Очередной "бюджетный", доступный в Украине, медиаплеер -
http://www.traxdata-multimediadrive.com/:
The Traxdata MultiMediaDrive is a portable multimedia Hard Disk Drive that can simply be plugged into your TV set or any other type of screen for instant playback of movies, songs or photos.
With a huge 500GB storage capacity, you can create your own media library using Traxdata’s MultiMediaDrive to watch movies, view holiday snaps, and play your favourite songs on your television instead of on a computer. Since the drive is equipped with a multitude of audio and video connections it is compatible with most TV sets and it is also able to play a wide range of media types.
The MultiMediaDrive is easy to use and works by transferring files stored on a computer to the drive, through the USB 2.0. It can then be plugged into any audio and video interface, including high-definition multimedia interface (HDMI), allowing you to make full use of your HDTV (up to 1080i) without losing image and sound quality. To further enhance user experience a remote control has been included, allowing you to control your entertainment from the comfort of your armchair.
Download: Datasheet
Specifications
STORAGE
HDD: 3.5” SATA I/II
File System: FAT32 or NTFS
Storage Capacity: 500GB
INTERFACE
USB 2.0 (USB Type B Connector)
AUDIO/VIDEO INTERFACE
Audio/Video: HDMI*, Composite Video + Audio R/L (3.5mm phone jack)
Component Video: Y, Pb, Pr (3.5mm phone jack)
Digital Audio: Coaxial S/PDIF Output(RCA)*
SCART: SCART Connector (Europe)*
OPERATING SYSTEM SUPPORT
Windows: 98SE/Me/2000/XP/Vista
MAC: OS 10.2 or above (FAT32)
MEDIA SUPPORT
Media types: MPEG-1, MPEG-2, DivX, XviD, MP3, WAV, JPEG
Media Files: dat, mpg, mpe, mpeg, vob, m2p, avi, divx, xvid, jpg, jpeg, mp3, wav
DivX Subtitle: IDX/SUB, SRT, ASS, SSA, SUB (type II), SMI, PSB
DVD Folder: DVD Menu/Audio/Subtitle/Angle Selection
CONTENT RESOLUTION
Video: 720 x 576 pixels
JPEG (Baseline): 5120 x 3840 pixels (Baseline)
MP3: 320kbps
VIDEO OUTPUT
TV: NTSC / PAL
Screen Ratio: 4:3 / 16:9
Component: 480i/480p/576i/576p/720p/1080i
AUDIO OUTPUT
Analog Audio: Stereo/Left Mono/Right Mono
Digital Audio: Dolby Digital 5.1 / DTS
SECURITY
Private folder: Password protection in both TV/PC mode
POWER SUPPLY
Input: AC 100-240V, 50/60Hz
Output: DC 12V, 2A
GENERAL
Dimensions: 7.7(L) x 2.4(W) x 4.8(H) inches / 196(L) x 61(W) x 122(H) mm
* The following cables are sold separately: HDMI, Coaxial S/PDIF, SCART.
Download: Datasheet
Specifications
STORAGE
HDD: 3.5” SATA I/II
INTERFACE
MEDIA SUPPORT
CONTENT RESOLUTION
MP3: 320kbps
VIDEO OUTPUT
TV: NTSC / PAL
AUDIO OUTPUT
SECURITY
POWER SUPPLY
Output: DC 12V, 2A
GENERAL
