0x04200000
PARAM : stdin=serial
PARAM : stdout=serial
PARAM : stderr=serial
PARAM : autoload=n
BOOT PARAM VERSION = 9
mount: Mounting none on /proc/bus/usb/ failed: Device or resource busy
/app/start.sh: /app/modules_sys/bin/stapi_modlist_mknod.sh: 14: /app/modules_sys: Permission denied
MODULE_INSTALL_DIR = /app/modules_sys/modules26
BIN_INSTALL_DIR = /app/modules_sys/bin
the reference tree was released on W650
stos_core: module license 'ST Microelectronics' taints kernel.
stos_core_init_module(): Initializing STOS Module
stcommon_core_init_module(): Initializing STCOMMON Module
Setting all Group priorities done
PTI Clock: Cut 3.0 detected -> setting PTI workaround clock.
TC_Ram test...
Writing...
Reading...
ok
Preproc Clock: Cut 3.0 detected -> setting Preproc clock.
stpio_core_init_module(): Initializing STPIO Module
Load module fdma [254] by insmod (pid 51)
STFDMA_ClbckMgr: task created ... Priority=99
Load module stpti4_core by insmod (pid 53)
Load module stclkrv_core by insmod (pid 54)
hdmi_i2c_init : Initializing I2CHDMI kernel Module
the adapter name is i2c-ssc-0 number 0
the adapter name is i2c-ssc-1 number 1
the adapter name is i2c-ssc-2 number 2
SMSC: Link is now UP at 100Mbps FD
SMSC: LAN911x: ASYMP,SYMP ,100FD,100HD,10FD ,10HD
SMSC: Partner: , ,100FD,100HD,10FD ,10HD
mod_lxload_init: Initializing LXLOAD kernel Module, StartAddress: 0x04200000
Load module lxload[253] by insmod (pid 64)
LXLOADER virtual io kernel address of phys 0xa4200000 = 0xa4200000
/dev/stapi/lxload
mknod -m 0660 /dev/stapi/lxload c 253 0
loading audio binlxload_open: major=253 minor=0
setting up Audio LX in NON-DEBUG mode
ary file
lxload_release: major=253 minor=0
Starting Audio LX by disabling reset
LX loaded:
Base: 0xa4200000
Last: 0xa4347284
mod_lxload_exit: Exiting LXLOAD kernel Module
The I/O memory region 0x04200000 is released successfully
Unload module lxload by rmmod (pid 72)
mod_lxload_init: Initializing LXLOAD kernel Module, StartAddress: 0x04000000
Load module lxload[253] by insmod (pid 73)
LXLOADER virtual io kernel address of phys 0xa4000000 = 0xa4000000
/dev/stapi/lxload
setting up LX in NON-DEBUG mode
Starting video LX by disabling reset
LX loaded:
Base: 0xa4000000
Last: 0xa403403c
The I/O memory region 0x04000000 is released successfully
Unload module lxload by rmmod (pid 81)
EMBXSHM-PortClosed: with RT priority done with syscall. PID=88
EMBX EMBXSHM-PortClosed: task created ...
EMBXSHM-NewPort: with RT priority done with syscall. PID=87
EMBX EMBXSHM-NewPort: task created ...
