PKT Octagon SF-1028P E2 HAARP v3 Image
Enigma2 OpenSource SH4 Duckbox Project GIT-3052 PKT SVN-1250 HAARP v3 Image
Имидж собран для установки в FLASH / USB / SATA
Для ресиверов: Octagon 1028 / ATEVIO 7500
Kernel stm24-207
Added by sh4 Duckbox Team:
- [make/ffmpeg] - updated ffmpeg 0.6.1
- [eplayer3] playback aac-he streams with aac-lc
- fix timing problem in filepush
- [Player2 179/191] possible fix for chopped DTS sound on some files
- [e2 nightly-0]introduce 3D Mode for OSD ( paint OSD twice in Side by Side or Top and Bottom )
- [libeplayer3] support for OSD 3D modes for subtitles
- [libeplayer2, libeplayer3] Close directory file handles after looking for subtitle files
- new BusyBox 1.19.2 (stable) config and patches
- extend streamproxy to support linuxdvbapi5
- [player2_191/player2_179]resturucture dts fix. The fix now only applys to DTS streams and the playback time is only corrected on time differences up to 50ms this MAY fix some issues with async sound
- [player191] adoptions from p179; bugfix for 710x receiver (HD channel problems)
- [player2_191] fsynth bugfix
- fix ufs910 audio on scart
- use utf8 as python default
- adapt wrong page_offset and improve mem
Added by PKT:
- добавлен новый WebInterface v 1.6.7
- новая функция "live ecm" в инфобаре
- показ номера канала на передней панели + ON/OFF в меню настройки
- upgrade CrossEPG svn 268
- исправлена qwerty VirtualKeyboard
- исправлена Backup/Autorestore функция | LABEL=RECOVERY required
- исправлен показ номера канала в VFD, если название канала слишком большое
- set home directory to /root
- EPG description on channel list -> ON
- change reading of ecm.info
- новые converters и skins модификации
- исправлена функция угасания при переключении каналов
- fix parsing PROV, CAID, PID
- moving EPG support to KeyMapper
- ReferencePKT optimization
- установлен скин PKTGoldHD в качестве скина по умолчанию
- fix CIFS mount if passwd is empty
- MPlayer fix GS of EOF
- upgrade formating device in Install Manager
- update API of MyTube based on last CVS source
- update EmuManager v1.0.6: add sh4Cam support & gbox fix
- font FIX moved to Skin setup
- remove unnused files or BP menu settings modification
- fix showing processes
- res_emu in standby add in BP->Settings
- tune and fix sys_info
- add showing /Loaded modules/ in BP ->Menu ->System
- update WIFI scripts:
* add detecting of supported USB WLAN adapters
* user is informed about unsupported device
* optimize selecting WLAN driver
* optimize starting WLAN driver
- fix show event-progress in channel selection
- fix crossEPG
- PKT InstallManager 1.2.2
- PKT KeyMapper 1.5
- update Permanent Clock
- fix EMUManager russian translate
- add green button support in Media Player
- fix streamproxy after reboot
- Add Auto 3D Skin Switch by Dr.Best
- add support for fake cccam
+ change only in HAARP V3 version
- пиконы обновлены
- добавлена активация BPanel в MoviePlayer ( синяя кнопка )
- добавлена совместимость с другими не PKTeams скинами
- fix dot on VFD if channel number is not available
- исправления для обоев в радио режиме
- исправлен показ пиконов в списке каналов, если они находятся в папке /hdd/picon
- добавлен поиск папки пиконов /media/usb/picon
- 2nd generation of speed up channels zap
- add standby smooth extingushing TV
- обновление списка каналов 28-10-11
- улучшение качества отображения
- новая BluePanel 2D v3.1.19 с графическим интерфесом:
-- добавлена ​​функция для проверки необходимости обновления
-- added color & numeric keys actions support to immidiate plugin/function/menu activation
-- 1st row - keys: 1, 2, 3, 4
-- 2nd row - keys: 5, 6, 7, 8
-- 3rd row - keys: red, green, yellow, blue
-- добавлено действие по нажатию кнопки меню
-- добавлено меню информации об изменениях
-- добавлена синхронизация локального времени и даты с NTP сервером
-- added on/Off the smooth extinguish TV while switching to standby mode
-- add Enable/Disable cardreader for 1008+ in Blue Panel (default: OFF)
- исправлено отсутствие файла reference.dat
- исправлено переключение международных шрифтов в настройках скина
FTP login: user: root, passwd: pkteam
  • PKT_SF1028_E2_HAARP_v3_Image.zip
    39,3 MB · Просмотры: 53
  • PKT_SF1028_E2_HAARP_v3_Image_Flash.zip
    36,3 MB · Просмотры: 18
Установил настроил. Первые впечатления отличные. Русский шрифт можно пофиксить в меню настройки скинов нажатием кнопки EPG. Понравилась новая блюпанель !good!. Исправили меню softcam: если русский язык теперь не вываливается в зелень. Понравились новые функции: скачивание иконок, пиконов и обновление блю панель. Что-то скриншоты через вебитнерфейс не удалось сделать...
