Софт(ПО) и программы для AB CryptoBox 7ххHD
stawr62
7xxHD V1.11.19423_09-05-2018
(English, German, Hungarian, Polish, Russian, Czech, Slovak, Ukrainian, Greek, Bulgarian, Romanian, Turkish, Netherland-Dutch, Arabic, French, Finnish, Spanish, Portugal, Italian)
Changelog EN:
Strictly recommend factory default!!!
fix - STB totally hangs on some channels
fix - HDMI CEC with TV RCU support. After turn on HDMI CEC is reboot STB needed. TV isn´t able wakes up STB from deep standby.
added - improved mcas database
added - youtube.cfg file is automatically downloaded by starting Youtube
fix - auto BISS update didn´t work well
fix - only black screen was on TV while STB wakes up after few hours in fake standby while sharing card
fix - STB reboots itself while cc**m sharing randomly while it wakes up
fix - Dailymotion didn´t work
fix - STB reboots itself while fast forward in Youporn
fix - recordings of IPTV are playable
added - PIN code of CAM is automatically saved on adult channels. STB doesn´t ask enter PIN code on adult channels again. In CI menu there is option to remove saved PIN code.
fix - in Digi CAM entering PIN code on adult channels causes rebooting STB
fix - on VDSL routers problem with network apps
fix - non working audio track AD (Audio description)
fix - while showed TXT window it wasn´t possible adjust audio volume
fix - initializing cam message was displayed on TV while switching channel by using cams Skylink Irdeto Neotion and Skylink Viaccess CAM701
fix - in Viaccess CAM701 wasn´t possible enter PIN code because window was hidden too fast
fix - if PIN code was entered successfully to Viaccess CAM701 on adult channels, picture wasn´t showed on TV
added - region option in weather app
added - submenu name has used larger font
added - in item "Front Panel Display" was added new option "Channel name" = channel number will not be displayed, but only name
change - CI message is ON as default after factory reset
stawr62
- Подскажите - AB-com Cryptobox Комбо 752 с модулями CI+ от 3К и НТВ+ работает?
janigor
7ххHD_V1.14.20062_09-05-2018.zip
Changelog EN:
  • Add Orange card is now working
  • Disable set subtitle when search channel
  • Add save PIN code for CI
  • Add DLNA DMP
  • Add Antik CZ fastscan
  • Fix screenshots while fast forwarding/rewinding HEVC recordings were not showed
  • Add Norwegian language.
  • Add auto fastscan support for Antik.
  • Fix 752HD pixeling issue on DVB-T2 (H.264) channels.
  • Fix sometimes can't show EPG of PVR file (2x pressing info button) and it causes reboot STB.
  • Satellites on first positions on sat list were reordered
  • Improve better Fastscan functionality
  • Improve DHCP problem on VDSL routers
  • Youtube works again
  • Improve 752HD manual cable scan
  • Add Seca cards with FEDC
  • Add Radio network app
  • 700HD_MINI_V1.14.20062_09-05-2018.zip
    4,1 MB · Просмотры: 6
  • 700HD_V1.14.20062_09-05-2018.zip
    4,1 MB · Просмотры: 12
  • 750HD_V1.14.20062_09-05-2018.zip
    4,3 MB · Просмотры: 10
  • 752HD_V1.14.20062_09-05-2018.zip
    4,5 MB · Просмотры: 36
janigor
На новом софте нормально сканируются и показывают все каналы зеонбуда с Астра 4А
12188H, 12341H
На 700 мини - проверил только что.
janigor
7xxHD_V1.14.20092_09-05-2018.rar
Changelog EN:
  • Add Radio app
  • Add HDMI CEC
  • Add Viaccess1
  • Recording from NC+ CAM
  • Hispasat 30W moved to first positions in sat. list
  • Youtube some videos weren´t playable
  • Add Magnet TV FastScan
  • 700HD_MINI_V1.14.20092_09-05-2018.rar
    4,2 MB · Просмотры: 7
  • 700HD_V1.14.20092_09-05-2018.rar
    4,1 MB · Просмотры: 17
  • 750HD_V1.14.20092_09-05-2018.rar
    4,3 MB · Просмотры: 15
  • 752HD_V1.14.20092_09-05-2018.rar
    4,5 MB · Просмотры: 29
janigor
@vovaplus, а чуть выше написано об этом.
