OCTAGON SF1008 HD INTELLIGENCE V10826 09.06.10
for Octagon HD SF 1008 HDTV - INTELLIGENCE :
Changes :
- STB hang-up when aging fix.
--> SSeveral optimisations in main SW !
- No signal when AC power Off/On fix.
- Move finction problem in service list manager fix.
- Timer : UI when setting the timer and if duplicate with the previous timer - Improved
- New Function in Timer Settings Menu :
--> Menu - System Tools - Timer Setting : Blue Button - Delete All
- Playlist (Playback) EPG Info durch INFO Taste
--> [INFO] button excute in recording file - improved : EPG, Time & REC file details
- Samba Turkish char support (8859-9 default)
- Turksat (42E), latest TP List - Updated
- Incorrect channel number display in REC info bar when recording fix.
- Incorrect recording time in recording file fix. (Trick Mode Problem)
- OSD message box - Improved
- SAT Name add. by Service Search Mode
- New Function in Infobar :
--> Menu - Configuration - Display Setting :
--> Info Box Event Name : present event with time, present and follow event
- Volume Control in TXT Mode (Volume v+ v-) add.
- BISS + DCW input (keymanager) adjusted
--> Menu 8282 ...DCW key new functions add.
--> SID ONID TSID . & SID PMTPID ECMPID
System Information :
- API Version 08.Juni 2010
- Treiber Version 08.Juni 2010
- Build Version : 3206
Online SW upgrade : oud.gmc.to
Файловый архив.
Обсуждение.
Changes :
Файловый архив.
Обсуждение.