Монтируются жесткие диски также как и раньше без проблем.
При всем моем изощрении так и не удалось отправить ресивер в зеленку. Очень стабильный имидж. Можно рекомендовать для установки во Flash ресивера.!good!
Все таки мне удалось прикрутить скин HD Glass16 v3.76 на HAARP v3 :). Но он не до конца гладко работает. Иногда можно зелень выловить. Вот результат:
arion75
Где можно взять этот скин.И как правильно поставить именно на этот имидж.
В интернете. :) Если честно новичкам не рекомендую проблемы потом может быть неописуемые. Я его устанавливал вручную. То есть раскидывал все по папкам и заменял файлы. Есть версия пониже для IPbox 3.44 в ipk ее можно ставить из меню ресивера. А еще я тут выкладывал на форуме его в теме энигма - скины. :) Но скин очень классный много информации.
Вот тут выложил ipk этого скина. Очень легко установить в автоматическом режиме!good!.
Ребята кто желает потестировать энигму для 1008: sf1008_GIT-3105_PKT-1269-NP_stm24-p0207.tar.gz пишите мне я дам ссылку на скачивание. Имидж тестовый пока не официальный релиз.
Сегодня получим энигму HAARP v3a для всех поддерживаемых моделей. :)
arion75
Насколько я понял обновить предыдущую версию не получится.Нужно делать бекап имиджа и по новой устанавливать на флешку.
Посмотрим. Может будет обновление с сервера. Хотя у них раньше не было такого. Да бэкап надо сделать если не хочешь заново настраивать.
PKT SF10Х8 E2 HAARP v3a Image
Enigma2 OpenSource SH4 Duckbox Project GIT-3106 PKT SVN-1273 HAARP v3a Image
Kernel stm24-207
+ change only in HAARP V3a version
- обновлены пиконы
- добавлена совместимость со стандартными не PKTeams скинами
- fix for radio mode wallpaper
- fix показ пиконов, если они расположены в папке /hdd/picon
- added /media/usb/picon to picons search folders
- channel list update 28-10-11
- display quality improvement
- new BluePanel 2D v3.1.19 with graphic interface:
-- added function to check update is needed
-- added menu key action support
-- added changelog information menu
-- added synchronization of local time and date from NTP server
- fix missing reference.dat
- fix international fonts switch in Skin Setup
- [SF1018/SF1008/SF1008+] fix cardreader driver
- screenshot OSD fix
- fix GS on GlassHD skin
- [SF1008+] fix deepstandby
- [SF1008+] теперь картоприемник все время активный
  • PKT_SF1028_E2_HAARP_v3a_Image.zip
    39,1 MB · Просмотры: 250
  • PKT_SF1028_E2_HAARP_v3a_Image_Flash.zip
    36 MB · Просмотры: 148
  • PKT_SF1018_E2_HAARP_v3a_Image.zip
    37,7 MB · Просмотры: 121
  • PKT_SF1008_E2_HAARP_v3a_Image.zip
    37,8 MB · Просмотры: 138
  • PKT_SF1008+_E2_HAARP_v3a_Image.zip
    39,5 MB · Просмотры: 928
  • PKT_SF1008+_E2_HAARP_v3a_Image_HDCLONE.zip
    45,1 MB · Просмотры: 993
Установил настроил под себя. Поправили вебинтерфейс. Можно скриншоты делать. Я нащелкал вот чуток. Видеострим тоже работает через вебинтерфейс. Вчера проверял !good!. Можно на телевизоре один канал смотреть на компьютере другой. :)
andkip
тоже очень понравилась эта версия. все работает и очень приятненько.
нормально сработал фикс русского языка.
проигрывает все видео файлы что у меня есть
получился норм медиа комбайн наконец-то
у меня 1008
dima381
установил проверял спасибо все в норме папку вар взял с нета менял вар полностью при перезагрузке рес не запускается открыл запустил через путти пишет что логин и пароль ввести надо ввожу от пкт теам не действует снес систему заново установил опять флешку форматнул систему установил запустил три раза и все три папки вар от других источнико е2 не грузитсяна путти пароль и логин висит но в первый раз с своим родным папкой вар нет такого.
arion75
У меня на С6 стал новый имидж без проблем.
Молодой человек потрудитесь расставить знаки препинания. Ничего не понятно из этой каши :(. Одним предложением все написано :stop:.
Реакции: Yaro
dima381
пока вар не трогаю все норма работает е2но шару надоже смотреть ставлю вар свой закаченный с интернета после перезагрузки на путти появляются логин с паролем.Тут
root
pkteam
не помогают уже
Зачем ты папку var меняешь я этого не пойму хоть убей. Тебе нужно в папке keys файлы, все остальное тебе не нужно. Естественно если папка от другого ресивера там и пароль другой. Или я не прав?:)
dima381
спасибо все ясно где именно она держится пароль ? чтоб больше не менят то что не положена или можно их подправить?
Имидж надо заново ставить :). Потому как в папке вар куча важных файлов энигмы... Меняй только свои нужные файлы для шары все остальное оставь. Сам себе геморрой создаешь.