Обычно софт для всей линейки 7хх или другие модели получается одинаковым.
На 750 должно работать.
vovaplus
Спасибо работает все и не только на Сириусе а 5 градус западный тоже работает мультистрим Италия и Франция
samodelkin1979
Доброго времени суток всем. Подскажите как перепрошить ресивер через ком порт???? какой прогой его можно шить и какими прошивками???? Заранее спасибо за ответ. P.S. через флешку не зашью так как при прошивке был скачек напруги и теперь кроме заставки при включении ничего нет. на пульт не реагирует.
janigor
Нашел на словацком форуме программу для загрузки софта через COM-кабель (RS232)
Выложено в разделе прог для 7хх моделей
Прошивку взять стандартную.
ПС
Сам восстановление для 7хх ресивера не делал. Не было необходимости.
  • RS232 tool ALIUP.rar
    376,5 KB · Просмотры: 44
janigor
Редактор каналов для 7хх
ПС
Версия 1.6 наверное старая
Версия STBEditor_V1.7.2_750HD наверное подходит не только к 750 а и к 700 и 700мини
Версия STBEditor_V1.7.2_752HD только для 752, поскольку там в списке не только спутниковые каналы, но и Т2.
  • STBEditor_V1.6_7x0HD.rar
    214 KB · Просмотры: 22
  • STBEditor_V1.7.2_750HD.rar
    221 KB · Просмотры: 28
  • STBEditor_V1.7.2_752HD.rar
    222 KB · Просмотры: 38
janigor
Программа для конвертирования записей сделанных на ресивере
  • PC_TOOL_ALI.rar
    70,5 KB · Просмотры: 28
janigor
7xxHD_V1.14.20403_09-05-2018
Changelog EN:
  • Add Orange Fast Scan
  • Modified Ukrainian OSD menu
  • Modified Russian OSD menu
  • Fix Cccam sha**ng with LTE routers
  • Fix There in Youtube after stop and start this app work music videos again
  • Fix Youporn works again
  • Fix Weather app works again
  • Fix Client STB in active standby stays connected to server
  • Fix problem to get IP address via DHCP in some routers after longer time STB was in standby mode
  • Fix Fast Scan of Digi CZ have missing some channels
  • Fix Unable to record two EPG events one by one
    Note: DLNA DMP works with USB stick connected to STB only.
ПС
Удалил глючный софт
janigor
7xxHD_V1.14.20433_09-05-2018
Changelog EN:
  • Fix - EPG doesn´t work correctly
  • Fix - After timer recording STB goes to standby
  • 700HD_MINI_V1.14.20433_09-05-2018.rar
    4,1 MB · Просмотры: 10
  • 700HD_V1.14.20433_09-05-2018.rar
    4,1 MB · Просмотры: 23
  • 750HD_V1.14.20433_09-05-2018.rar
    4,3 MB · Просмотры: 12
  • 752HD_V1.14.20433_09-05-2018.rar
    4,5 MB · Просмотры: 102
sergei2004
добрый день,получил терестриал 702т,какой софт ставить с емуль? пробовал Patch 1.14.20092 и сброс к заводским ну ненашёл емульки внутри
спасибо заранее
janigor
Зайти в пункт меню Xtras и набрать 0000
Santacrus
Changelog EN:
добрый день. 700HD пишет ошибку при открытие
janigor
Не понял что это означает.
Если не разархивируется архив, то проверил - все нормально.
Если не хочет ставиться прошивка, то у Вас очень старая версия на ресивере.
Тогда прошиваемся как описано в сообщении и следующем сообщении:
т.е. обновляемся до 700HD V1.09.17769
1) промежуточное
2) прошивка 1.09.17769
а затем уже самую свежую прошивку
Santacrus
1) промежуточное
Может проблема у меня но никак не могу его разархивироватьSharedScreenshot.jpg
