На AFF board появилась следующая информация TDTs_first_Beta_Image_XMAS_release_rev600:
Кстати и просят помощи. Мож кто подсобит?
А по этому адресу и сама бетка TdT_sh4_enigma2_src_1.00_rev600.zip подшаманенная andy-1
TDT выкладывают source code Е2 видимо устали уже ребята. Но они надеются сбацать и готовый имидж из энтой бетки.Team DuckTales proudly presents the first enigma2 BETA image for Kathrein UFS-910.
If you are a developer, and you have experience in (embedded)hardware/linux-dvb-api
coding feel free to contact us - you're welcome!
To test this enigma2 image you need a running nfs server and a network
connection to the receiver.
The aim of the BETA version was to create an e2 image with as less changes in the e2 source as possible.
We have moved most work into the driver and therefore we can now provide you the modified e2 source code.
In the last weeks we made many modifications which reduces the green screen, make picture and sound more
stable, add the cam module handling to e2 and add many proc entries like they are on dm machines. Of course
there are many things to do and of course some things are not done because of the amount of work and
of missing hardware. But we think that we can say that the current release has the BETA status.
Other improvements:
- changing resolution works no without changing current channel
- streaming BoX -> PC (VLC) works
- AC3 Output works, HDMI and optical
- Startup wizard works
- better RC support
For the future the following tasks are planned:
- improve stability of system
- add support for other cam modules (like alphacrypt, we wait for the delivery of a testmodule )
- timeshift
- handling of loosing signal of tuner
- fixing vfd
- scart and hdmi output at one time
- MKV support
The main change is the proc tree, which is for big parts the same as on dm's.
Not all Nodes are implemented, to get the options for each node, just make a
cat 'NODE'
This image comes in 4 parts,
1. The base Image, as you already know and love it,
2. The Modules.tar containing the kernel drivers, which will be updatet from time to time.
3. The eplayer.tar containing the interface for playback of mpg, avi ... . Will be updated from time to time.
4. The source of our modified Enigma2 GPLv2
greetings from team DuckTales
If you want to contact us, we are sure you will find a way to do this
