nikomar
PKT mod 5.6 Tideglo rev 0.5.5
E2 Tideglo
release 0.5.5
Ok from this release you will get a nightly build image. (this means i will not support stupid options like: panels, plugins and so on)
Soon a sifteam image will be out with panel and many options enabled.
I choose this way because i want that cuberevo community increase more! Many teams are involved in E2 now, so
each one can do his choice, and sifteam images will be out with another image (obviously based on the same Nightly build image version)
I will publish also how to build your own flash image, so every team can do it.
- new bootlogo (thanks arken)
- added bulgarian language
- added autofs
- added openvpn
- added openssl library
- added 576i to AutoResolution plugin
- added ftpput
- added ftpget
- added netstat
- "fixed" signal level on tuners
- teletext exit with "exit" button on remote
- fixed aspect on screen when exiting from teletext. If watching 16:9 format, it is shrinked, so looks like 16:6 or something
- fixed positioner setup
- fixed teletext subtitles
- remapped few buttons
- fix for DVB subtitles wich were not shown on some skins
- fixed bootlogo view on SD television
- fix the issue with stopping playback while it is paused
- incorporated the new web interface version (04/06/2009)
- fixed fast forward for MP3 in MediaPlayer
- enabled forwarding the second transport stream to the decoder
- fix avi 23.976fps/24.976fps/29.976fps
- avi: fix audio track selection early support for redirecting in http streaming
- added .rec extension file support
- CI cam drivers handling should now be better
- lot of fixes on PicturePlayer
- lot of fixes on MediaPlayer
- modified epgCache load to allow the load on e2 starts (now crossEpg works perfectly)
- added estonian language
- allowed to record/stream multiple channels from the same transponder (FTA only)
- There were a bug when a freeze happen on HD and SD channels, that bug showed you a full green pixel screen or an image repeating loop,
well this is bug was really hard to find for me and i'm not sure i've found all the cases when it happens, so... let me know if it happens again.
Many people asked me to add smart card drivers made by pacco, but i've not did them, so i will not add them like part of my images.
They can be added manually by everyone and each team made the possibilty to download and install them, so i will not add them until
i will make my own version (wich i don't know when and how it will be ready, you can use the pacco's version wich is good enought)
Enjoy it! Tideglo
Zmiany PKT w stosunku do wersji 5.5
- nowy przebudowany BP - wersja "wielojęzykowa" - możliwość łatwego tłumaczenia na inne języki
- PKT locale EN/IT/ES/DE/PL
- pobieranie EMU -> BP-> Wtyczki-> Przeglądarka wtyczek-> zielony przycisk
- zaktualizowano PKT feed
- nowe skiny i picony by Father Pio
- nowa zaktualizowana lista kanałуw
- nowe bootlogo
- nowy EMUmanager 0.9.2
- nowy MOUNTmanager 0.6.1
- oraz wiele innych zmian i poprawek...
Zapraszamy zainteresowane osoby do tłumaczenia BP na inne języki.
Pozdrawiamy
Polish Kathi Team
Wersja USB/SATA
PKT_mod_5.6_Tideglo_rev_0.5.5_9000_USB.tar.gz
(34.52 MiB) Pobrane 34 razy
http://pkt.cal.pl/download/file.php?id=1141
PKT_mod_5.6_Tideglo_rev_0.5.5_910_USB.tar.gz
(34.52 MiB) Pobrane 27 razy
http://pkt.cal.pl/download/file.php?id=1142
PKT_mod_5.6_Tideglo_rev_0.5.5_900_USB.tar.gz
(34.52 MiB) Pobrane 6 razy
http://pkt.cal.pl/download/file.php?id=1143
PKT_mod_5.6_Tideglo_rev_0.5.5_91_USB.tar.gz
(34.47 MiB) Pobrane 10 razy
http://pkt.cal.pl/download/file.php?id=1144
Wersja FLASH
PKT_mod_5.6_Tideglo_rev_0.5.5_9000.tar.gz
(27 MiB) Pobrane 14 razy
http://pkt.cal.pl/download/file.php?id=1137
PKT_mod_5.6_Tideglo_rev_0.5.5_910.tar.gz
(27.22 MiB) Pobrane 11 razy
http://pkt.cal.pl/download/file.php?id=1138
PKT_mod_5.6_Tideglo_rev_0.5.5_900.tar.gz
(27 MiB) Pobrane 9 razy
http://pkt.cal.pl/download/file.php?id=1139
PKT_mod_5.6_Tideglo_rev_0.5.5_91.tar.gz
http://pkt.cal.pl/download/file.php?id=1140
E2 Tideglo
release 0.5.5
- added autofs
- added openvpn
- added ftpput
- added ftpget
- added netstat
Enjoy it! Tideglo
- nowe bootlogo
Pozdrawiamy
Polish Kathi Team
Wersja USB/SATA
Wersja FLASH