mknod -m 0660 /dev/stapi/sti2c_ioctl c 253 0
Load module staudlx_core [252] by insmod (pid 98)
sthdmi_ioctl_init_module: Initializing STHDMI IOCTL Module
Load module sthdmi_ioctl[251] by insmod (pid 100)
mknod -m 0660 /dev/stapi/sthdmi_ioctl c 251 0
Load module stvid_ioctl[250] by insmod (pid 107)
mknod -m 0660 /dev/stapi/stvid_ioctl c 250 0
Load module stevt_ioctl [249] by insmod (pid 114)
mknod -m 0660 /dev/stapi/stevt_ioctl c 249 0
stblit_ioctl_init_module: Initializing STBLIT IOCTL Module
Load module stblit_ioctl[248] by insmod (pid 121)
mknod -m 0660 /dev/stapi/stblit_ioctl c 248 0
stlayer_ioctl_init_module: Initializing STLAYER kernel Module
Load module stlayer_ioctl[247] by insmod (pid 128)
mknod -m 0660 /dev/stapi/stlayer_ioctl c 247 0
Load module stpti4_ioctl [246] by insmod (pid 135)
mknod -m 0660 /dev/stapi/stpti4_ioctl c 246 0
Load module stclkrv_ioctl [245] by insmod (pid 142)
mknod -m 0660 /dev/stapi/stclkrv_ioctl c 245 0
stdenc_ioctl_init_module: Initializing STDENC IOCTL Module
Load module stdenc_ioctl[244] by insmod (pid 149)
mknod -m 0660 /dev/stapi/stdenc_ioctl c 244 0
stvtg_ioctl_init_module: Initializing STVTG IOCTL Module
Load module stvtg_ioctl[243] by insmod (pid 156)
mknod -m 0660 /dev/stapi/stvtg_ioctl c 243 0
stvout_ioctl_init_module: Initializing STVOUT IOCTL Module
Load module stvout_ioctl[242] by insmod (pid 163)
mknod -m 0660 /dev/stapi/stvout_ioctl c 242 0
stvmix_ioctl_init_module: Initializing STVMIX IOCTL Module
Load module stvmix_ioctl[241] by insmod (pid 170)
mknod -m 0660 /dev/stapi/stvmix_ioctl c 241 0
stvbi_ioctl_init_module: Initializing STVBI kernel Module
Load module stvbi_ioctl[240] by insmod (pid 177)
mknod -m 0660 /dev/stapi/stvbi_ioctl c 240 0
Load module stmerge_ioctl [239] by insmod (pid 184)
mknod -m 0660 /dev/stapi/stmerge_ioctl c 239 0
Load module staudlx_ioctl[238] by insmod (pid 191)
mknod -m 0660 /dev/stapi/staudlx_ioctl c 238 0
utils_ioctl_init_module: Initializing UTILS IOCTL Module
Load module utils_ioctl[237] by insmod (pid 198)
mknod -m 0660 /dev/stapi/utils_ioctl c 237 0
Load module stinj_ioctl [236] by insmod (pid 205)
mknod -m 0660 /dev/stapi/stinj_ioctl c 236 0
Load module stpio_ioctl [235] by insmod (pid 212)
mknod -m 0660 /dev/stapi/stpio_ioctl c 235 0
Unload module stttx_core by insmod (pid 220)
mknod: /dev/cimax_dev: File exists
mknod: /dev/button: File exists
mknod: /dev/stpio_dev: File exists
mknod: /dev/vfd: File exists
mknod: /dev/wdt: File exists
mknod: /dev/sysconf: File exists
mknod: /dev/fdma_player: File exists
CIMAX DeviceInit
SysConf device Init
LMI_SYS VCR0 = 00d40000
LMI_SYS VCR1 = 0f041000
LMI_SYS MIM0 = 861a0247
LMI_SYS MIM1 = 01010022
LMI_SYS SCR = 00000000
LMI_SYS STR = 35b06455
LMI_SYS COC = 00000000
LMI_SYS SDRA0 = 08001900
LMI_SYS SDRA1 = 08001900
LMI_SYS CIC = 00000249
LMI_SYS SDMR0 = 00000000
LMI_SYS SDMR1 = 00000000
LMI_VID VCR0 = 00d40000
LMI_VID VCR1 = 17101000
LMI_VID MIM0 = 861a0247
LMI_VID MIM1 = 01010022
LMI_VID SCR = 00000000
LMI_VID STR = 35b06455
LMI_VID COC = 00000000
LMI_VID SDRA0 = 14001900
LMI_VID SDRA1 = 14001900
LMI_VID CIC = 00000249
LMI_VID SDMR0 = 00000000
LMI_VID SDMR1 = 00000000
UFS910 Button Device Driver(by Marusys Co.)
tmp_pin = 84753548
VFD_Driver Init
TestModMgr::CheckTestMode CmdLine = console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysarea=1280 coprocessor_mem=2m@0x04000000,2m@0x04200000
CMDLINE = console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysarea=1280 coprocessor_mem=2m@0x04000000,2m@0x04200000
cannot fine test mode
TestModeMgr::CheckMode : TestMode Disabled
